Engine pulling and Camshaft spec
Posted by Morten
sagsert
Mustafa Samli
Gaylant VR4
Re: Engine pulling and Camshaft spec
February 21, 2006 03:52PM
Duuuude,
You are turning in to a chicken farmer worrying about ducks though.
Relax, it wil all be groooooooooovy.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
Morten
Morten
1974 Dodge Colt
February 22, 2006 12:44AM
We're pulling the motor/engine out... After starting on the front cover, it seemed just as easy to take the motor/engine out and bolt it to a stand. Everythings stripped off the long block and tomorrow we just have to pull the bolts off the bell housing, and she should slip out.
This may not be the simplest route, but I am learning a shitload and building confidence at the same time !
What do you call that bolt with the funky star like head that bolts the head to the cover housing ?
sagsert
Mustafa Samli
Gaylant VR4
February 22, 2006 09:20AM
Some call it George, some call iy Betty, some call it Bolt With Funky Starlike Head.
Don't make me take the pictures myself !! Post the pictures.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
February 22, 2006 11:05AM
> pictures.
> Cheers
> M.Samli
> Phoenix AZ
> Gaylant VR4
> EVO II GSR
> STC Mouthpiece
> Instigator Extraordinaire
> Avatars are like underwear, change them daily.
Yeah I'm the one that calls things "the fuckin thing" cause I know what I mean.
you guy have to call things by the correct names of we can help you.
or post piccies
Morten
Morten
1974 Dodge Colt
February 22, 2006 11:09AM
Not really much to show yet...
The coolant looks a little "off", where can I buy the "fucking thing, George, Betty, or whatever"... is it a common automotive item ?
open | download - valve_cover_belts.jpg (87 KB)
open | download - long_block.jpg (89.2 KB)
open | download - coolant.jpg (51.2 KB)
February 22, 2006 12:21PM
12 point metric? Some of the things I'm familar with that are similar to what you refer to are simply metric and use a 12 point socket to remove. Kind of looks like an inverted torque head bolt? (or is it torx?) Anyhow, as a woodworker you should know what I mean.
Morten
Morten
1974 Dodge Colt
February 22, 2006 12:46PM
It looks like this :
open | download - starlike.jpg (39.5 KB)
Rich Smith
Rich Smith
February 22, 2006 01:42PM
Morten,
Just describe the star-head bolt to the guy at your local autoparts store (or print your photo and take it in). He'll recognize it and sell you a proper wrench to use with your 3/8" ratchet.
But don't reinstall it. Replace it with a bolt that has a conventional head.
Rich Smith
February 22, 2006 01:50PM
Holy shit Morten. That's a torques head I believe. Not even an inverted one. They are used mostly as a better quality wood screw as they don't strip. I would have thought that you'd have recognized it. smiling smiley
Morten
Morten
1974 Dodge Colt
February 22, 2006 02:10PM
Thanks Rich !
Morten
Morten
1974 Dodge Colt
February 22, 2006 02:13PM
Thanks Grant... I've never come across one before.
But what I've found on the net is that it's refered to as a "6 lobe or a torx".
February 22, 2006 03:12PM
During my short stint as a professional skateboard ramp builder, I used exclusively torx screws. They don't ever strip can suck in easier. A bit more expensive, but I was never paying for them. Of course, I only did two projects, one set of ramps for a nationwide skateboard/punk rock tour and a skateboard park in Wyoming. Here's me at the one in Wyoming.
open | download - stale.jpg (77.9 KB)
sagsert
Mustafa Samli
Gaylant VR4
February 22, 2006 05:00PM
It is a TORX.
TORX bits are readily available at your friendly tool stores such as SEARS or HARBOR FREIGHT.
Get a set, they are cheapish.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
PAddy
Patrick McVeigh
Student Loans
February 22, 2006 05:18PM
Ummmmmm, what colour was the coolant when you put it in the engine?
Parry
Dave Maxwell
February 22, 2006 09:32PM
A few things.
yes, they will strip in a heartbeat if you let them
and
get a good set of torx tools or you are just going to snap them (the tools) all day long.
Before I remove them, I use a pick to clean out the head and tap in the tightest fitting torx tool I can. Give it a few good whacks to make sure it is seated in all the way and break them free.
