Put about 150 miles of dirt driving on it on Sunday. Mostly tight twisty and technical. Much, much better than an open diff that's for sure. Diff held up well. Gearbox did not but that's okay as I was planning to go to T5 anyhow. You have to stay on top of things especially when coming into a corner hot and downshifting as the rear will kick out, but you can use that to the advantage. The final drive still sucks though, as does the T9 gearing, and that was my biggest complaint. If there were a cheap ring and pinion available I'd be content running a low ratio welded Ford diff. But as it's not, I went and pulled a 4.3 ratio Supra LSD yesterday after work. Spotted a Supra that someone had lifted the ass on to pull the gas tank on Saturday. Went back yesterday after work with my cordless impact and had it out in very little time. Cage work starts in two weeks!
Grant Hughes |
PAddy Patrick McVeigh Mega Moderator Location: Toronto, ON Join Date: 12/21/2005 Age: Midlife Crisis Posts: 358 Rally Car: Student Loans |
Wello a really tight clutch plate diff, and by that I mean like breakaway torque like 175 ft/lbs or more will be similar.
Good you got a diff finally. It IS an 8" or properly a 200mm diff so that's confirmed now. More of the sheetmetal parts to do the chassi rail mounts are done and I just spoke with my man Sean about how we really have a drop dead date to get the square beams done by time Paddy comes so worry about the cage and there will be a way to mount the diff prettyu soon. I missed calling the Laser cut palce for the sump guard center support parts but thewy said they should be cut by tomorrow, then to get them welded up. I'm doing one for you Grant and for Paddy, Scott, Skye, me, and one more for the shelf or two for the shelf. So stand by soon for more panic calls for dough. Grant, do you have the front sumpguard mount/tow eye/jack points or didya sell them? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
mothra Matt Smith Ultra Moderator Location: Wilmington NC Join Date: 03/31/2006 Age: Possibly Wise Posts: 546 Rally Car: xr4ti |
PAddy Wrote:
------------------------------------------------------- > Was this testing done at that dirt track you have > the 'arrangement' with, or are there even MORE > good roads in Co? There are so so many good roads in Colorado. Problem is we have no organizers and not real friendly to the idea forest service managers. We were mostly in Pike National Forest on Sunday. Found a pretty fun road. Here's a Google Earth pic of a little bit of it. The whole road is around 30 miles of this type of terrain. Some big exposures, a few rough spots, some really smooth spots, and lots of elevation changes. Grant Hughes Edited 1 time(s). Last edit at 07/19/2006 09:52AM by NoCoast. |
Hot pink? You must have seen the wheels I posted on specialstage. I'll post them here too then. Ultimate chick drift mobile. JVAB hot pink brake hats, menstrual red US Brakes, and these wheels!
http://cgi.ebay.com/TEAM-DYNAMICS-15-MONZA-R-PINK-ALLOY-WHEELS-TYRES-NEW_W0QQitemZ290004415386QQihZ019QQcategoryZ9888QQssPageNameZWD1VQQrdZ1QQcmdZViewItem It'd be the shit. Someone get photoshop on that now! Grant Hughes |
------------------------------------------------------- > More of the sheetmetal parts to do the chassi rail > mounts are done and I just spoke with my man Sean > about how we really have a drop dead date to get > the square beams done by time Paddy comes so worry > about the cage and there will be a way to mount > the diff prettyu soon. > I missed calling the Laser cut palce for the sump > guard center support parts but thewy said they > should be cut by tomorrow, then to get them welded > up. > I'm doing one for you Grant and for Paddy, Scott, > Skye, me, and one more for the shelf or two for > the shelf. > > So stand by soon for more panic calls for dough. > > Grant, do you have the front sumpguard mount/tow > eye/jack points or didya sell them? I sold them but don't plan to replace them, at least not soon. I start school in a month so am going to be back to mostly poor college kid. Any estimate on what beam is going to cost? I'm likely in if I can afford it. Did you make up some of the alternator relocation brackets yet? I do need that. A 90 degree rotated upper would be best for the intercooler. And last but importantly, do you have any of the T5 tranny mounts and how much dough for them? The T9 is trashed after the last drive so have to upgrade it sooner than was planned. And how much for the chassis mount stuff? I'm on a tight budget and it's only going to get worse, so the more I can estimate now the more of these items I can actually get when the time comes. School and two jobs starting in the fall. Bleh. Grant Hughes |
------------------------------------------------------- > john vanlandingham Wrote: > -------------------------------------------------- > ----- > > More of the sheetmetal parts to do the chassi > rail > > mounts are done and I just spoke with my man > Sean > > about how we really have a drop dead date to > get > > the square beams done by time Paddy comes so > worry > > about the cage and there will be a way to > mount > > the diff prettyu soon. > > I missed calling the Laser cut palce for the > sump > > guard center support parts but thewy said > they > > should be cut by tomorrow, then to get them > welded > > up. > > I'm doing one for you Grant and for Paddy, > Scott, > > Skye, me, and one more for the shelf or two > for > > the shelf. > > > > So stand by soon for more panic calls for > dough. > > > > Grant, do you have the front sumpguard > mount/tow > > eye/jack points or didya sell them? > > I sold them but don't plan to replace them, at > least not soon. I start school in a month so am > going to be back to mostly poor college kid. > > Any estimate on what beam is going to cost? I'm > likely in if I can afford it. > > Did you make up some of the alternator relocation > brackets yet? I do need that. A 90 degree > rotated upper would be best for the intercooler. > > And last but importantly, do you have any of the > T5 tranny mounts and how much dough for them? The > T9 is trashed after the last drive so have to > upgrade it sooner than was planned. > > And how much for the chassis mount stuff? I'm on a > tight budget and it's only going to get worse, so > the more I can estimate now the more of these > items I can actually get when the time comes. > School and two jobs starting in the fall. Bleh. > > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO Hey numb nuts, just make convenient monthy payments. The beam design is, after a LONG evening on Moday, nailed down as is the revised diff mount. Should have the first one VERY soon. I will have an extra set of the skidplate mounts so just get them and don't snivel, you'll be a rich doctor one day!!! As for the center supports, they're PROMISED for tomorrow. Grant you want to weld up yours yourself and save$$$$??? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Sure. They'll be easier to box and ship probably like that anyhow.
Doctor? No way. I'll be the math nerd that tells the doctor that he can't take 17 people from the UP, feed them Lutfisk for a week, discover that none of them got the flu, so therefore, Lutfisk is a perfect natural vaccine for the flu. Okay. I really need to call you. Maybe I'll get a chance tonight. Grant Hughes |
------------------------------------------------------- > Sure. They'll be easier to box and ship probably > like that anyhow. > > Doctor? No way. I'll be the math nerd that tells > the doctor that he can't take 17 people from the > UP, feed them Lutfisk for a week, discover that > none of them got the flu, so therefore, Lutfisk is > a perfect natural vaccine for the flu. Only works with narrow genetic subtypes commonly called "Square-heads" and "Herring-Chokers". > > Okay. I really need to call you. Maybe I'll get > a chance tonight. OK. > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Carl S Carl Seidel Mod Moderator Location: Fe Mtn, MI Join Date: 02/10/2006 Age: Midlife Crisis Posts: 765 Rally Car: 1993 honderp |
