Buy, Sell & Trade
misc parts for sale, gauges and VW stuff
Posted by Tom B
November 01, 2008 07:01PM
latest and greatest list of crap I have in my garage I would like to see gone:
Cool Stuff:
1 Sparco 70" H-style shoulder harness (ONLY THE SHOULDER HARNESS) for cam-lock 3" belt sets SFI Build date 10/2003 $40 image
1 Rally America / NASA / CARS Legal RALLY first aid kit $ 60
1 5# fire extinguisher with dual strap bracket filled and current 1yr certification $40
Plated and widened Rabbit A-arms (made by Cascade Autosport), same track as a Golf II (use golf axles) $150
10.1" mkI Rabbit/Jetta/Scirocco brake kit (calipers, carriers, and rotors) w/Porterfield R4 (race) Brake pads $120 (Used 40% on the pads, 80% on the rotors), great for track days.
OMP Aluminum Dead Pedal and Co-Driver's foot rest some very light surface corrosion $50
VW 02A Clutchnet 4-puck Sprung Hub Clutch Disc NIB, streetable, but I wouldn't recommend it $100
Autometer Ultra-Lite 5" 160MPH Electronic Speedometer
$180 ($218 Summit) Like New
Autometer Ultra-Lite 5" 10K RPM Tachometer
$110 ($140 Summit) Like New
Autometer Ultra-Lite 2 1/16" electrical water temp gauge
$40 ($45.00 Summit) New
Autometer Ultra-Lite 2 1/16" electrical oil temperature gauge
$40 ($47 Summit) New
Longacre Carbon gauge panel w/ Oil Pressure, Water Temp and Oil Temp gauges w/ warning lights for all gauges (burn from rear due to an arcing hot wire, almost unnoticeable) (PN 44424)
$150 ($200 new)
Longacre Carbon Start switch panel Start button w/one aircraft switch for ignition and two switches and indicator lamps for accesssories
$50 ($68 new)
Rabbit Suspension/Braking:
Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll)
Autotech Solid 22mm front swaybar $140
Front upper strut tie-bar for a 8v rabbit, Autotech $80
Polyurethane rear transmission mount $20
Poly rear torsion beam bushings $10
One power steering tie-rod end new $15
Rabbit Power Steering Rack, new (150 miles on) tie rods and tie rod ends $175 image
Rabbit rear beams $20ea
Scirocco 16v e-brake cables for rear discs $30
Stock Rabbit A-arm set $30
Misc Rabbit Stuff:
Clutch cable New $20 ea
Long American Tail Lamps $30/pr
Aluminum dash $50 no gauges can include gauges and switches for extra image
Rabbit Fuel Accumulators $20 ea
Rabbit Fuel Tank $20
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20
Rabbit Carbon fiber look PVC Sintra Door panels $50
Rabbit driver's side flag mirror $20
Rabbit H4 Round Headlamps $50
Scirocco/rabbit 16V exhaust manifolds $60 ea image
Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45 image
Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea
80 Rabbit non-defroster hatch $20
83 GTI non-sunroof ROOF SKIN $20
77 Rabbit (lightweight) doors L & R $40 ea
Scirocco 16V Cis-E engine harness for a rabbit $50
factory vw rabbit remote reservoir radiators $20 ea used/working
rabbit overflow bottles $5ea
other
4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $90/set image image
16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $240 image image image
Audi 20V NA 5cyl bottom end $40
Fuba Radio antenna and cables $20
CIS basic fuel injection setup $40
CIS-E fuel distributor and top airbox mount $60
Golf/Jetta II 42mm 16v intake manifold $25
oil pan with turbo return line welded in $20
Golf/Jetta II brake booster and 20mm master cylinder $20 image
Trades/WTB:
Wideband A/F Gauge
Golf/Jetta II 100mm axles
Golf/Jetta II Front fenders
Golf/Jetta II Small bumpers front and rear
Golf/Jetta II lower front valance
Golf/Jetta II front dual or quad round grilles and headlamp assemblies (even just individual pieces)
Golf/Jetta II 2-door doors
Golf/Jetta II Hoods
16V race internals for NA motors
Lightweight 15" 4x100 wheels/tires
VWMS Transmission components
02A Gearkits straight cut dog engagement or helical synchronized kits (Gemini, Quaife, etc).
Golf/Jetta II brake kits (Wilwood, Brembo, Alcon, etc.)
Come get some!
Re: misc parts for sale, gauges and VW stuff
November 02, 2008 01:03AM
I want the co-driver footrest. Which one of these is it? Door #1, 2, or 3?
November 02, 2008 11:48AM
#3 with a driver's dead pedal too
November 02, 2008 05:02PM
I'll pass on that one Tom.
vbares
Vittorio Bares
Audi 4k (3b conversion)
November 10, 2008 01:06AM
hmm - I want your 20v NA bottom end ! Too bad I'm clear across the freekin country sad smiley
November 10, 2008 01:12AM
Shipping a bottom end ain't that bad.
Specially as the thing costs so little.
vbares
Vittorio Bares
November 10, 2008 08:41AM
What's the preferred method of shipping? Greyhound? UPS? What does the thing weigh? and Tom would you be open to shipping?
November 10, 2008 01:38PM
for $40 I'm just trying to unload it for a friend...I'm not real motivated to ship that thing...
vbares
Vittorio Bares
November 10, 2008 01:48PM
I can imagine you're not...there are a number of Audi nuts in your area - let me reach out to these folks and see if there are any local takers...
November 10, 2008 02:14PM
feel free, if they want to pick it up for you, it ain't no thang
Bill Beers
Bill Beers
'77 G2 Rabbit
November 13, 2008 04:34PM
Hey Tom,
You may not be interested, but I've got a pair, L/R door skins that came with my '88 MKII that you can have if you want.
-Bill
November 13, 2008 08:10PM
November 14, 2008 06:44PM
Tom B,
My buddy down here wants to buy those 14" warrior tires. I remember you said shipping was more than you thought last time. Maybe we can make it up with this one.
Let me know if you think you can get those tires for my buddy down here for $120 out the door,
Thanks.
