Tom B Tom B Mod Moderator Location: Douche Canoe, WA Join Date: 02/27/2006 Age: Midlife Crisis Posts: 780 Rally Car: VW Golf |
Brantz International 2 'S' Pro Trip Meter $250
5 Hella Rallye 4000 Driving Lamps w/guards, 3 pencil, 2 cornering $80 each Terratrip Terraphone Professional Intercom, w/two practice headsets $200 18" Avanti Map light $40 Sparco Sprint Racing seat $150 (some dirt, stains and small burns) Tilton Quick adjust proportioning valve $60 FIA Cert-2012 Black G-force Racing 6-point Camlock Harnesses and sparco shoulder pads $200 Sprint car Window Net Set $40 Demon Rally Shark Fenders $100ea donation Demon Rally numbered Doors $40ea donation Rabbit Reinforced lower tie-bar, complete weld-in Skid plate assembly, and two matching skidplates W/brackets and mounting hardware $450 Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $80 each Rabbit 16V Long tube exhaust header $100 Rear rabbit Euro bumper $40 Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies) Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new) Rabbit Bilstein Front HD Struts/Springs/Bearings $250 (new) Rabbit Bilstein Rear HD Struts/spring assembly $125 (4 rallies) Rabbit KYB Rear struts/spring assembly $50 (used, not rallied) Rabbit Brand New (fresh ends) 100mm axle set $200 Rabbit New Short (fresh ends) 100mm axle $100 Rabbit Power Steering Rack, new complete tie rods $225 Rabbit Steering knuckles/bearings, $25ea Rabbit 10.1" rotors $20/pr Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulator $20 Rabbit Fuel Tank $50 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it $40 Rabbit small tail lamps $45/set Rabbit rear Tail panel filler $50 (used to convert large tail lamp cars to small tails w/o body work) Rabbit Solid Aluminum rear engine mount $100 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 ea Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Headlamps $50 Rabbit Heim shift linkage $75 Scirocco shifter box w/leaning handle$20 OBO -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
mack73 Jason Wine Infallible Moderator Location: Seattle, WA Join Date: 02/20/2006 Age: Midlife Crisis Posts: 448 Rally Car: Started a Golf... Never Finished It |
DR1665 Brian Driggs Mega Moderator Location: Glendale Join Date: 06/08/2006 Age: Midlife Crisis Posts: 832 Rally Car: Keyboard. Deal with it. |
Those fenders would look siiiikkkk in someone's garage.
seriously, they'd be dope as garage art.
iRACECAR Roy Farrell Ultra Moderator Location: Connecticut Join Date: 06/27/2008 Age: Settling Down Posts: 3 Rally Car: A sullen Scirocco awaiting a transfusion of blood, sweat, tears, and heaping armfuls of non-existent money. |
UPDATED LIST:
some images available upon request Bunch of spare parts for sale here for BO: Race Stuff: 2 Sparco six-point camlock racing harnesses Expired FIA Cert $250 ($300ea new) Looks like Current FIA Cert-2011 Black G-Force Racing 6-point Camlock Harnesses and sparco shoulder pads $200 Looks like Current FIA Cert-2011 Grey/Silver Willans 6 point Camlock Harnesses $350 ($300ea new) Looks like Terratrip Terraphone Professional Intercom $75 ($100 NEW) Garage Art/Help Us get back out again: Demon Rally Shark Fenders $100ea donation Looks like Demon Rally numbered Doors $40ea donation Rabbit Specific: Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr Link Rear rabbit Euro bumper $30 (driver's side scuffed) Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies)Link Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new)Link Rabbit Bilstein Front HD Struts/Springs/Bearings $250 (new)Link Rabbit Bilstein Rear HD Struts/spring assembly $125 (4 rallies)Link Rabbit KYB Rear struts/spring assembly $50 (used, not rallied) Rabbit New Short Driver's Side (fresh CV's) 100mm axle $100 Rabbit Power Steering Rack, new complete tie rods $225 Rabbit 10.1" rotors $20/pr used Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulator $20 Rabbit Fuel Tank $50 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $40 Rabbit small tail lamps $45/set Rabbit rear tail panel filler $50 (used to convert large tail lamp cars to small tails w/o body work)Link Rabbit Solid Aluminum rear engine mount $100 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 ea Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Round Headlamps $50 Rabbit Heim shift linkage $70 Scirocco shifter box w/leaning handle$20 Scirocco 16V exhaust manifolds $60 ea Scirocco 16V stock downpipe and newer catalytic converter $45 Rabbit Non-AC Heater/Defroster box and heater core $20 Rabbit Rear Axle Beams $40 Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea 80 rabbit hood $20 80 Rabbit non-defroster hatch $20 83 GTI non-sunroof ROOF SKIN $40 77 Rabbit (lightweight) doors L & R $50 ea Under the Hood: Schrick 276 Cams, exhaust cam has very light keyway damage from a timing belt slip, was never an issue, just need to torque it down properly gears are pressed on already $450 (~$750+ new) Rare Velocity 55mm 16v throttle body $300 ($400 new) Link New 60 Amp Golf II 8v alternator $70 9A 020 8V GTi Transmission Used $180 2Y 020 16V GTi transmission Used $225 2.0L 16V 5K mile old cylinder Head Fresh Rebuild No cams (stock can be supplied and installed) $250 4 14" Snowflake Rally Wheels $50/set more to come :screwy: -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
KTurner Kevin Turner Senior Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
Possibly interested in the Willans belts (two right?) and terraphone. How long are the shoulder straps? I have an fia kit for a GC8 and the harness bar is more or less on the rear deck. Think wrapping the shoulders would cause an issue with the FIA cert??
-KTurner Stomp down on the exhilarator and hold on to the wheel. |
yup, that'd be for two sets of belts, I'll check on the length and get back to you. Only have 1 professional terraphone unit left, no transit headsets.
Couldn't tell you about wrapping the shoulders affecting the FIA cert, never dealt with an FIA cage before..chat with a scrutineer to make sure. -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
Tom B Wrote:
------------------------------------------------------- > > Couldn't tell you about wrapping the shoulders > affecting the FIA cert, never dealt with an FIA > cage before..chat with a scrutineer to make sure. > Checking it with Willans. -KTurner Stomp down on the exhilarator and hold on to the wheel. |
Belts are sold...sorry.
Updated list: Race Stuff: 2 Sparco six-point camlock racing harnesses Expired FIA Cert $250 ($300ea new) Looks like 1 Terratrip Terraphone Professional Intercom $75 ($100 NEW) Garage Art/Help Us get back out again: Damaged Demon Rally Shark Fenders $100ea donation Looks like (one SOLD, thanks Matt!) Damaged Demon Rally numbered Doors $40ea donation Rabbit Specific: Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr Link Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll) Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies)Link Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new)Link Rabbit Bilstein Front HD Struts/Springs/Bearings $250 (new)Link Rabbit Bilstein Rear HD Struts/spring assembly $125 (4 rallies)Link Rabbit KYB Rear struts/spring assembly $50 (used, not rallied) Rabbit New Short Driver's Side (fresh CV's) 100mm axle $100 Rabbit Power Steering Rack, new complete tie rods $225 Rabbit 10.1" rotors $20/pr used Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulators $20 ea Rabbit Fuel Tank $40 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 ea Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Round Headlamps $50 Rabbit custom Heim joint shift linkage $70 Scirocco shifter box w/rocco leaning handle $20 (works in a Rabbit, puts the shifter closer to you) Scirocco 16V exhaust manifolds $60 ea Scirocco 16V stock downpipe and newer catalytic converter $45 Rabbit Non-AC Heater/Defroster box and heater core $30 Rabbit Rear Axle Beams $40 Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea 80 rabbit hood w/hood pin hold-downs $20 80 Rabbit non-defroster hatch $20 83 GTI non-sunroof ROOF SKIN $20 77 Rabbit (lightweight) doors L & R $40 ea Under the Hood: Schrick 276 Cams, exhaust cam has very light keyway damage from a timing belt slip, was never an issue, just need to torque it down properly gears are pressed on already $450 (~$750+ new) Rare Velocity 55mm 16v throttle body $300 ($400 new) Link New 60 Amp Golf II 8v alternator $70 9A 020 8V GTi Transmission Used $180 2Y 020 16V GTi transmission Used $225 2.0L 16V 5K mile old cylinder Head Fresh Rebuild No cams (stock can be supplied and installed) $250 4 14" Snowflake Rally Wheels $50/set more to come :screwy: -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
JohnLane John Lane Professional Moderator Location: Lynden Washington Join Date: 01/14/2006 Age: Possibly Wise Posts: 725 Rally Car: The Fire Breathing Monster |
Pomeroy? it's a possibility, but we need to sell some more of this crap...Our VERY optomistic date is for DooWops 09, but I won't rule anything out right now.
mothra Matt Smith Elite Moderator Location: Wilmington NC Join Date: 03/31/2006 Age: Possibly Wise Posts: 546 Rally Car: xr4ti |
the lights were sold in the first 10 minutes...here is the latest list:
Race Stuff: 2 Sparco 70" H-style five-point camlock racing harnesses SFI Build date 5/2004 $250/pr ($600pr new) Looks like 1 Sparco 70" H-style shoulder harness (ONLY) for cam-lock 3' belt sets SFI Build date 10/2003 $40 1 Terratrip Terraphone Professional Intercom $75 ($100 NEW) 4 Kumho R700 Rally tires 205/60/15 not a ton of tread depth left, but very little corner wear $75/all Lengths of FIA Homologated rollbar padding both 1-14"-1-5/8" up to 2" $5/chunk 1 Rally Legal first aid kit $ 60 2 5# fire extinguishers $40 Rabbit Specific: Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr 2 Sets left! Link Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll) Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies)Link Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new)Link Rabbit KYB Rear struts/spring assembly $50 (used, not rallied on) Aluminum dash $50 no gauges Polyurethane rear transmission mount $20 Poly rear beam bushings $10 One power steering tie-rod end new $15 Rabbit New Short Driver's Side (fresh CV's) 100mm axle $100 Rabbit Power Steering Rack, new complete tie rods $225 Rabbit used 10.1" rotors and Porterfield R4 pads $70 Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulators $20 ea Rabbit Fuel Tank $20 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 ea Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Round Headlamps $50 Scirocco shifter box w/rocco leaning handle $20 (works in a Rabbit, puts the shifter closer to you) Scirocco/rabbit 16V exhaust manifolds $60 ea Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45 Scirrocco/Rabbit 16V reinforced pedal cluster with sprung clutch return, 22mm master cylinder and 16v brake booster combo $75 Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea 80 rabbit hood w/hood pin hold-downs $20 80 Rabbit non-defroster hatch $20 83 GTI non-sunroof ROOF SKIN $20 77 Rabbit (lightweight) doors L & R $40 ea Rabbit CIS K&N drop in filters $30ea Scirocco 16v e-brake cables for rear discs $30 Scirocco 16V Cis-E wiring harness for a rabbit $50 80+ rabbit gas caps $10ea Stock Rabbit A-arm set $40 VW Motorsport rabbit rear Transmission mount $40 factory vw rabbit radiators $20 ea used/working custom 1/8" rabbit aluminum radiator shroud $20 rabbit overflow bottles $5ea US Spec long tail lights great shape $50/set other 4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $100/set MKII 9.4" hub set nearly new with race pads, lightly used rotors, Kelsey-Hayes Calipers and newer good ball joints, comes with 2 sets of Porterfield R-4S (race) pads used, $600 in parts, $150 takes it (hell the pads run $100/set alone) 16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $250 New in Box 60 Amp Golf II 8v alternator $70 9A 020 8V GTi Transmission Used $180 4 14" Snowflake Rally Wheels $50/set Audi 20V NA 5cyl bottom end $50 Fuba antenna and cables $20 CIS basic fuel injection setup $40 Golf II 42mm intake manifold $25 oil pan with turbo return line welded in $20 -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
