http://www.afcoracing.com/tech_pages/4link.shtml
It's really good info , we ought to cut and paste the whole thing here and 'stickify" it if i knew how to make it sticky. Oh OK This article explains the workings of the 4-link suspension and the tuning methods used to maximize its performance under various track conditions. This information applies only to 4-link rear suspensions having links floated on the rear axle (via birdcages) with all links running forward. The 4-Link Difference Upper Links Lower Links Indexing AFCO Springrod AFCO Clamp Brackets The popularity of the 4-link suspension is due primarily to its ability to let the race car turn freely in the middle of the corner without compromising forward bite. To understand how a 4-link can be made to provide such handling, you must first understand a few basics about rear suspensions. Realize that you can increase forward bite on any type of rear suspension by angling the trailing arms upward toward the front of the race car. Trailing arms mounted in this manner cause the rear tires to try to drive underneath the chassis as the rear axle pushes the race car forward (See illustration 1). As a result, the loading of the rear tires (during acceleration) is quickened and forward bite is enhanced. Illustration 1. There can be a handling trade-off, however, to the forward traction gained by running the trailing arms upward to the front of the race car. During chassis roll, trailing arm/s mounted upwards will cause the right rear tire to move rearward (until the arm/s reach a level position) and the left rear tire to move forward. The condition is referred to as "loose roll steer". (See illustration 2A.) Loose roll steer causes the rear axle to steer towards the outside of the race track. If excessive, loose roll steer can cause a loose handling condition that negates the benefits of the forward bite gained by running the trailing arms upward towards the front. However, the right amount of loose roll steer can help a race car to turn the corner correctly. At best, any trailing arm arrangement is a compromise between forward bite and roll steer. The 4-Link Difference A well designed 4-link provides good forward bite and the proper amount of roll steer. The two most critical factors to the performance of a 4 link suspension are the link lengths designed into the suspension and the angles to which the links are adjusted. The key to correctly designing and tuning a 4 link is to understand the significance of these two factors. Upper Links We stated earlier that trailing arms mounted upwards to the front of the race car enhance forward bite by using axle thrust to quicken the loading of the rear tires. We use the upper links on a 4-link suspension to enhance the forward bite. Upper link angles from 15º to 18º on the right and 10º to 15º on the left provide good forward bite. A good starting point for both links is 15º upwards (to the front). However, keep in mind that chassis roll causes the link angles to change. If the link angles become more upward on the left than on the right, the left rear tire can become loaded more quickly than the right during acceleration (due to the axle thrust effect). This condition may cause a gas pedal push. One fix is to position the links so that the right side link is from 3º to 5º higher than the left when the chassis is at ride height. Be aware that trailing arms angled uphill too steeply can hold the chassis up during acceleration which can reduce the effectiveness of the shocks and springs. This condition will cause loose handling-especially on rough race tracks. Keep in mind that trailing arm angles can become excessive if the rear of the chassis lifts a lot during acceleration. The length of the upper links should be at least 17" . We can reduce loose roll steer by making the lower links shorter than the upper links (more on this later). If the upper links are shorter than 17", the lower links have to be extremely short to minimize loose roll steer. But extremely short links change their angles radically whenever the suspension moves. When the rear links are too short forward bite and roll steer are overly affected and handling becomes inconsistent. Lower Links We can use the lower links of a 4-link suspension to help offset the loose roll steer tendency caused by the steep angles of the upper links. The following examples and illustrations should help you to understand this important function of the lower links. You should pay close attention to how the lower link adjustments change the paths traveled by the bottom of the birdcages during chassis roll. Keep in mind that any change to the path traveled by any trailing arm will affect roll steer. For example, in illustration 2A, both the top and the bottom links move the birdcages (and the rear tires) rearward on the right side and forward on the left side during chassis roll. This action will cause loose roll steer. We can reduce loose roll steer by lowering the bottom links at the chassis. You can see how this adjustment works in illustration 2B. We've lowered the bottom links to a level position and now the bottom of the right side birdcage moves forward during chassis roll instead of rearward as in illustration 2A. On the left, we have reduced the forward movement of the bottom of the birdcage. As a result, loose roll steer is reduced. Basically, we've position the bottom links to counteract the forward(L.S.) and rearward (R.S.) movements of the birdcages caused by the upper links. As a result, we reduced loose roll steer. We can reduce loose roll steer further by lowering the bottom links further as shown in illustration 2C. Notice how this adjustment, positioning the lower links 5ºdownhill, causes the bottom of the right side birdcage to move forward more during chassis roll than in illustration 2B where the links are level. On the left side, the bottom of the birdcage now moves rearward (until the link reaches a level position) instead of forward as in illustrations 2A and 2B. Consequently, a further reduction in loose roll steer results. Generally, bottom link angles from 0º to 5º downhill (to the front) are used to help control loose steer. Some forward bite may be lost when the bottom links are lowered but the effect on forward bite is usually minor relative to the overall handling improvement that is realized by reducing loose roll steer. Another method used to reduce the loose roll steer of a 4-link suspension is to shorten the bottom links. Notice, in illustration 2D, how the shortened bottom link pulls the bottom of the right side birdcage forward during chassis roll more than the longer links in the other illustrations. The bottom of the left side birdcage does lose some of its rearward movement because of the shortened bottom link. But since left side birdcages typically move down much less than right side birdcages move up during chassis roll, the overall effect, when shortening the lower links, is a reduction in loose roll steer. However, if the left rear of your chassis hikes up during cornering, loose roll steer may increase whenever both bottom links are shortened! We could reduce loose roll steer even further by combining the long bottom link arrangement of illustration 2C on the left side and the short bottom link arrangement of illustration 2D on the right side. The preceding paragraphs should help you understand why. The length of the bottom links are dependent on the roll steer and traction characteristics desired by the chassis tuner. For most track conditions, bottom links 2æ shorter than the upper links work well. Short links( from 3æ to 4æ shorter than the upper links) generally work best for tight, flat race tracks or on any track where the chassis tends to be loose. Long bottom links (equal in length or no more than 1æ shorter than the upper links) work best for fast tracks or on any track where the chassis tends to push. You should use the information in this article to determine the correct link lengths for your application. However, a proven 4-link arrangement includes 15 1/2æ bottom links, mounted 5º downwards to the front, coupled with 17 1/2æ top links, mounted 15º upwards to the front. Indexing A 4-link birdcage rotates or "indexes" on the axle tube whenever the suspension moves (unless both upper and lower links are equal in length and parallel to each other). Indexing is greatest when there is a lot of length and/or angle difference in the upper and lower links. Typically, indexing causes the coil-over mounts, if located on the front of the birdcages, to rotate against the shocks and springs during suspension bump (compression) movement. As a result, the springs and shocks are compressed from both ends at once and the suspension becomes very stiff. (Try to bounce the rear of a car with a 4-link rear suspension). During chassis roll, indexing loads the right rear tire and unloads the left rear tire and wedge is reduced (40 lbs to 80 lbs is typical!). Indexing can improve driveability by keeping the race car flat in the corners. However, indexing can cause the rear suspension to be too harsh on rough race tracks. When selecting springs for your 4-link, you should keep in mind the effect that indexing has on suspension stiffness. AFCO Springrod The AFCO Springrod (see the AFCO Catalog) is used to replace the right side upper link when tighter handling during acceleration is desired. The operation of the springrod is simple. During acceleration the springrod compresses and allows the right rear tire to move forward. This movement steers the rear axle to the inside of the track and tightens the race car. When the springrod compresses it causes the birdcage to rotate away from the right rear spring (if the coil-over unit is mounted ahead of the axle). As a result, the right rear tire loses some of its load (the left rear tire gains load) during acceleration and handling becomes tighter off the corner. The AFCO Springrod can provide a significant handling improvement. AFCO Clamp Brackets AFCO Clamp Brackets (see AFCO Catalog) are used to mount the coil-over units directly to the axle housing. When clamp brackets are used in front of the axle, axle wrap-up during acceleration causes the rear axle & chassis to separate. The rear axle (and tire) are forced towards the race track. Clamp brackets are sometimes used on short, slick tracks to improve initial forward bite. Mounting the left coil-over unit ahead of the axle (on a clamp bracket) generally tightens corner handling. Mounting both coil-over units on clamp brackets and ahead of the axle can improve forward bite on stop and go or slick race tracks. On extremely slick race tracks, you can tighten overall corner handling by using clamp brackets to mount the left coil-over unit ahead of the axle and the right coil-over unit behind the axle. Suspension movement usually increases when the coil-over units are taken off birdcages and mounted to clamp brackets (since there's no longer any indexing of the springs). Consequently, it may be necessary to increase rear spring rate when making this adjustment. You should keep in mind that any loading of the rear tires caused by clamp brackets during acceleration will be accompanied by an unloading of the rear tires during deceleration This unloading can upset the race car upon corner entry -especially when both coil-over units are positioned ahead of the axle and attached to clamp brackets. You may be required to make chassis adjustments to correct any corner entry handling problems caused by clamp brackets. Final Points The 4-link is a relatively complex rear suspension that is very sensitive to adjustments. A link length change of 1" or a link angle change of 5º can make a noticeable change to handling. When designing or tuning a 4-link, it is important to understand the relationship between link lengths and angles and how the relationship affects roll steer and tire loadings. We highly recommend that you build a full-scale working model of your 4-link, or use the design parameters mentioned in this article, to help you to better understand the 4-link suspension. You can use cardboard, wood, aluminum strips, etc. The idea is to trace the paths actually traveled by the centers of the birdcages during chassis roll. You should draw the paths to include at least 3" of rebound movement for the left birdcage path and at least 3" of compression movement for the right birdcage path. You can evaluate the roll steer characteristics of different set-ups by comparing the different paths drawn on your model. You can also check the indexing and the link angle changes during roll or bump. In short you will speed up your learning process by working with a model. As we stated earlier, the 4-link is a fairly complicated rear suspension. We hope the information in this article, combined with your efforts, will provide you with an AFCO advantage! Tuning Tips • Increasing the upward angle (to the front) of any link will enhance forward bite and increase loose roll steer. • Decreasing the upward angle (to the front) of any link will decrease forward bite and reduce loose roll steer. • Suggested angle adjustment parameters: • Upper Links: 12º to 20º (upward) RS 10º to 18º (upward) LS • Lower Links: -5º to +5º • You may need to reduce link angles when using clamp bracket/s and/or when running on rough race tracks. • You may need stiffer rear shocks when using clamp brackets (to control wheel hop). • Angling the links inboard (at the front) tends to increase loose roll steer. • You can correct roll steer handling problems by leading or trailing the right rear tire (or left rear). • Shortened bottom links (especially R.S.) tend to reduce loose roll steer. Claro??? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
hudson Wrote:
------------------------------------------------------- > john vanlandingham Wrote: > -------------------------------------------------- > ----- > > Claro??? > > This article is for circle track aka turn left > turn left hit wall cars? > > Andrew McNally > Hamilton ON > 28 There is info applicable to 4 links IN GENERAL John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
------------------------------------------------------- > There is info applicable to 4 links IN GENERAL I agree, but from the bit I read, which I learned something super key ie upwward sloping arms.. that makes complete sense once you think about it. I seriously hadn't and yes it makes total sense. Previously I thought that rally cars had the Shell mounted four links high purely for ground clearance. I hadn't thought that the axles inertia could help lift up the rear and put weight on the front tires! Would that not be negated by any braking? But what's this talk about left and right bird cages? That has to be about turning one way and not the other. Andrew M Onterrible 30ish |
alkun Wrote:
------------------------------------------------------- > yo hudson dude, at 200mph, or on dirt with 700hp, > you bet those "left turn" good ol boys spend some > thought on making the suspension work through > turns... > > thanks for the info John. Yo Al dude, I have family who did the circle thing and have friends that still do. I've spent many a night in the pits of the local track. I wasn't trying to be disparaging of that kind of racing at all. In fact, some of the best racing I've seen has been at the local track. I was just wondering about this left and right bird cage talk. That sounds like making it turn better one way rather than the other.. but maybe I'm stupid and there's something to do with the torque of the motor that skews it to one side rather than the other. (I admit I didn't read all the way though yet). Andrew M Onterrible 30ish |
Tim Taylor Tim Taylor Professional Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Midlife Crisis Posts: 622 Rally Car: Mazda 323 GTX |
Why the hell would you want to use the "bird cage" mounts? There is no way I'm letting you out those pivoting mounts on your axle Al. How about we corner weight your car, find the CG, and then build a standard 4 or 5 link that has somewhere between 15% and 20% anti-squat. With a little more work it could even be a 4-link with roll understeer.
Tim |
c'mon Tim, when we are done the car is going to have a virtual roll center 3 feet underground, it will be cool! No, John just sent me this stuff to read while I'm on the crapper. I alreaddy question my own sanity for cutting up the stock stuff and putting in the turrets.
Hudson, sory for duding you. No one likes to be duded. As above John just sent me this stuff for hahas, but it is great information for anyone into cars. -Al |
TerribleOne Vince McAllister Super Moderator Location: Mangohick Va. Join Date: 08/11/2007 Age: Midlife Crisis Posts: 71 Rally Car: 89 Volvo 244tic |
Damn.. Now I'm never gonna get any work done today.. weblinks are the devil!
Stroker 2.5 redblock, JE forged blower pistons 8.2:1, Eagle H beams with DSM big end, Avalanche underdrive pulley, 46/40mm valve 530 with Enem C2 turbo cam, Isky db springs, SDS efi w/DIS/wasted spark, PCS digital touch screen dash/logger, 60lb Deka IV's, ATP 60-1 @ 22psi, Tial bov, Walbro 255, Avalanche T-5 adapter, 02 Tremec 5sp, 6puck, 3" driveshaft, modded G80, Painless chassis harness. Corbeau seats.. 300+whp Driven daily.. |
TerribleOne Wrote:
------------------------------------------------------- > Damn.. Now I'm never gonna get any work done > today.. weblinks are the devil! > Come on you're all hung over from your Birfday Partay anysways..... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
hudson Wrote:
------------------------------------------------------- > I was just wondering about this left and right > bird cage talk. That sounds like making it turn > better one way rather than the other.. but maybe > I'm stupid and there's something to do with the > torque of the motor that skews it to one side > rather than the other. (I admit I didn't read all > the way though yet). This part is about left handed turns: • Upper Links: 12º to 20º (upward) RS 10º to 18º (upward) LS You wouldn't want to see the links at different angles left to right for a rally car. The rest of the discussion applies. I read this and a couple of other articles and concluded that for starters, I'm gonna keep the lower links close to level, and start with the upper links there too. The upper link forward connections will have varible points to change the angle. Angled links have me concerned over roll steer. The old leaf spring rear axles of the Colts/Arrows had a lot of 'twitchiness', part of which I've concluded is due to the roll steer inherent in that suspension setup. On a circle track, the roll steer encountered is pretty constant from lap to lap and week to week. So compromising the roll steer with angled links to get bite is sensible. But in rally, with a rough stage road (like in MI, ME, ON, and other places), I would like to get rid of as much roll steer as I can, 'specially if the car is short. But, I have yet to get this thing going and have no experience in tuning the angles. So any expereinced users' comment would be approacted. Thanks for bring this up! Mark B. |
starion887 Wrote:
------------------------------------------------------- > > > But, I have yet to get this thing going and have > no experience in tuning the angles. So any > expereinced users' comment would be approacted. > > Thanks for bring this up! > Mark B.\ But Mark, isn't it fun to actually have the choice of being able TO TRY something out after all these years of fixed junk? Tim Taylor has said he can do some sketches to show "applied" stuff so us visual guys can see better in a CAR rather than some water-bug F1 chassi. > > John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
starion887 Wrote:
------------------------------------------------------- > This part is about left handed turns: > • Upper Links: 12º to 20º (upward) RS 10º to 18º > (upward) LS > You wouldn't want to see the links at different > angles left to right for a rally car. The rest of > the discussion applies. For sure. > I read this and a couple of other articles and > concluded that for starters, I'm gonna keep the > lower links close to level, and start with the > upper links there too. The upper link forward > connections will have varible points to change the > angle. > > Angled links have me concerned over roll steer. > The old leaf spring rear axles of the Colts/Arrows > had a lot of 'twitchiness', part of which I've > concluded is due to the roll steer inherent in > that suspension setup. On a circle track, the roll > steer encountered is pretty constant from lap to > lap and week to week. So compromising the roll > steer with angled links to get bite is sensible. > But in rally, with a rough stage road (like in MI, > ME, ON, and other places), I would like to get rid > of as much roll steer as I can, 'specially if the > car is short. > > But, I have yet to get this thing going and have > no experience in tuning the angles. So any > expereinced users' comment would be approacted. I don't know if I 100% understand roll steer.. is that the the suspension geometry causing the vehicle to steer as the body rolls? Could that also apply to when you're in a pickup truck going straight and find your ass end 6 inches to the left(or right) after a bump? Is that due to the leaf springs, the frame flexing, or? Andrew M Onterrible 30ish |
hudson Wrote:
------------------------------------------------------- > > I don't know if I 100% understand roll steer.. is > that the the suspension geometry causing the > vehicle to steer as the body rolls? It's easy to visualize for a solid rear axle, and is the same phenomenon whether the vehicle leans (rolls) in a corner or one wheel ends up lower or higher than the other due to road bumps. In a solid rear axle, it happens when the wheels on either 'axle' (front or rear) move forward or rearward relative to one another, and the alignment of the axle is no longer perpendicular to the vehicle's main axis. This causes the rear axle to steer to one side or another; if the axle angles toward the outside in a corner this causes 'roll oversteer', and roll understeer results if the axle points towards the inside. Imagine a solid rear axle held to the car with two short links running back from an attachment point to the car body forward of the axle. (This is like the front half of a standard leaf spring suspension.) Futher imagine that the links are angled downward from the attachment point to the axle at normal ride height. If one wheel drops down further than the other (due to a bump or a roll in a corner), then it will be pulled further forward than the wheel at the other end of the axle, due to the larger angular swing of the link on that side. This misaligns the rear axle relative to the main axis of the car, and the rear is 'steered'. See illustration 2A in the posted article. You can have similar roll steer effects on all sorts of suspensions; the actual steering mechanism will vary, but the idea is the same; wheels/axles misalign with their normal straight-ahead postion as the body rolls or the wheels move up or down . On a desert truck very long rear axle links are used combat this with their very severe susension travel; the long links reduce the swing angle changes, and thus reduce the fore/aft wheel motion and the resulting axle misalignment. > > Could that also apply to when you're in a pickup > truck going straight and find your ass end 6 > inches to the left(or right) after a bump? Is > that due to the leaf springs, the frame flexing, > or? More likely this is due to inherently overly stiff rear suspension, that acutally leaves the road surface on a bump for a moment. The traction is lost and the truck's rear moves in the direction away from the forces acting on it when the traction is broken (like swinging out on a corner). Stock truck suspensions have to be a compromise on handling in order to carry loads. Regards, Mark B. Edited 1 time(s). Last edit at 04/05/2008 11:43AM by starion887. |
