XR Build Thread
Posted by Thomas Kimsey
Re: XR Build Thread
June 18, 2014 12:35PM
Thomas Kimsey
Man I want to look at those and see about lengths and stuff now that its going to be straight gravel car....you're probably going to want different springs, those Ford 909 things are stiff.
Main springs 27.3cm 80N/mm (STIIIFFFFFFF)
Helpers 9.5 cm
Ring me.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
June 18, 2014 03:57PM
Ring me.
Ill get you the insert specs tonight. Then I have to throw the car back together to move it. Probably ship you a box on Friday.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
June 18, 2014 05:34PM
Dimensions are in cm and are not exact.
Insert stamping: 380 160 53619
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
June 27, 2014 02:52PM
Haven't done much with the car this week. Had to store it in the yard without the front suspension in it.
Should be pretty busy with it come mid July.
Had to put them in to move the car before I took the front suspension back apart.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
July 21, 2014 05:01PM
For anyone wondering about the dimensions for the XR driveshaft for supra diff.
XR Driveshaft
OD 2"
Wall Thickness 0.065"
Re: XR Build Thread
July 21, 2014 07:13PM
Thomas Kimsey
XR Driveshaft
OD 2"
Well that sounds like weld yoke PN 2-28-417
2.000 X.065 W
1.881
1.688
is the weld yoke of choice then.
http://www.drivetrainamerica.com/p-5127-spicer-2-28-417-1310-weld-yoke-2-x-065.aspx
currently outta stock so ask for the Neapco equivalent.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
July 21, 2014 07:26PM
Thomas Kimsey
XR Driveshaft
OD 2"
2.000 X.065 W
1.881
1.688
Looks like Northern Drivetrain has it available for drop ship.
Re: XR Build Thread
July 21, 2014 07:36PM
Thomas Kimsey
Thomas Kimsey
XR Driveshaft
OD 2"
2.000 X.065 W
1.881
1.688
I package with 2 parts ships cheaper than 2 packages with one part..Dunn forgits the U-joint.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
July 21, 2014 07:45PM
Thomas Kimsey
Thomas Kimsey
XR Driveshaft
OD 2"
2.000 X.065 W
1.881
1.688
Found them all cheaper and in stock elsewhere.
Re: XR Build Thread
July 21, 2014 08:01PM
Thomas Kimsey
Thomas Kimsey
Thomas Kimsey
XR Driveshaft
OD 2"
2.000 X.065 W
1.881
1.688
oooooooooowwww ain't you special?
howza bout a fawkin link?
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
July 21, 2014 08:05PM
Thomas Kimsey
Thomas Kimsey
Thomas Kimsey
XR Driveshaft
OD 2"
2.000 X.065 W
1.881
1.688
http://drive-lines.com
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
July 21, 2014 08:07PM
Site is not so great but allows you to search part numbers.
Also not cheaper, was looking at the wrong part. No in stock alternative to Spicer 2-28-417.
Edited 1 time(s). Last edit at 07/21/2014 08:36PM by Thomas Kimsey.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
August 01, 2014 09:29AM
Car should be a lot better with this. Supra 4.3, 250 ft lb breakaway and crush sleeve eliminator.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
August 04, 2014 01:28PM
Long weekend working on these two.
Learned a lot about setting up a diff as well. Waiting on getting the right shims to put together the supra diff.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
Re: XR Build Thread
August 13, 2014 08:32PM
After a long week of rebuilding the diff, mounting the diff, modifying a propshaft, putting the front suspension back in, and fixing blown up coolant lines I made it out to a rallycross.
For those of you who want to rebuild a supra diff the shims from Toyota are not so easy to find. I ended up having the original ones surface ground and modified some other ones I had to fit. Also you will need a very large bearing splitter for the inner pinion bearing.
Me and the XRatty
Graham and the 96. Unfortunately due to clutch issues he didn't race it.
Proper limit slip makes this car very fun.
A little too fun.
Graham had some fun in the XR as well.
Edited 2 time(s). Last edit at 08/13/2014 08:36PM by Thomas Kimsey.
