I just have a stock one right now, and its on its way out. It likes to slip whenever i try to tug someone out, and it was looking a little thin when I put the engine in.
So, whats the hot ticket? I was thinking a 6 puck sprung hub thing from some place. Yeah? Any brands to stay away from? I've also got some spare pressure plates to add some straps on the pressure plate, cause I hear those like to break in vw's. Edited 1 time(s). Last edit at 07/24/2006 05:40PM by Carl S. |
DR1665 Brian Driggs Senior Moderator Location: Glendale Join Date: 06/08/2006 Age: Midlife Crisis Posts: 832 Rally Car: Keyboard. Deal with it. |
I've heard a lot of people unhappy with both the Centerforce dual friction (CFDF) as well as Spec clutches. I'm sure there are going to be all kinds of useful replies to this thread which will blow my mind, but I would suggest possibly calling up South Bend Clutch to talk with them about your needs and what they can do for you. Since I am from the non-turbo side of the DSM tracks, we can't just buy an ACT clutch off the shelf and these guys have built a reputation in my community for being honest guys who are genuinely interested in hearing what you need and why you need it before the suggest anything.
Hey Flying Fly Squadron leiter,
I'd go for a sprung center 4 puck clutch, maybe even a 3 puck No point to go for 6. AP Racing supplies a 4 puck for rip-snortin a' rootin an a tootin GpA Cosworths so why go more for a widdle bitty sorta-wabbit?? I use and reccoment Clutch net and have supplied such famous VW drivers as Derek Bottle. Worked good for him. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
sagsert Mustafa Samli Elite Moderator Location: Arizona Join Date: 01/10/2006 Age: Ancient Posts: 824 Rally Car: Gaylant VR4 |
Excusez moi, what car ?
I get my clutches from clutchnet.com even though they are Russian, they take their business very serious and their clutches never failed under my abuse. I use a sprung pressure plate and 6 puck. I had some problems with 3 aqnd 4 plucks so I used straight logic, with a 3 puck, you get one rivet failiure, you lose 33%, 4 puck 25%, 6 puck 17%. Cheers M.Samli Phoenix AZ Gaylant VR4 EVO III GSR (Stolen) Rallies are no place for traitors |
As far as bite is concerned 4 puck and 6 puck are very similar. Contact surfaces are almost identical. If you have a less than perfect flywheel surface the 4 puck will flex less.
sagsert Wrote:
------------------------------------------------------- > As far as bite is concerned 4 puck and 6 puck are > very similar. Contact surfaces are almost > identical. Good math moosie, the pucks are the same area each, say 15sq cm. 4 pucks would be 60 sq cm, 6 pucks 90 sq cm. yeah 30 more cm sq 30 is 50% of 60. Almost identical. Bad Mooosie, go stand in the corner with only 1 ciggie and NO TEA! If you have a less than perfect > flywheel surface the 4 puck will flex less. It seem s the consensus that if the pressure plate makes say 1000 lb/sq in pressure 1000 spread over 4 pucks of "X" are means more presssure per square inch than 1000 spread over 6 pucks. > > Cheers > M.Samli > Phoenix AZ > Gaylant VR4 > EVO II GSR > STC Mouthpiece > Instigator Extraordinaire > > Avatars are like underwear, change them daily. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
nick the brit Nick Taylor Junior Moderator Location: North Hollywood, CA Join Date: 01/25/2006 Age: Possibly Wise Posts: 149 Rally Car: 1995 Subaru Impreza WRX |
FWIW I got a Clutchnet full ring type clutch (I agree they are very nice guys too). I asked about using a puck style for my Subaru (stock WRX 2.0l Turbo engine) and that is what they recommended. Igor (the boss man I think) had said that a client had used a puck for the same type of application and found it a little harsh. I guess I'll find out when I eventually get this godforsaken car finished!
Nick Taylor. Knobhead. Los Angeles, CA. |
nick the brit Wrote:
------------------------------------------------------- > FWIW I got a Clutchnet full ring type clutch (I > agree they are very nice guys too). I asked about > using a puck style for my Subaru (stock WRX 2.0l > Turbo engine) and that is what they recommended. > Igor (the boss man I think) had said that a client > had used a puck for the same type of application > and found it a little harsh. I guess I'll find > out when I eventually get this godforsaken car > finished! > > Nick Taylor. A little harsh as in the dude personally didnt like the engaugement or that it was too difficult to drive? I'm thinking I may just go with the 4 pucker, it'll sound more hardcore when I pull up at the street races, is cheaper, and will be lotsa better than stock. I just hope I dont have to line up against any excels with ignition modz at the lights. Thanks for the advice, guys. And as the lord of the legion of flying flies, I will spare thee from a mighty smiting once we take over the world. |
But Johnny, the 4 puck and the 6 puck i have only have >3% difference on contact surface area. But I am comparing 2 clutches from 2 different manufacturers, I knew there was a reason why I kept the 4 puck that disintegrated, now I can throw it in the garbage.
> > A little harsh as in the dude personally didnt > like the engaugement or that it was too difficult > to drive? The impression I got was that it was a bit too much on or off, so yes the engagement. That would also make it a bitch to drive on the street too. And since a harsh engagement bet stress the weak ol' Subaru trans I went with the full ring. Might not make much of a difference since I got a straight cut dogbox anyway, so will not use the clutch as often - once I learn how to do it anyhoo. Nick Taylor. Knobhead. Los Angeles, CA. |
cdxc/0 jgdxf
Moosie, that's what my 16 month old daughter thinks of your comparing two different brands. Now you forced me to go and actually measure a Clutch-Net puck you pucker. EACH one is 2040mm sq 4 x 2040mm sq is 8160mm sq 6 x 2040mm sq is 12240 mm sq and oddly enough thats a bit more than 3%. Vous ete un Turque Sauvage, pas de ciggies pour toi! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 07/26/2006 12:31AM by john vanlandingham. |
------------------------------------------------------- > > > > > A little harsh as in the dude personally > didnt > > like the engaugement or that it was too > difficult > > to drive? > > > The impression I got was that it was a bit too > much on or off, so yes the engagement. That would > also make it a bitch to drive on the street too. > And since a harsh engagement bet stress the weak > ol' Subaru trans I went with the full ring. Might > not make much of a difference since I got a > straight cut dogbox anyway, so will not use the > clutch as often - once I learn how to do it > anyhoo. > Dude the puck stuff I have used and supplied for a million years is hardly worse than the feather light non feel pedals most Japonause voitures come with, hardly "hard". All things like pressure plate, being equal AP Racing says you get about 30% more torque capacity. So cars with really horrible junk release mechanisms like pre 71 Beetles and my old Saab V4, they chatter till your teeth fall out, but thats a release brg with no guide sleeve. > > > > Nick Taylor. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
