So... I've been thinking...
I am trying to come up with the ultimate compromise for lifting the rally car, that is compact, portable, fast liftning and doesn't take up any (or at least too much) space.
Currently I use a regular trolley jack - liftning height about 20 inches. I have it set up so the handle is easy to remove, it is not too heavy etc., so it fits in my station wagon (our DD doubles as service van). Portability- and compact-wise it works well.
But since it only lifts about 20 inches, I have to lift at the cross member, to get the car high enough into the air to get at least reasonable space under it.
When the car is on the ground, I can't get the jack under the skid plate (we rally on tarmac, so I don't have that much clearance, though it's no road racer).
Currently I solve that by either driving up on two ramps. But they have to sit just right, and always move about a bit, they take up space in my not too big garage, and it's just one extra step that I could do without. Particularly at service.
If i lift at the front, I can't get the car high enough into the air to get the jack stands under the mounts that are behind the front wheels (Mk II Golf).
I used to have a high lift trolley jack, but it takes up a lot of space in the garage, and is too big and heavy for me to bring to races.
I have pondering a million solutions, and the last one is to use one of those farm/off road jacks.
I would build some sort of adapter bar of sorts, to put into the back and front of the respectively, and then put the jack into that.
I figure that the 48" variety of those jacks would be pretty good, and if not, the 60" is always a possibility. The 48" inchers seem to weigh in at around 30 pounds - that should be better than the current trolley jack.
I am concerned about two things though:
1. Are these jacks stable enough for jacking a regular car that high. Or can they be modified in some way to stabilise?
2. Are they worth the while when it comes to the speed and effort of jacking?
I have been watching videos of 4x4-guys using them, but those cars would be quite a bit heavier, and also they may be exaggerating the movement for instructional purposes. Also, I can't seem to figure out if it will take for ever to get the car to a reasonable height.
So - how does the plan sound? Doable? Anybody done something like this?
Other suggestions?
Thanks in advance.
Brgrds
Brian
