Ford CVH engines - bolt pattern?
Posted by Pete
September 09, 2006 11:03AM
I've seen conflicting info on this.
The Ford CVH engines - popular There, not popular Here.
Some of the local-spec ones have 45mm intake/36mm exhaust and HUGE ports. Sounds interesting! They also grow on trees.
Question of the day: Anybody have any hard info on if these have the same bellhousing bolt-up as the 2.3l?
The interest is in mating one to a common 2.3/T5 bellhousing. I understand there is some bugaboo with the dowel pins being different in size, but that's No Big Deal.
Edited 1 time(s). Last edit at 09/09/2006 11:05AM by Pete.
Re: Ford CVH engines - bolt pattern?
September 09, 2006 04:49PM
they are shit weak motors, bad heads,
weak cranks, shit shit shit, and the make no power what the fuck??????????
Compound Valve Hemisperical.
how do you make compression with a fawked up canted valve sorta hemi? with dentonation producing domes for shitty low comp.
silly boy, pull your weiner out and whack it on the end!!!!
they popular cause for some kids cause they can afford the cars which happen ton have VCHs in em.
