Buy, Sell & Trade
rocky mountain autosports
Bryan Short
2002 JDM WRX STI
Winter Rally Tires
January 09, 2014 11:38PM
Take a look at the new Black Rocket winter rally tires. Get them with or without studs. Tires take 4-5 weeks for delivery.
Paddy1337
Tim Patrick
Galant VR-4
Re: Winter Rally Tires
January 10, 2014 02:16PM
interesting tread blocks on the right, lol
Towona
Tony P
MK2 Golf
January 30, 2014 04:45PM
For which rally are these legal to use?
Runamuck Rally
Bryan Short
2002 JDM WRX STI
January 30, 2014 04:52PM
As long as they are not studded they should be legal in most all US rally racing. I would verify with sanctioning (RA, NASA, SCCA, etc) body to be sure.
January 30, 2014 05:43PM
One should bear in mind that the rubber used for tire that are intended to be studded are ---in my experience there using rally studded tires---harder than hell so they will grip the stud..All real studded tires and this includes Black Rocket, have soooooper secret mixes of glue they use to glue the studs in and then the tires are re-vulcanized to set the studs in 100% securely..
When I was importing these a couple of hundred went to ice-racers in Maine---pretty high powered cars running hard and fast (hell first lap I did I did over 100 mph on the straights and I couldn't really see out cause of the fixed seat--and thats rpm vs tire not the speedo) 2 seasons and the guys said maybe 2-3 studs had spat out..
In motor-cross for studding we used either OLD Dunlops or Continentals, both we said then "made from worn out screwdriver handles"...we would never think about those tires for summer use since they were just too gawddam hard.
I know people have used Michelin C5 unstudded for snow---and they did no better than me on Michelin L3s---and those were horrible compared to my street car Nokia NR09s in 165/80 x 15.
I would be very very wary of using these unstudded...
Perhaps for the guys where a little sanity prevails and some studs are allowed, they could forward the spec and the max size and that could be forwarded and get studded and glued in, maybe?
Creech
Scott Creech
Audi 90 Quattro (WIP)
January 30, 2014 06:00PM
Yeah, but where is the Fun in THAT?
cool smiley
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
acrane
adam crane
corolla GT-yes
January 30, 2014 07:28PM
would they glue in 135 studs per tire (per Canadian rules) and hmm, sipe the rest? then ship it over? I'd take 10 for Big WHite next year.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
January 30, 2014 08:01PM
acrane
Thats the max allowed? Not "xx per decimeter of tire"?
HiTempguy
2002 Subaru WRX STi
January 30, 2014 08:02PM
acrane
I think the big issue would be:
The visible portion of each stud must be no more than 5mm in diameter, and any cross-section of the
visible stud (as originally installed) must be perfectly round in shape, and must be of solid
construction, not hollow.
And I believe it is 130, but I always seem to hide my latest copy of the RallyWest regs...
January 30, 2014 09:13PM
SBF rules:
SVENSKA BILSPORTFÖRBUNDET
TEKNISKA Regler RALLY (RY
T)
RY_Tekniska Regler_2014.doc
Utgåva: Januari 2014
Sidan
25
av
25
© 201
4
S
D
UBBNING AV DÄCK
Däcken ska vara dubbat med max 20 dubbar per längd/dm på
däckets hela omkrets mätt med en 20 cm mall.
Dubbme
tod:
utifrån islagna.
Det är förbjudet att kompletteringsdubba däcken under p
å-
g
å
ende tävling.
D
UBBAR
Däckdubbar får användas enligt följande bestämmelser:
1.
Längd: max 20 mm.
2.
Vikt: max 4 gram
3.
Typ:
Cylindrisk kärna, vinkelrätt skuren, ej rör.
Flänsens diameter får vara max 9 mm.
Dubbkroppen ska vara homogen.
4.
Användning: under tävling.
5.
Medgivande: från VV.
6.
Förbud: när ”vinterföre” ej råder.
7.
Yttre begränsningsmått: se skiss
K
RAV FÖR GODKÄNNANDE
AV DUBBAR
Dubben ska uppfylla SBF:s och
Trafikverket
s bestämm
els
January 31, 2014 12:14AM
acrane
WCRC Rules
4.0 Tire Studs
Studded tires may be used on Rally West or RPM events with the following limitations:
a) Studs are only allowed on events outside of Manitoba that take place from October 1st to April 30th of the following year
b) Studs are only allowed on stand-alone regional events, not on National / Regional
combined events.
c) Studs must protrude no more than 3.5mm from the tread face.
d) The visible portion of each stud must be no more than 5mm in diameter, and any cross-section of the visible stud (as originally in stalled) must be perfectly round in shape, and must be of solid construction, not hollow.
e) The studs must be commercially and commonly available, and of conventional design, from tire dealers in the Rally West or BC regions (i.e., no homemade or specially imported studs).
f) There must be a maximum of 130 studs per tire, regardless of tire size
g) Studs must be run on all four corners of the car
h) All studded tires must be presented to the scrutineer before they can be used on an
event
i) Studs cannot be replaced in, or added to any tire for the duration of the event once the tire has passed scrutineering.
j) Studs are permitted in all Region classes
The WCRC rules for reference, a couple of items bolded.
John, the 130 max came from the lowest stud count in the relevant provincial HTAs.
Bryan Short
2002 JDM WRX STI
January 31, 2014 10:41AM
Black Rocket sent us samples of studs. We added photos of these studs to the BR 50, BR 90, BR 110 and BR 120 product pages.
January 31, 2014 12:50PM
We need a winter rally in Colorado that allows these fully studded tires. Create our own market! smiling smiley
January 31, 2014 01:53PM
Yep. So much "we gotta FIA this, we gotta FIA that we gotta blah blah"
Then pick and choose just this and just that..
Kinda like when we all agitated to adopt the F-cup cc to weight thing which SEEMS to have worked so well and for so long..
Nope couldn't leave it alone, "they" know better..
Pfffft!
January 31, 2014 03:18PM
A couple of factors led to the stud rules in western Canada.
- A desire to stay within the lowest regulated standard withing the provincial Highway Traffic Acts.
- Feedback from the competitors involved that showed they didn't really want to spend $1200+ on a set of special order rally tires. (in other words, how could we ask a 'clubbie' to spend what they'd spend on two local events on JUST a set of tires for one event.)
- An understanding that 'WRC' studs cause a great deal of damage to the stage roads, particularly start lines, and damned near dangerous on paved roads.
- That's how we ended up with commerically available street studs as a reasonable option. The amount of stud exposed isn't legislated, so the long studs are fine. (In reality, anything over 2.5mm exposed will get ripped out fast anyway)
So if you don't like picking and choosing, if we adopted the cc to weight thing then you also advocate an outright ban on turbos? That's worked well for so long as well!
