Master Cylinder Size - Help
Posted by wvonkessler
July 03, 2008 12:10AM
Looking to upgrade the E30 Bimmers to Wilwood Dynalite 4 pistons and 11 inch rotors from a VW Corrado. Also looking to install bias pedal boxes, and hydraulic handbrakes.
Any suggestions on the proper MC sizes for the bias pedal box? I assume 5/8 is right for the handbrake.
TIA.
Wilson
Re: Master Cylinder Size - Help
July 03, 2008 01:05AM
If you can tell me the bore size and rotor diameter front and rear I can calculate it for you. It will most likely end up with 0.75" bore on both master cylinders but that depends on the caliper bore you choose for the Dynalites. What's the rotor width? I have one extra caliper for 1" wide rotors that I bought while doing research. You can have for less than wholesale since I can't return it and I'm not using it.
Tim
July 03, 2008 09:30AM
Tim:
Fronts:
Wilwood Dynalite 4 pots
Disk Diameter: 280mm
Disk Width: 22mm
Bore Size: 1.38"
Rears:
ATE single pot
Disk Diameter: 258mm
Disk Width: 10mm
Bore Size: 33mm
Thanks,
Wilson
July 03, 2008 05:49PM
wvonkessler Wrote:
> Tim:
> Fronts:
> Disk Width: 22mm
> Bore Size: 1.38"
> Rears:
> ATE single pot
> Disk Width: 10mm
> Bore Size: 33mm
> Thanks,
> Wilson
> My opinions are my own and are not to be construed
> as representing the viewpoint of any other person
> or organization. How's that for legalese?
Okay, I assumed quite a few things but this will get you really close. The following chart has your current calipers using a standard Tilton dual master cylinder/balance bar setup. The balance bar is centered in all cases. The rear MC is 0.75" in all cases and the front changes from 0.625"-1.125" in 1/8" increments. Sorry but the program doesn't print out nice sheets and it crops the field so even a screen capture isn't really clear.
In order of preference I would choose a 0.75" rear MC and a 0.875" front followed closely by equal 0.75" for both. If you want to go deeper into this we have to measure a bunch of stuff. Is this going to work for you?
Tim
EDIT:
Here is another run that shows the bias bar range for both the 0.75 and 0.875 front MC:
Edited 4 time(s). Last edit at 07/03/2008 09:12PM by Tim Taylor.
What about the Hydraulic Handbrake
July 05, 2008 09:48AM
Tim:
Thanks.
Any clue as to whether the hydraulic handbrake should run 5/8 or 3/4?
Wilson
Re: What about the Hydraulic Handbrake
July 05, 2008 12:30PM
wvonkessler Wrote:
> Tim:
> Thanks.
> Wilson
Not a problem I'm happy to help.
They're usually 5/8 but depending on the length of the handle either one can be made to work. I thought a little more on the MC sizes too. Since you do tarmac rallies you might do better to try the 3/4 front master cylinder first. It will give you a better chance of being in the adjustment range of the bias bar between gravel and tarmac.
Tim
