Towona Tony P Super Moderator Location: Alberta, Canada Join Date: 08/21/2010 Age: Midlife Crisis Posts: 149 Rally Car: MK2 Golf |
Supposedly, but they aren't common at all....and really they are hardly worth the time and money to R&R the box strip it and install... Do the match: 3.9 to 4.2 only shortens the final drive a little bit---about the same as the tall gravel tires gear the car UP, so you spend whatever and end up geared in effect, like a standard road car.. Nope, go for something that actually results in a NET-GAIN for the time and money spent John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
BobOfTheFuture Rob Ultra Moderator Location: LI, NY Join Date: 09/25/2010 Age: Settling Down Posts: 629 Rally Car: None, anymore. |
020 8V Ring and Pinion set 4,86 : 1 What could possibly go wrong? Here, hold my beer. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
The stock 16v and 8v GTI boxes that everyone uses are 3.67 so going to 4.25 is a bigger jump than you suggest but still problematic. With a 16v 5th gear (0.91) you end up with a top speed of like 130+ mph which is too high. ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
danster Haggis Muncher Mega Moderator Location: Haggisland UK Join Date: 01/04/2013 Age: Possibly Wise Posts: 409 Rally Car: VWs (for my sins) |
Looks like an AGB box is the same as a 2Y. If that is true then the diff OD / crownwheel ID is 111mm.
Are you going to be fitting an LSD? If so choose one for an 8v application with 109mm OD as most lower final drive option use that size. I wouldn't be building a box for rally use without an LSD of some sort. The two main weaknesses of the standard 020 box are the original / crownwheel rivets failing and the planet and sun gears falling to bits, both result in a fooked box and an expensive DNF. One DNF costs the same as an LSD.... Disappointingly not yet a Jackass |
My memory may be inncorect but I thought all the VW fan-boi types always blab about their "close ratio" was this
3.67 is even worse.... Looks like the shorter the better if retaining stock overdriven 5th.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Memory still working ok there John. The term "close ratio" is commonly used in VW circles to identify the oem GTI gear set, as opposed to the oem "wide ratio" gear set used in less sporty shopping car models. It is not being used in a "motorsport close ratio" sense. Both those close and wide ratio gear sets are listed in the quoted box in your post. However there are a few alternate ratios in the 2nd, 3rd, and 4th gears but 1st is always 3.45 and 5th no lower than 0.91 in oem gears. The 3.89 final drive was fitted to some mk1 Golf / Rabbits and that gearbox casing does not have the mounting bosses cast into it to attach a mk2 / 3 rear gearbox mount to the diff casing. And that type of casing will also not accept 100mm inner CVs. Disappointingly not yet a Jackass |
RallyBrighton Brad Hayosh Mod Moderator Location: Ann Arbor, Michigan Join Date: 08/08/2011 Age: Possibly Wise Posts: 19 Rally Car: MK2 Jetta - 1998 Impreza STIish |
FWIW, I picked up a 4.46 FD (for an 8V) box this summer - 290 euros (180 for the FD - 110 for shipping) from MTS - well worth it (Kaaz, too but not from MTS).
Other bit of kit worth thinking about: http://www.usrallyteam.com/index.php?main_page=product_info&cPath=13_34&products_id=1763 - let's you actually tell what gear you are in... |
The car had a AGB with a quaife, but then popped a bit of aluminum off the case and a ton of oil into the clutch... With the help of Kurt, we now know just about the whole gearbox is trash but the quaife. So the idea was to swap that and a better final into another AGB that he has to offer. I'm nervous because the internet calls that box '16V'. But the internet also says the input shaft is a size it wasn't (as we dealt with earlier getting a clutch, John) And seeing what the cost of getting a bit of gear over here, I guess I just wanted to run it past the guru's. Enablers, All of you. |
Thanks Chad, was just on the phone with Bob trying to straighten him out on all the choces--not so easy when I never built one of these... At least I assured him that those overseas 4.86 things aren't gonna be some gigantor headache and it made me remember that guy "Brokenvw" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
OK looks like we fingered that one out...Not bad fora buncha never-was-es who never did anything, ever. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
