Clayto Clayton McCrary Junior Moderator Location: Olympia,WA Join Date: 07/04/2013 Age: Possibly Wise Posts: 161 Rally Car: XRatty purchased. Now build it!! |
Or by looking at your pic... That means you have heims joint and can make spacer!? |
No no no, forget metric rod ends. Get 3/4" LH and RH and then the nifty stainless spacers... drilled to 12 or 14.....that plug into the 3/4" holes. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
mke723 Mike Lindenfelser Professional Moderator Location: Minnesnowta Join Date: 10/17/2012 Age: Midlife Crisis Posts: 154 Rally Car: 1995 Impreza L |
fixed that for ya JVL I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to. Edited 1 time(s). Last edit at 09/15/2013 10:08PM by mke723. |
Get whatever the fuck you want. I don't know why I bother sometimes. You other guys, get your advice and parts from this guy. You're on your own now. Fuck it. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
You can buy the more expensive metric heim joints and spacers but then they become real fun to try to get in and out while laying in the dirt at night.
Or you buy a larger and cheaper standard joint and then a plug in spacer that brigns the hole down to the actual size you need and the spacer plugs into the heim meaning you don't have to fiddle with your knee holding the arm in place while you fiddle with the bolt and a spacer and an arm and another spacer and and and... Of course, some of you pervs probably like getting kinky under the rears of Subarus. On the other hand, you'll still regularly get your asses handed to you by stock suspension cars. And you'lkl just put the stock shit back in at service when you bend the fuck out of the rear arms. Though now they're really weird because you've also bent the shit out of the crossmember in that hit because it was a hard hit and instead of folding up a stock arm, you've slightly less folded up a stronger custom arm AND fucked up the subframe. Grant Hughes |
imnotcrazy Don Kennedy Ultra Moderator Location: Reading, PA Join Date: 10/05/2006 Age: Fossilized Posts: 227 Rally Car: Impreza |
Creech Scott Creech Junior Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
I can vouchsafe for the Pierce stuff. Well thought out, well made, Good (Nay - GREAT!) People. Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. |
TronDD Tim Meunier Godlike Moderator Location: Boston, MA Join Date: 10/27/2011 Age: Midlife Crisis Posts: 252 Rally Car: 96 Subaru Impreza |
Yeah, all concerns I have. I'll live and learn. ...unless I die. Then someone else should learn. Tim. |
Here's a list of catalogs you should order. Every one of them will have swedge tubes, rod ends, brackets, etc. You should be able to find something that is cheap and strong, and it'll show up next day most of the time. A lot of teams race 3 or 4 times a week here.
Yes the parts are for circle track cars, but they'll work just fine for rally unless you hit something. Even then, it's tough stuff. The cornering speeds in late models, mods, and sprints are incredible. speedway motors performance bodies day motorsports smiley's racing products |
Reamer Jeff Reamer Junior Moderator Location: Marlette, Michigan Join Date: 08/14/2010 Age: Midlife Crisis Posts: 489 Rally Car: Subaru |
When you pull into service and change out your stock bent one and dont fix anything else in your car cause you ran out of time.
Or you pull off the road on transit loosen a jam nut spin the bent one a few times re set tow and move onto the next stage brake stage record. Then go to podium get pics with hot girls and get one of those big checks! Oh wait thats not rally? Even still rally cars should have adjustable hiems at some point in its life! First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
Yeah, oh wait, I was about to say! This ain't a You're-a-peein rally. It ain't Czecho--oi oi oi where do they dig up all the hotinas they have at those events? Its enough to make me think about doing tarmac! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Oh I suggest you contact mke723 Mike Lindenfelser, he'll fix you right up I'm sure. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
SteelSolutions William Timmins Ultra Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Midlife Crisis Posts: 648 Rally Car: 3 xr4ti/74 capri/02 bug eye |
No one asked me? That's some horse shhhhiiiit I have only equipped over 100 cars
chances are I have some old shit id love to sell! I know there's some cheap skates out there I'm one of them. and I think every one should build there own shit but that would leave me with out a living. I have thousands in bushing, I have old model shit I would sell for cost. 14mm 40 and 60 mm wide and some 12mm aluminum and steel. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! |
