DaveK Dave Kern Mod Moderator Location: Centennial Join Date: 07/11/2008 Age: Midlife Crisis Posts: 1,085 Rally Car: Compact M3 & Evo IX |
We tried that on the edge of the splitter on my Evo at PPIHC one year. I thought it worked pretty well, but looking at pictures after the event even the stiff stuff really flexed at speed. In some high speed sections looked like it was folding back nearly 45 degrees from the static mounting position. No idea what that means in terms of how good/bad it worked, just and observation. Dave |
MConte05 Matthew Conte Super Moderator Location: St. Louis, MO Join Date: 06/27/2011 Age: Settling Down Posts: 257 Rally Car: 1991 Subaru Legacy Turbozzzzzz |
I think that's what I used? Had a 90 degree lip on one side that we riveted into the top of the splitter, and then on the other end there was a round tube thingy that gave the lower lip strength. In the pic you can see the deflection from the way the shadow/sun is hitting it: ![]() ...and damn, I really miss the dirt up there! Dave |
I threw on the pretty one on the new Legacy. It's pretty much useless. However the skidplate is tucked up a lot tighter than my old one since I don't have to clear NA headers. So it still feels more stable at speed than the old car (diffs and proper alignment helps too).
I do want to find whatever the WRC or SRTUSA guys are using, at least in 4" wide rolls. |
One of these days I'm going to have to ask Ben what he had on the Focus, it seemed pretty robust, at least until you started slamming it into the ground...
![]() ![]() ![]() ![]() ![]() ![]() http://www.utahrallygroup.com |
funny you should mention it...Was out in the heat doing this today--in between chasing some squirmy giggly girls, pushing on a several ton CNC mill, and packing for a campy trip up into the mountains to watch the meteor shower. ![]() These should be ready to ship mid week---I'm probably going to revise the upper little ear mounts so they are 100% boxed (top and bottom) Sure would be nice if the shocks order so long ago ever would come ![]() John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Thanks John, looking forward to getting them in |
Got the struts John, thanks, now where do y'all recommend I get springs? 2800ish lb car, rwd, nose heavy pig with s50 in front. Some jumps coming up at BRS, so want to get it right and not bounce off the road on a landing.
Relative Noob driver, probably 25 stages under my belt now. |
My compact is about 2700 with nobody in it and no rally spares or tools. Also had heavy S50 up front and the car seemed great up front with 2.5" diameter 14" 300# springs on the 40mm JVABs. I just ordered up another set with the same rates from a local roundy round shop earlier this week. The new springs are 2.5" barrel springs from Swift as a standard 2.5" spring didn't the spring perch. (Note: I asked for something weird from John, so your setup may require 3" diameter springs.) Dave |
