Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: The TDI is ALIVE !!!
September 22, 2014 02:29PM
After much swearing at wires
Test drive today???
One. Class -- 2WD
www.quantumrallysport.com
September 22, 2014 02:54PM
Did you figure out the clutch switch?
Steve said one is cruise cancel and the other is clutch start cancel and both can go. And that he never got your email.
Josh Wimpey
Josh Wimpey
Sneak the Golf
September 22, 2014 04:09PM
Got it, Steve emailed me some helpful instructions last week.
The brake switch is the tricky one. It is a 4-wire switch that switches different circuits closed in each direction (brake off or brake on). To make matters worse, the ECU monitors both and the stop lamps too. Some folks have gotten clever but end up with impossible brake value codes flashing the glow plug light on the dash and other issues.. seem the simplest route is to zip-tie the plunger in the 'brakes-off' position so the ECU never sees brakes at all...
One. Class -- 2WD
Josh Wimpey
Josh Wimpey
Sneak the Golf
September 23, 2014 03:08PM
Reported: Test drive went well if really noisy in the cabin. Need to add an isolator to the pendulum mount for sure and maybe more than that...
Still some more work to go. Maybe a video later
One. Class -- 2WD
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
September 24, 2014 08:42AM
Car looks good. When is it going to see the stages?
September 24, 2014 10:26PM
i wanna know more about the VNT
riverwestauto
jake henes
mk2 jetta
May 14, 2015 06:40AM
Still have to deal with the clutch and brake pedal switches. I am running a pressure switch for the brake lights so the pedal switch needs only fool the ECU into never seeing brakes applied so that brake and throttle can be applied simultaneously without fuel cut. Not sure what to do with the clutch pedal switches. Am I correct that they are only used to cancel cruise control?[/quote]
Software tuning can delete the two foot driving ecu problem. In fact it can do away with other things like limp mode etc.
