latest and greatest list of crap I have in my garage I would like to see gone:
Cool Stuff:
1 Sparco 70" H-style shoulder harness (ONLY THE SHOULDER HARNESS) for cam-lock 3" belt sets SFI Build date 10/2003 $40
1 Rally America / NASA / CARS Legal RALLY first aid kit $ 60
1 5# fire extinguisher with dual strap bracket filled and current 1yr certification $40
Plated and widened Rabbit A-arms (made by Cascade Autosport), same track as a Golf II (use golf axles) $150
10.1" mkI Rabbit/Jetta/Scirocco brake kit (calipers, carriers, and rotors) w/Porterfield R4 (race) Brake pads $120 (Used 40% on the pads, 80% on the rotors), great for track days.
OMP Aluminum Dead Pedal and Co-Driver's foot rest some very light surface corrosion $50
VW 02A Clutchnet 4-puck Sprung Hub Clutch Disc NIB, streetable, but I wouldn't recommend it $100
Autometer Ultra-Lite 5" 160MPH Electronic Speedometer
$180 ($218 Summit) Like New
Autometer Ultra-Lite 5" 10K RPM Tachometer
$110 ($140 Summit) Like New
Autometer Ultra-Lite 2 1/16" electrical water temp gauge
$40 ($45.00 Summit) New
Autometer Ultra-Lite 2 1/16" electrical oil temperature gauge
$40 ($47 Summit) New
Longacre Carbon gauge panel w/ Oil Pressure, Water Temp and Oil Temp gauges w/ warning lights for all gauges (burn from rear due to an arcing hot wire, almost unnoticeable) (PN 44424)
$150 ($200 new)
Longacre Carbon Start switch panel Start button w/one aircraft switch for ignition and two switches and indicator lamps for accesssories
$50 ($68 new)
Rabbit Suspension/Braking:
Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll)
Autotech Solid 22mm front swaybar $140
Front upper strut tie-bar for a 8v rabbit, Autotech $80
Polyurethane rear transmission mount $20
Poly rear torsion beam bushings $10
One power steering tie-rod end new $15
Rabbit Power Steering Rack, new (150 miles on) tie rods and tie rod ends $175
Rabbit rear beams $20ea
Scirocco 16v e-brake cables for rear discs $30
Stock Rabbit A-arm set $30
Misc Rabbit Stuff:
Clutch cable New $20 ea
Long American Tail Lamps $30/pr
Aluminum dash $50 no gauges can include gauges and switches for extra
Rabbit Fuel Accumulators $20 ea
Rabbit Fuel Tank $20
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20
Rabbit Carbon fiber look PVC Sintra Door panels $50
Rabbit driver's side flag mirror $20
Rabbit H4 Round Headlamps $50
Scirocco/rabbit 16V exhaust manifolds $60 ea
Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45
Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea
80 Rabbit non-defroster hatch $20
83 GTI non-sunroof ROOF SKIN $20
77 Rabbit (lightweight) doors L & R $40 ea
Scirocco 16V Cis-E engine harness for a rabbit $50
factory vw rabbit remote reservoir radiators $20 ea used/working
rabbit overflow bottles $5ea
other
4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $90/set
image image
16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $240
image image image
Audi 20V NA 5cyl bottom end $40
Fuba Radio antenna and cables $20
CIS basic fuel injection setup $40
CIS-E fuel distributor and top airbox mount $60
Golf/Jetta II 42mm 16v intake manifold $25
oil pan with turbo return line welded in $20
Golf/Jetta II brake booster and 20mm master cylinder $20
Trades/WTB:
Wideband A/F Gauge
Golf/Jetta II 100mm axles
Golf/Jetta II Front fenders
Golf/Jetta II Small bumpers front and rear
Golf/Jetta II lower front valance
Golf/Jetta II front dual or quad round grilles and headlamp assemblies (even just individual pieces)
Golf/Jetta II 2-door doors
Golf/Jetta II Hoods
16V race internals for NA motors
Lightweight 15" 4x100 wheels/tires
VWMS Transmission components
02A Gearkits straight cut dog engagement or helical synchronized kits (Gemini, Quaife, etc).
Golf/Jetta II brake kits (Wilwood, Brembo, Alcon, etc.)
Come get some!
DemonRallyTeam | Fine Tuning |
CTS Turbo & RP Turbos |
RalleyTuned |
JRM |
Meister Autowerks
Spitfire EFI |
Product Apparel |
JVAB Imports |
NLS |
AP Tuning |
USRT
Add us on
Facebook | Next Event:
2013 Olympus Rally June 22-23 Olympia, WA
