zack13277
Hey, I'm looking for a Toyota rear end or 3rd member, I live in Wisconsin, but could drive to pick it up. Let me know what you have. Preferably not rusty.
Thanks
Zack specify you want a 8" unit...Maybe 4 runner is best.
Look here:
http://www.4crawler.com/4x4/4R_TechInfo.shtml
Ratio
Ring
Pinion
Factory
Color
Code Crawl Ratio
(stock) Tire Size
to stock
M/T Tire Size
in use
M/T Tire Size
to stock
A/T Tire Size
in use
A/T
3.42 41 12 Purple 31 : 1 . . . .
3.90 39 10 none 36 : 1 . . . .
3.93 . . none . . . . .
4.10
41
10
Pink 37 : 1 28 28 . 28
4.11 37 9 Orange 37:1 pre-'82 28 28 . 28
4.30 . . Blue . 29-30 29-30 28 28
4.37
35
8
Green 40 : 1 30 29-30 28 28
4.56
41
9
Yellow 41 : 1 31 29-31 29-30 29-30
4.88
39
8
White 44 : 1 33 31-33 31 31-33
5.29
37
7
none 48 : 1 36 33-36 33 33
5.71
40
7
none 51 : 1 39 37+ 35 33+
gawddam formatting..Look at link.
There are 4 common factory gear ratios for the '84-'95 pickups and 4Runners. What ratio your truck has depends on what type of transmission it came with (manual/4 speed) or automatic) and whether it came with the factory 31" tire option (early '90s SR5 option) or the normal 28" (P22575R15) tires, as noted below:
Tranny/
Tire 28" 31"
Manual 4.10
4.56
Automatic 4.30
4.88
So auto tragic 4 -runner with big dumb baloony tires gets you a 4.88 stock..
