Thomas Kimsey Thomas Kimsey Mod Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
Solidworks FEA ![]() Abaqus ![]() Also, not worth it as a design validation as it would get me nowhere with the scrutineer. And it surely would only be good for comparison between designs and not as an accurate model of the whole system. Would be a fun side project if I didn't have a whole lot of other projects and a vast lack of time. Side note: What is on the Clark XRatty for oil cooling? Stock ecoboost heat exchanger or proper cooler? Edited 1 time(s). Last edit at 06/14/2016 07:59PM by Thomas Kimsey. |
Coolant temps dropped from 125C to 99C max (257F to 210) after the hood was removed. The old engine saw 135C/275F a few times... scary hot. That same motor did 4 more races with high temps, and it never skipped a beat... until Rocky this year, when it holed a piston. The 'boost is a pretty tough little motor. |
Its connections to the rear towers are done like the Izzy's one (the bars are laid out differently though): I think its cage was built by The Original Dave Clark. Self-righteous douche canoe Edited 2 time(s). Last edit at 06/20/2016 05:11PM by hoche. |
If only it were that easy. The problem is that there are a lot of gray areas in the rules and it's in those cases where scrutineer opinion comes into play. And it's complicated by the fact that different scrutineers have different experiences, training, and temperment. Some try to be helpful, some are martinets. Self-righteous douche canoe |
Started the cage last weekend. Waited almost six months to have a local shop make my bends but after a while they told me they didnt have time. Luckily I was able to borrow a bender from a friend last week.
DanielSL Daniel Professional Moderator Location: Vero Beach, Florida Join Date: 03/02/2016 Age: Possibly Wise Posts: 338 Rally Car: 2005 VW Mk. 4 Golf GTI 1.8T |
p0inT92 Thorkild Mathiasen Godlike Moderator Location: Denmark Join Date: 08/08/2014 Age: Settling Down Posts: 21 Rally Car: Maybe a Lada.. |
Its not very hard. I do have help from someone who has done a couple cages before. I am certain there are better people to ask on this forum for tips and tricks as I am an extreme novice at this. But I will give you a brief overview. Boxes for cage feet - 3mm steel plate cut with a cutoff wheel. Pretty simple but time consuming to make everything fit nicely. Main hoop - Took a large piece of cardboard and cut it until it fit where I wanted the main hoop. Then I took a bent piece of pipe and traced where the bends would be. Trimmed the cardboard in straight lines between the bends and then replicated the cardboard outline in tubing. Forward legs - I had some bends from a old cage I cut apart so I just mocked up a forward leg out of 2 bends and some straight parts. I couldn't imagine trying to get the fit right on the forward legs without having some pre existing bends to play with. (Attached picture to show mock up forward leg) Everything else is pretty much measure, cut the tube an inch too long, and take a small cut with a tubing notcher, check fit, if its too long still take more small cuts till it fits. The tubing notcher I borrowed will only cut to 60 degrees so some members have required some sculpting with an angle grinder and a flap disk. I've only scrapped one piece so far and it was because it was less time consuming to make a new one and it was only 6" long. |
It would have been nice if I got the tubes bent a while ago but I was also busy doing other stuff like being lazy and helping my housemate with getting his 96 logbooked and ready. Probably could have pushed the shop to bend them a long time ago, also I got the tubing from them and they gave me a good deal.
More progress this weekend. However the seat mounts are too high and with padding on the forward leg and a helmet on there are clearance issues. This week is going to probably be dedicated to putting the seat mounts as low as possible.
Things left to do on the cage are -Taco Gussets -Tie front strut towers to cage -Harness bars -Tie rear strut towers together/to floor over diff mount |
