Buy, Sell & Trade
Want to beat John Lane? Here's your best shot...
Posted by NoCoast
October 03, 2008 01:45PM
1985 Merkur XR4TI - $15,000
Spent the last three years building. Has successfully completed Rally Colorado, two hill climbs and three testing days and one rally cross with little to no problems. Never missed a competion run at the hill climbs and never failed to complete a run. Hate to sell but life is catching up to me. Between working full time , grad school, and having way to much debt at the moment I realistically can’t be racing rally cars. I’m also a little tired of eating peanut butter and crackers as many of my meals because I’m always broke. I've invested nearly $30K into building the car, not to mention hundreds and hundreds of hours of prep time/labor. I hate to part with it, especially at such a loss and as it's so close to being really, really cool. I built this car with the intention of having something fun and RWD that I could learn on, but would be fully capable of winning 2WD at any event in the nation. It's definitely there or really close right now as it sits. A little bit of work on the head and an ECU upgrade and it’d be well over 300 hp to the wheels. Reliably. Anyhow, here's the full specs.
Drivetrain/Cooling/Steering:
Ford 2.3T engine
Stock head
Rotated and ported upper intake
Relocated alternator and upgrade to 3G serpentine drive
Upgrade power steering system with remote reservoir and large Setrab cooler
Cossie Intercooler and all 2.5" mandrel bent plumbing
Large Setrab oil cooler
50 mm thick aluminum radiator
Dual 11" 1300cfm Spal puller fans
Bailey Motorsports Swirl Pot
Bailey Motorsports header/expansion tank
All Samco or Hose Techniques silicone hoses for cooling, vacuum, and intercooler plumbing.
Bailey Motorsports Venturi Dump Valve
Upgrade 0.63 AR T3 turbocharger
Remote oil filter with oil line to turbo right after filter.
AN hose almost everywhere
KN cone filter
Oil pressure and temp, EGT, water temp, and voltmeter VDO gauges
3" turbo back exhaust with 3" high flow cat comes with car. Flex pipe and v-band at end of downpipe for ease of removal.
Ford Motorsports M7003Z aftermarket, close ratio T5 transmission with steel bearing retainer.
Godfrey adjustable clutch quadrant
Clutchnet 6 puck race clutch with stock pressure plate
Fidanza 9 lb aluminum flywheel
Welded stock rear differential
New halfshafts w/ two additional new ones for spares
New wheel bearings all around before Rally Colorado
Brakes:
Demon Tweeks adjustable dual master cylinder pedal box. Reinforced firewall.
JVAB custom fronts with Wilwood FBSL 4X1.625 calipers on 283mm X 1.25" rotors and aluminum hats.
TCE custom rears with 11" X 0.81" rotors on aluminum hats and Wilwood NDL 4X1.125 calipers
K-sport Hydraulic Handbrake
Every line is teflon braided stainless steel. No hard lines left in the car
The braking system is nearly identical to the Sierra Cosworth WRC cars and the car stops like a rock star and braking feels amazing.
Suspension:
JVAB 41 mm Bilstein fronts, 50 mm Bilstein rears
MC2Racing nylon bushings on rear trailing arms.
Powerflex poly rear beam bushings
MC2Racing aluminum diff mount with poly bushes
Powerflex front TCA inner bushings
Compbrake compression struts in front
Exterior:
VW Jetta bumper conversion
NACS Cossie RS500 rear whale tail and front grill
Euro spec glass headlamps
Freshly painted
Sparco mudflaps
Euro style rear windows with lexan all around
Large and well built 6061 skidplate
Fuel lines and pump/filter protected
Pin stand slots in front and rear of car
Car cover
Wheels and tires
6 - Compomotive 15X7 et 35 with Yokohama gravel tires. Tire all used but fairly decent still
4 - Compomotive 15X6 et 25 with Michelin gravel tires. Total of 10 Michelin tires for fronts, all used but still pretty good.
Interior:
Custom built FIA 2007 spec roll cage with all required bars and gussets plus a few extra
Sparco Pro 2000 and Rev Plus seats
Sabelt lightweight 5 point harnesses
Fully flocked dashboard
Momo steering wheel
Custom gauge pack
Optima yellow top battery with 150 amp fuse on ground in cool Tim Taylor battery mount, sitting behind codrivers seat
Spares/extras:
Halfshafts, rear STAs, rear tranny housing, front hubs/uprights, full set of M14 race studs and nuts to upgrade from M12, both serpentine belts, a bunch of random sensors, relays, etc., two Supra clutch type LSD differentials with 4.3 final drive ratios and the JVAB adapters to go to Merkur halfshafts (JVAB is in process of building custom stronger rear beams to use these diffs), lots of brake fittings and some other random AN fittings and hose. T3 turbo, 3G alternator, spare bracket for alternator
Tools:
Harbor Freight 35.5" lift height super jack (awesome for using tall pin stands)
Correct sized socket for the stub shafts through the wheel bearing carriers (41 mm or something huge like that)
JohnLane
John Lane
The Fire Breathing Monster
Re: Want to beat John Lane? Here's your best shot...
October 09, 2008 09:20AM
Grant I've not had the chance to beat you on stage yet!!
JohnLane
October 09, 2008 10:55AM
You will. smiling smiley
JohnLane
John Lane
October 11, 2008 11:09PM
You should make it out for Doo-Wops!!
JohnLane
