There are decades and decades of data collected on carb jetting. Weber, Delorto, Holly, Carter, SU and Solex , Mikuni and even Rochester. Large volumes of data. Mazda racing books, Datsun racing books, Ford racing books, the carb companys publish data themselves. What scares me is the little electrons I can't see (and Euro Bosch injection). I'll bet there are a couple dozen blown up Honda motors in this little town from kids trying to turbo them and some tuner adding a chip to the stock ECU.
Pete is right tho, those sumbitches have gotten very pricey to buy new....yikes. |
tdrrally edward mucklow Junior Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
Rallymech Robert Gobright Super Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Possibly Wise Posts: 1,292 Rally Car: 91 VW GTI 8V |
Yep... and leaving it the way Ford made it is the least clever way to do things, so we're already getting clever.. how deep is the rabbit hole gonna go? Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
I should look at what exactly I have...
It is a 2 barrel carb, I believe its the Esslinger adapter to a Holley 2 barrel. The block with high compression pistons was not in the pile of stuff dropped off. This video comes to mind... http://www.powerblocktv.com/episodes/HP2012-16/building-a-competitive-dirt-track-engine Anyhow, I'll just add it to my slightly growing pile of stuff that comes with the Merkur when I try to sell it again and figure something else out later... Grant Hughes |
Gawddam Grant you're like a American 21 year old girl sometimes "I want this. Its pretty. I want that. Its shiny!! Oh wait i want , Iwant, I want. Put the fucking car back together, get a 4.3 in it and have some fun. Look Sean built a good one-=-all purdy.. and Tom Buress who when his VW junk doesn't break is fast like fast.. When he drove Seans he called and was blabbering away 100mph which is unusual for him and say WHOOOOOOOOA man golly fuck-me it works so good.. And he said Sean had to cuff him across the chops to get him to listen and he said "Its stock engine. Stock clutch, 4.3 diff and an intercooler, that's it" You have the damn car, you have enough to put it back together--or people will help=---- you don't need to spend money yoy don't have, and get a bazzillion HP. 4.3 and have fun. And stop being distracted by the latest shiny bauble. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
put it together and run it
n/a with a holley or turbo with efi that is up to you build the better head later i have driven an Esslinger powered mustang svo well worth the work. put it back together and drive it I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
The 2 bbl 500 cfm Holley is pretty easy to 'de-assify'. (I'll add that to my technical lexicon, thank you!). Drill out the air inlets a bit, and then hang wires down into the openings to tune the air bleeds. I used window curtain hanger hooks with the sharp ends ground down to various diameters to stick down into the drilled out air tubes to tune the air; the j-shaped hook part hooked up over the top edge of the air horns nicely. Then tune the fuel jets like regular. You can change the accelerator pumps. Credit John Bell for this idea BTW. Ran almost as good as twin DCOE 45's; the 45's had 300-400 rpm better more usable low end; probably due to better throat sizing to the engine (1.9L Opel with the knarliest cam Isky made) and better transition-off-idle . Poorer idle and gas mileage too but super driveable once you got the hang of it. Match to a 2.3L should be better. I probably have it still lying about if a pix is desired. Edited 1 time(s). Last edit at 10/01/2013 07:08PM by starion887. |
I sold some of my arms to a circle track guy, his high comp race 2.5 on a carb makes 283hp, and revs to 9k. Multiple seasons on a build.
I bet with some decent pistons, a bit or porting, and a carb it would easily make 200. Better than a stock turbo? probably not, BUT it is now G2 legal...... That was the reason I was considering that rabbit hole. Grant, LA/LB computer and a Volvo intercooler is more power than the car needs, and dead reliable on pump gas. |
b00sted David Barrett Mega Moderator Location: Chicago, IL Join Date: 10/21/2011 Age: Settling Down Posts: 216 |
The hell you can't. You guys make carbs sound so terrible... They're easy, as long as you stay away from that Quadrajet/Carter AFB junk. A 2/4 barrel carb based off of the Holley double-pumer design is very easy to tune and will run great. You'll need a jet kit, and you'll want to consult with a good carb builder/tuner(Patrick at ProSystems is one of the best) to figure out a good starting point for accellerator pump(s), cam(s), boosters, etc. We've bought a few ProSystems carbs that came out of the box and ran nearly perfect on the engine dyno(Perfect a/f ratios, awesome power, etc) on 800+hp naturally-aspirated motors. Call a reputable carb builder, tell them what you plan on doing(including engine/cam specs, etc), and let them tell you what you need. It'll basically be a GOOD metering block, and changing a few things on the main-body, bowl, etc. |
Me personally...I'd want to run a good ITB setup with Megasquirt or similar and Alpha-N that utilizes barometric correction to automatically adjust for DA changes. This is assuming it's a high-winding motor with large cams.
Also, is e85 legal in RA and SCCA classes such as G2, G5, and Open Light? |
what is wrong with an afb?
one of the easiest carbs to tune out there. but for a 2.3 a 500cc holley is the way to go, 10000+ stock car racers cant be wrong easy to tune parts at every good auto parts place, books with pictures and the list goes on I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
Every notice all of those guys go almost always one direction? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
the holley works very well on road and desert racers
make sure to use a center float bowl all sort of tuning options i do favor side webers or fuel injection but for the cash the holley is hard to beat I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
