Eric Ewert Eric Ewert Godlike Moderator Location: Calgary, Ab Join Date: 05/13/2013 Age: Settling Down Posts: 366 Rally Car: volvo 240 |
I dunno man, too tired to look it up.
Im kinda stumped after starting this thread. Everyone actually came to the table with valid arguments for going various routes. This is what i'm seeing, this factors in a t5 gearbox in there. Volvo 1030 Pros Cheapest, would have it together for around 800$ Axle : Need to have it shipped here so say 400$ R@P: 150$ If coming from a 140 may have the right gearing but count on needing one Fresh bearing/ seals. I dunno 120$ Driveshaft adapter: 90$ Driveshaft from pnp:40$ Bolts in, easiest and fastest to put together Cons: Probably fine strength wise but is the weakest Hardest to find No cheap diff thats good for gravel Toyota 8 inch Pros Far more plentiful than a volvo axle Removable center section... I quite like the idea of this. Supra diff slots in it... and I have one already. Stronger than a volvo 1030 by a good amount With the diff in there would work better than a welded 1030 Cons Cost... see below Supra diff from yard: 90$ Complete axle: 130$ Count on a ring and pinion but 4.88's did come in these things. 160$ Rebuild kit:120$ Redrill axles, well ill leave this out. I may have matt or my school who can help with this. But as discussed above 160$ Driveshaft: I dunno, here in calgary probably 500$ minimum to have a custom one done up. E-Brake: no easy solution for a ebrake that is safe for parking. Line lock? Must fabricate panhard mount aftermarket 4 link. Probably easier than swapping volvo mounts over: 200$ ish in parts Total: Minimum 1200$, not including ebrake or cost of machining axles. Say 1500$ But it is a better axle. Ford 9 inch. Similar to yoda but about 20x them in pick n pull. With lsds. and brake options. But you would be looking at adapters or different wheels to keep factory brakes. Get the displeasure of shortening an axle. Not something im comfortable with doing and not sure what it would cost. Could be cheaper than the toyota. And would have way more parts available to it. But It is probably a good bit heavier. Ill sleep on it. Who knows I might just spur of the moment go and pull a pathfinder axle out of the yard just to piss everyone off. Im not actually going to do that, however there are a lot of those things in the yard and if memory is correct they got removable center sections and are similar width to toyota. Edited 1 time(s). Last edit at 10/11/2014 02:19AM by Eric Ewert. |
tdrrally edward mucklow Ultra Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
how about an ford 8.8 from an explorer rear disk brakes stock lsd stock r&p with install kit $320
then go to http://www.circletracksupply.com/clamp-on-panhard-mount.html and a custom drive shaft should be around $150 or a mustang 8.8 from an sn95 v8 stock lsd and disk brakes parking brake cable and the rest from the same sn95 you can buy for little money new four link mounts from different companys like http://www.tabzone.com/AXLE-BRACKETS_c_31.html I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
The Ford Explorer 8.8 is another swap that is done into 240s. It involves shortening the longer axle tube to match the short one (2.25in?), this puts rear track on par with the front, but it's still 2in wider than stock. Grab another short side axle for $110 new and you're good to go. This is covered on Turbobricks a lot, wih different ways of accomplishing the chop and weld.
I have seen a lot of 8.8s with clutch type lsd on Craigslist here. $150 for a disk break rear end, complete. Will require a shortened mustang driveline. |
Yes beaten to death on Turbobricks where people scream that its so much less work that the Toyota axle.. Even when you do a 2 column comparison and show --finding a suitable axle---same, chopping off bracketry---same ----doing something about bolt circle--same, buying a yoke/propshaft fiddles ---same and then you have "chop off Pass Side axle tube, shorten, jig up and weld, check for straightness, straighten, back to junk yard to fuck around to find another short side axle....drill that one..." Somehow, with the logic of 3-4 screaming guys, THAT extra bit " is less work" Yeah do several extra steps and one involving precision welding---to end up with a 2 pinion rather lame diff..Sounds like good thinking. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Shop right. Some of thos stupid things came with 4.67 or shorter. Beggars can't be cHosers, Price for 4.88 meh find a 4.67 fawkin grab it, do the 4.88 later if you find your being held back by 4.67. LOOK at it, skip "rebuild." Its a fucking TOYOTA diff...they're marvy. Your current diff is Ok and its USED!!!!!! Oh Noez! well the Toiletta is used but its WAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAYYYY better so don't worry. Weld diff---till you can afford a El Ess Dee. Handbrake if you splurge for a "quaaaaaaality' handbrake master will hold--especially if you put the wheels to the curb as you should---never lost a car in Seattle--we have a few hills. Propshaft--use brains---outsmart the bastids... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
mellow65 Oliver Klozoff Super Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
http://yoshifab.com/store/index.php?_a=viewProd&productId=37 "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Skip rebuild? Im talking about fresh bearings in the housing/ center section, which any of these axles are getting for the cost of 120 bucks. Im not going to throw a 300 thousand plus km rear end in and hope it doesn't go wrong. Not for that price. I wasn't talking about the diff.
Welded in a toyota? That defeats half the purpose of going to a toyota which is very affordable diffs. One which I already have. If Im going to weld it I will keep to a 1030. Shop right.... even the 4.56 ones are scarce. Every one of these things at the yard seams to have a 4.3 at best. As previously mentions they are not too hard to find but they are not free pickings at the yard. Typically there are a couple in there. Maybe don't just disregard everything I just put down... |
Lots and lots of cars have been rallied successfully with other than 4.88 diffs. Anything near 4.5 is plenty and with a decent transmission and 175 hp then 4.00 can work. LSD , yup nice but some guys go pretty fast with a Lincoln Locker...I've rallied with an open diff and somehow survived.
So, I wouldn't spend money to go in a wrong direction, especially if it is wrong and difficult. Seems like 1030s are hard to find, hard to LSD, iffy on gearing and you have to spend money and go out of your way to do so. Toyota.. brackets should be nearly a non-issue for anyone building a rally car. Cut, grind, weld. axle shaft..a bit more difficult but I bet I know a guy who can do them for a moderate fee..done right. driveline ..iffy. Iffy the tube is the same diameter and either shortened or a different yoke of the correct size is installed then really not a big deal. Balancing usually isn't far enough off to worry about, honestly. Keep things straight and weld neatly. I don't know how many drivelines I've cut in days gone by with no big issue. We never balanced rally tires and a rim full of mud fawks things up in a heart beat anyway. DROP IN GEARSETS..should be self explanatory.. Ford..doesn't fit, doesn't fit right after extensive mods, expensive gear changes, costs as much or more. You already own the Supra LSD..you could go another route and sell your parts, you could go another route and still do a Toy later..but why? E-Brakes... hydraulic works. Either use the stock handle with the button pinned or a fancy schmancy one with a board or bungee cord. Daily driven rally cars..no, no, no. Do it right, do it once. Life is like that. A DNF costs more than the difference in building a good diff. Cheap and easy usually applies to the crack whore working the truck stops.... Chin up lil buckaroo ! or sell the whole mess and buy a Sube.. Ford...cutting a housing AND all the work needed for a Toy... |
There are a couple of times we've seen rally cars, with quality components, roll away after being left on their hydraulic handbrakes. Most recently, it was a car that had to stop mid-stage beacuse of an emergency situation. Best thinking on the situation was that as the brakes cooled, the fluid 'contracted,' reducing the pressure on the handbrake. (I can easily see this same cooling coming into play when changing a flat at the end of a stage... maybe even in the middle.) If it is easy to accomplish, I think there is good reason for a mechanical handbrake. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015
He's up there where there has to be piles of wannbe Mountain Men with the 4-runners all with fat, TALL tires so with a little searching he ought to be able to find one with the 4.67 or even the 4.88...just have to spend the time to search a bit...but as i said with college, time is a premium.. 'xactly
Up there where nice cars rust and get crushed, seems so. Here I can find 'em in 5 minutes. 09.42 now. 09.42; Fresh Inventory, Great Prices! Home Donate Vehicle Toolkit Rewards Search Events & Specials Check Inventory Part Pricing Locations We Buy Cars We Sell Cars About Us Printable Version Check Inventory Tracker: The Rapid Parts Finder To search vehicle inventory across all of our stores, please fill out the fields below. NOTE: If you don't find the vehicle you are looking for, call your local store and ask about interchange possibilities as several makes and models may have compatible parts. Postal/Zip Code Make/Model Distance Print This Page Results Approx Distance: 24 miles Pick-n-Pull - Lynnwood [More Information] 18306 Highway 99 Lynnwood, WA 98037 US 425-778-3147 Store Layout Map | Part Pricing Make Model Year Row Date On Yard Volvo 240 89 0041 10/06/2014 Volvo 240 81 0043 10/07/2014 Pick-n-Pull - Tumwater [More Information] 8010 Old Highway 99 SE Tumwater, WA 98501 US 360-357-4466 Store Layout Map | Part Pricing NOTE: This store was recently acquired by Pick-n-Pull and its inventory transferred to our Tracker system. As a result, some dates below may indicate when a vehicle was entered in the system instead of the date it arrived at the yard. Make Model Year Row Date On Yard Volvo 240 90 0039 07/25/2014 Volvo 240 85 0017 08/19/2014 Volvo 240 84 0021 09/10/2014 Volvo 240 84 0021 09/10/2014 Approx Distance: 47 miles Pick-n-Pull - Arlington [More Information] 6323 172nd Street NE Arlington, WA 98223 US 360-403-9505 Store Layout Map | Part Pricing Make Model Year Row Date On Yard Volvo 240 91 0006 09/03/2014 Volvo 240 85 0002 08/21/2014 Volvo 240 83 0017 05/16/2014 09.44: Pick-n-Pull - Kelowna [More Information] 1516 Stevens Road Kelowna, BC V1Z 1G2 CA 250-769-9377 Store Layout Map | Part Pricing Make Model Year Row Date On Yard Volvo 240 93 0068 09/26/2014 Volvo 240 86 0069 10/09/2014 Volvo 240 84 0052 07/17/2014 maybe
In stock and shock mounts too just for this.
Xratty-boy Matt just right down the road nearly certainly can do the thing--he accepts payment in beer. Drilling the holes is not too rough with a Bridgeport---you crank the head way out so you can hang the axle over the edge of the bed and secure axle with a V block and normal clamps.. DRO and I have the X and Y to make it soooooooper easy
Yep--weld yoke for $18 at diff end and a weld yoke for 1310 at the other for another $18. V blocks, goood chamfer, tack in 3-4 spots and weld. DROP IN GEARSETS..should be self explanatory..
It CAN but yeah--everywhere but Turdboatpricks its more work
They really work good with the nice big Volvo rear calipers.
I dunno, I've done it, park in 1st gear, wheels cut to curb correctly. Never had one roll away---done a number for other guys in years past and they parked them on hills too, no problems..
Yep..just delayed gratification a bit...delayed gratification builds work ethic, makes America strong.. Dun't know what it does for Canajians tho
Yep looks like a big deal but gawddam this kid do a whole cage and did it good, zotting on a few tabs and a propshaft is nuthing compared to that... DOOOOOOOO IT. And just think---drop out center section...aaaahhhh so easy... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 10/11/2014 12:23PM by john vanlandingham. |
Which 4.88? If Dana 30 the break pint is in the 3.30 sumpin range I think so non-issue. If Toiletta he's 'spossed to dig for the right one and get either the 4.67 OR the 4.88 and leave the fawkin thing alone for now. I wonder if I call Matt, the Xrattie guy I can convince him to go 'splain to him he's being silly and smack Eric with a mackrel? Something like this.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
well, shit. You guys are awesome. Fine ill try the toyletta thing.
I wonder if there is a way to make the stock volvo handbrake work on the toyota thing? Because I don't need a hydro one. I think there stupid for the most part and never use one other than to park the damn thing. Don't judge me on the daily driven rally car! Well ok judge all you want but im still doing it... im 20, insuring two cars is not an option. |
The factory 4.88 from toyota. They had thinner ring gears.
The volvo e brakes are internal drums, so you would need to mount the backing plate and use the rotors also. When picking your calipers, find something with a integrated e brake, the GM metric ones use pretty much the most supported pad out there. And if you want to ditch the mechanical hand brake someday, you can swap on any of the tons of metric calipers out there. The e brake ones I'm talking about came 1979-1985 Cadillac Seville. Other then that, there are mustang ones like Gene said, and probably a whole list of them, it's just going to take some time at the junkyard. Just make sure you find something with aftermarket support. I'm kicking myself for that mistake right now. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
