When I deleted the prop valve in the RX-7, I just grabbed metric unions from the local auto parts store (Murray's). AFAIK Mitsu is pretty standard across the board with their flare fittings, as opposed to GM and Ford who like to use a special, different, size/pitch for every friggin' connection. 10x1.0 sounds about right. I don't bother with the Taco Bell rejects usually working the counter(*) but go right to the rack with lines and fittings and adapters and such.
I don't know if metric tees exist in easy-to-locate form, but if you had to, you could always go the sleazy route and use adapters and a SAE tee, or just put SAE fittings on your lines, simple cut and reflare job, takes 10 minutes including finding the beer.
(*) Some parts stores have actual, real-live, intelligent people working the counter. Usually you will find them in non-chain stores, but chain stores that have small showrooms and a couple delivery trucks are also a good bet. (They cater mainly to local shops and thus need to know their shit - my local goto is a NAPA of all places, but if i need a left-side framus bushing for a '83 Obscurmobile, they can get it or know the reason why) Find a place like this and reward them with continued business.
Edited 2 time(s). Last edit at 10/10/2006 07:16PM by Pete.
