Ascona73 Bob Legere Mod Moderator Location: Spofford, NH Join Date: 03/07/2007 Age: Possibly Wise Posts: 308 Rally Car: 1971 Opel Ascona |
Doivi Clarkinen Wrote:
------------------------------------------------------- > I thought about how cool it would be to build a > mid engined turbo Omni long ago but then figured > that would be too much work when it really > wouldn't be any faster than a turbo FWD Omni... But at least the gravel would be spewing from the correct end of the car! Worth it IMO... Bob Opel is a 4-letter word... http://www.flickr.com/photos/10498579@N07/sets/ |
jameseshepherd Jim Shepherd Mod Moderator Location: A few hours north of Seattle in the state of confusion Join Date: 10/20/2008 Age: Ancient Posts: 27 Rally Car: 2001 Toyota Celica GT-S |
Phlyan Pan Travis Sleight Ultra Moderator Location: Saratoga Springs, NY Join Date: 12/16/2006 Age: Midlife Crisis Posts: 45 Rally Car: Moved on....wasn't much of a rally car anyway |
I haven't read the rulebooks in a while, but is there any rule that a car has to have only 1 engine?
How about a civic with a 900RR engine at each corner? You could do crazy things with weight distribution. Pretty lightweight I would think, N/A so no restrictor(s), Good horsepower (those things make like 100+ a piece right?), sequential shifting, no diffs to break, if you break something in 1, you got 3 more to drive home on. How 'bout it? "Time to unpimp ze auuto." sleightc (A.T.) Yahoo {DOT} com |
Phlyan Pan Wrote:
------------------------------------------------------- > I haven't read the rulebooks in a while, but is > there any rule that a car has to have only 1 > engine? That'd be one hell of a loophole. "Sure, the engine under the hood is a 1.8l 8 valve engine. It's not the one actually powering the car, though." Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
acrane adam crane Junior Moderator Location: Seattle, WA Join Date: 01/28/2006 Posts: 382 Rally Car: corolla GT-yes |
motor cycle engines are stupid,
but after reading the rules again, mike hursts' mustang is now in group 2. so is a NA rx7, so is 3.5L nissan in a 240sx so is a 3.2L v6 in a volvo (ditch the turbo john Lane) Welcome to a new "super power" era in rallying. your 1.6L is worthless here. begin shitting bricks. - STOP SHITTING BRICKS - your right andrew. 3. Replace the following definitions in Article 1.9 with the following: Group 2 Two-wheel drive cars with normally aspirated, small displacement engines with Open class style modifications allowed. [STRIKE]Adjusted displacement is limited to 2400cc.[/STRIKE] Refer to Article 10.2.B.9. "I put the hurt on dirt" - adam crane http://CraneRallyCrew.com corolla gt-s "Patches" Op: S.S. Edited 2 time(s). Last edit at 11/11/2008 07:18PM by acrane. |
acrane Wrote:
------------------------------------------------------- > mike hursts' mustang is now in group 2. How are you getting this? In the RA rule book the 10.2.B.9.b still contains the GpF style displacement to weight chart. The Mustang exceeds the maximum displacement of 3,080cc So 1.6L cars can still have an advantage because of the lower weight they are able to run. I still don't know if a motorcycle engine is the way to go but all is not lost for small displacement cars. Edited 1 time(s). Last edit at 11/11/2008 04:02PM by Andrew_Frick. |
Lurch Eric Burmeister Elite Moderator Location: Michigan Join Date: 02/14/2006 Age: Possibly Wise Posts: 307 Rally Car: Mazdaspeed3 and Mazda Protege |
Tom, keep building.
Like Doivi says, someone's gotta drive it, and even more important, someone's gotta build it and make it finishable. Ask NatuRally about their build. Or me about mine. It takes time to develop a car from scratch even when you have the engine in the same spot. You can drive your ass off. Getteth thee a quick, reliable, light rally car and let the beatings commence. Lurch Eric Burmeister The west coast...of Michigan |
mellow65 Oliver Klozoff Ultra Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
acrane Wrote:
------------------------------------------------------- > motor cycle engines are stupid, > but after reading the rules again, > mike hursts' mustang is now in group 2. > > so is a NA rx7, > so is 3.5L nissan in a 240sx > so is a 3.2L v6 in a volvo (ditch the turbo john > Lane) > > Welcome to a new "super power" era in rallying. > your 1.6L is worthless here. > > begin shitting bricks. - STOP SHITTING BRICKS - > your right andrew. > > 3. Replace the following definitions in Article > 1.9 with the following: > Group 2 > Two-wheel drive cars with normally aspirated, > small displacement engines with > Open class style modifications allowed. Adjusted > displacement is limited to > 2400cc. Refer to Article 10.2.B.9. > > "I put the hurt on dirt" > adam crane > corolla gts > Op: S.S. > > > > Edited 2 times. Last edit at Nov 11, 2008 by > acrane. you were reading it the same way i was, it sounded like they lifted the size limit for G2, in reality they were just removing the 2400cc sentence because it contradicted the new size of 3,080. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Yes there is still the 3000cc limit on G2, yes you can put the engine in the glove box....and if you can prove the thinnest of connections for engine parentage you should be fine.
Open class for G2/G2 is now pretty much a reality. The new Open Light class is also pretty exciting. Now let me assure you if a car comes in with flakey construction it will not get a logbook. Go ahead make a mid engine Bunny or Golf, just make sure the work is sound. |
Tom B Tom B Godlike Moderator Location: Douche Canoe, WA Join Date: 02/27/2006 Age: Midlife Crisis Posts: 780 Rally Car: VW Golf |
Free the ties to the manufacturer and I will stop rallying for a year (or two) to build an incredibly well built monster....seriously, what is the point of keeping within the make now?
In the mean time I will be tidying up our beast to start a Cody v. Burress v. Lane local 2wd war at Doo Wops. -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
Tom B Wrote:
------------------------------------------------------- > Free the ties to the manufacturer and I will stop > rallying for a year (or two) to build an > incredibly well built monster....seriously, what > is the point of keeping within the make now? > > In the mean time I will be tidying up our beast to > start a Cody v. Burress v. Lane local 2wd war at > Doo Wops. > > __________________________________________________ > _________ > Fine Tuning | DemonRally > > "If everything seems under control, you're just > not going fast enough." -- Mario Andretti > > Really there is no point to my thinking. I talked with Hurst about this a few times. I still will work on it. He did mention once (I think) that if the parentage rule were dropped it would be on a regional only basis. Hey we're making progress though ! |
Tom B Wrote:
------------------------------------------------------- > In the mean time I will be tidying up our beast to > start a Hughes v. Lane local 2wd war at > Doo Wops. Fixed that for you. Hey a guy has to have hallucinations right. I mean aspirations. Though I was probably closer at first. Grant Hughes |
I don't understand the parentage thing at all with the ability to put the motor where ever you want....Gene, you get it going at the regional level, and I will leave, sell pretty much everything I have and return in a bad way, stupid way....as long as I could compete nationally in the regional car I could care less where I am scoring points.
Grant, get the fuck out here and get going, there is some fun 2wd boys out here to get down with...plus Canada is right here, like ^^^^ come RACE. -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
