Hey Mark. I won't repeat what I said on specialstage, but I will post this picture.
There is a thread where I gave all the parts I used for mine. Yours should be similar.
If you're going with the remote filter, then definitely find the RX7 oil cooler with the built in thermostat. Get some AN-10 adapters to go into it. Get the Permacool 4 way remote oil filter kit and Permacool adapter plate off the block. 2 - 3/8 NPT to AN-10 and 2 - 1/2 NPT to AN-10 adapters. You'll have two spare holes on the remote filter that can be used for temp senders or whatever, or to supply oil to something else, like a turbo.
I used Setrab because they were cheap used on ebay. I wish I'd gone with the RX7 with the thermostat though. I thought I'd be crafty and use a remote thermostat, but don't really have anywhere to put it or want to deal with the extra lines to use it. But I probably will end up needing to in order to get the engine oil temperatures up.
open |
download -
(85.7 KB)
