Eddie Fiorelli Wrote:
> Thanks.
> "There's a very small window of opportunity to get
> the rings to seal really well ... the first 20
> miles !!
> If the rings aren't forced against the walls soon
> enough, they'll use up the roughness before they
> fully seat. Once that happens there is no solution
> but to re hone the cylinders, install new rings
> and start over again."
> Perhaps its the use of two exclamation points,
> count them , two!! that is bringing me back to
> him.
That's why you want to bring the thing up to temp and a moderate load will do it sooner.
Same as you standing in the cold and twiddling your thumbs, you are doing something but it won't warm you up.
Jogging along will make you warn, tho.
There is something between no load 2000 rpm in neutral and beating the thing mercilessly.
(I once had a job rebuilding as in complete teardown of a 10,500 shp at 650 rpm V20 twin turbo 80 valve diesel. It had just be "rebuilt" a few weeks before but the guys spent 3 days working on the fuel oil heaters while the engine was idling.
Glazed the cylinders and when they put a load on it it smoked badly. About 5 rings per hole so 100 grooves to clean to perfection. Rod caps weighed 185 lbs each
Crazy shit but really same shit, just bigger.)
> Edited 2 times. Last edit at Nov 10, 2008 by Eddie
> Fiorelli.
Edited 1 time(s). Last edit at 11/11/2008 12:48AM by john vanlandingham.
