Tom B Tom B Ultra Moderator Location: Douche Canoe, WA Join Date: 02/27/2006 Age: Midlife Crisis Posts: 780 Rally Car: VW Golf |
Newest updated list of race parts and other stuff I have for sale or trade, etc.
Bunch of spare parts for sale here for BO: Race Stuff: 2 Sparco 70" H-style five-point camlock racing harnesses SFI Build date 5/2004 $250/pr ($600pr new) image 1 Sparco 70" H-style shoulder harness (ONLY) for cam-lock 3' belt sets SFI Build date 10/2003 $40 image 4 Kumho R700 Rally tires 205/60/15 not a ton of tread depth left, but very little corner wear $75/all image image image image image Lengths of FIA Homologated rollbar padding both 1-14"-1-5/8" up to 2" $5/chunk 1 Rally Legal first aid kit $ 60 2 5# fire extinguishers $40 Plated and widened Rabbit A-arms (made by Cascade Autosport), same track as a Golf II (use golf axles) $150 VW CIS Fuel Sample Valve $40 SCCA legal mk1 Rabbit/Jetta Strut top reinforcement plate set, 1/4" mild steel, requires welding and cutting $60 10.1" mkI Rabbit/Jetta/Scirocco brake kit (calipers, carriers, and rotors) w/Porterfield R4 (race) Brake pads $120 (Used) Rabbit Suspension/Braking: Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll) Neuspeed rear rabbit swaybar (NLA) $150 ($300 NEW) Front upper strut tie-bar for a 8v rabbit, Autotech $90 Polyurethane rear transmission mount $20 Poly rear torsion beam bushings $10 One power steering tie-rod end new $15 Rabbit Power Steering Rack, new complete tie rods $225 image Rabbit used 10.1" rotors and Porterfield R4 pads $70 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 Scirocco 16v e-brake cables for rear discs $30 Stock Rabbit A-arm set $40 VW Motorsport rabbit rear HD Transmission mount $40 Misc Rabbit Stuff: Clutch cable New $20 Long American Tail Lamps $40 Aluminum dash $50 no gauges image Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulators $20 ea Rabbit Fuel Tank some small denting $20 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20 Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Round Headlamps frames are bent, headlamps and 55/100 bulbs intact $40 Scirocco/rabbit 16V exhaust manifolds $60 ea image Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45 image Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea 80 Rabbit non-defroster hatch $20 83 GTI non-sunroof ROOF SKIN $20 77 Rabbit (lightweight) doors L & R $40 ea Scirocco 16V Cis-E wiring harness for a rabbit $50 factory vw rabbit remote reservoir radiators $20 ea used/working rabbit overflow bottles $5ea US Spec long tail lights great shape $50/set other 4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $100/setimageimage 16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $250 image image image Golf/Jetta/Corrado Neuspeed swaybar, may be bent, one bad heim, $40 9A 020 8V GTi Transmission Used $180 image 5 14" Snowflake Rally Wheels $60/all imageimage Audi 20V NA 5cyl bottom end $50 Fuba Radio antenna and cables $20 CIS basic fuel injection setup $40 CIS-E fuel distributor and top airbox mount $60 Golf/Jetta II 42mm 16v intake manifold $25 oil pan with turbo return line welded in $20 Golf/Jetta II brake booster and 20mm master cylinder $20 image -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
BillyElliot Billy Elliot Mann Infallible Moderator Location: Royal Oak, MI Join Date: 08/11/2008 Age: Midlife Crisis Posts: 557 Rally Car: 1996 Honda Civic with VTEC YO! |
How does the fuel sample port hook up? I was looking at getting one that went with the soft line between the main pump and accumulator, but if you guys got one that's already made I might be interested in getting it.
And would you ship the 5 snowflake wheels? I've been looking for 5 wheels for a snow set and/or tarmac set and the only place I can find OEM VW wheels locally sells them for $75 a pop so getting 5 for $60 is a steal even if I include a shipping price. And is there a LSD in the tranny, how are the gears what ratios are in it and final drive, and how many rallies have been run on it? Would you ship that as well? BTW I'm in Detroit. Edited 2 time(s). Last edit at 08/25/2008 11:49AM by BillyElliot. |
Fuel sample port is basically a banjo fitting tapped with a cap It's no biggie to hook up, I think we had it on the return line, it should work on any CIS car.
I'd ship the wheels for whatever the shipping cost would be. no LSD in the transmission, but I can get pretty good deals on KAAZ diffs new. It is in good working order, no grinds or broken gears AFAIK. Final drive is the stock 3.67, swap to a 4.2+ and you will be a happy camper. -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
UPDATED LIST
some images available upon request Bunch of spare parts for sale here for Best Offer: Race Stuff: 2 Sparco 70" H-style five-point camlock racing harnesses SFI Build date 5/2004 $250/pr ($600pr new) 1 Sparco 70" H-style shoulder harness (ONLY) for cam-lock 3' belt sets SFI Build date 10/2003 $40 image 4 Kumho R700 Rally tires 205/60/15 not a ton of tread depth left, but very little corner wear $75/all image image image image image Lengths of FIA Homologated rollbar padding both 1-14"-1-5/8" up to 2" $5/chunk 1 Rally Legal first aid kit $ 60 2 5# fire extinguishers $40 Plated and widened Rabbit A-arms (made by Cascade Autosport), same track as a Golf II (use golf axles) $150 VW CIS Fuel Sample Valve $40 SCCA legal mk1 Rabbit/Jetta Strut top reinforcement plate set, 1/4" mild steel, requires welding and cutting $60 10.1" mkI Rabbit/Jetta/Scirocco brake kit (calipers, carriers, and rotors) w/Porterfield R4 (race) Brake pads $120 (Used) OMP Dead Pedal and Co-Driver's foot rest some very light surface corrosion $50 VW 02A Clutchnet 4-puck Sprung Hub Clutch Disc NIB $100 Rabbit Suspension/Braking: Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll) Neuspeed rear rabbit swaybar (NLA) $150 ($300 NEW) Autotech Solid 22mm front swaybar $150 Front upper strut tie-bar for a 8v rabbit, Autotech $90 Polyurethane rear transmission mount $20 Poly rear torsion beam bushings $10 One power steering tie-rod end new $15 Rabbit Power Steering Rack, new complete tie rods $225 image Rabbit used 10.1" rotors and Porterfield R4 pads $70 Rabbit Front poly engine mounts $20ea Rabbit rear beam $20 Scirocco 16v e-brake cables for rear discs $30 Stock Rabbit A-arm set $40 VW Motorsport rabbit rear HD Transmission mount $40 Prothane Rear Poly Urethane Rear Torsion Beam Bushings New In Box $20 Misc Rabbit Stuff: Clutch cable New $20 Long American Tail Lamps $40 Aluminum dash $50 no gauges image Rabbit Fuel Pumps $50 ea Rabbit Fuel Accumulators $20 ea Rabbit Fuel Tank $20 Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20 Rabbit Carbon fiber look PVC Sintra Door panels $50 Rabbit driver's side flag mirror $20 Rabbit H4 Round Headlamps $50 Scirocco/rabbit 16V exhaust manifolds $60 ea image Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45 image Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea 80 Rabbit non-defroster hatch $20 83 GTI non-sunroof ROOF SKIN $20 77 Rabbit (lightweight) doors L & R $40 ea Scirocco 16V Cis-E wiring harness for a rabbit $50 factory vw rabbit remote reservoir radiators $20 ea used/working rabbit overflow bottles $5ea US Spec long tail lights great shape $50/set other 4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $100/setimageimage 16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $250 image image image Golf/Jetta/Corrado Neuspeed rear swaybar, may be bent, one bad heim, $40 9A 020 8V GTi Transmission Used $180 Audi 20V NA 5cyl bottom end $50 Fuba Radio antenna and cables $20 CIS basic fuel injection setup $40 CIS-E fuel distributor and top airbox mount $60 Golf/Jetta II 42mm 16v intake manifold $25 oil pan with turbo return line welded in $20 Golf/Jetta II brake booster and 20mm master cylinder $20 image -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
