Buy, Sell & Trade
VW Golf Parts 16v 020 Sale
Posted by Tom B
November 21, 2009 06:05PM
Doing some spring cleaning and fund raising:
16V Schrick 276 Camset $500
16V Schrick 260 Intake Cam - NEW -$250
Kent Adjustable Cam Gear $150
16V TT 276 deg Camset $400
Breather Block Off with 1" and 3/4" NPT ports $75
034 EFI 16V Crank Trigger Setup $180
Used 16V short block-Recently rebuilt, 7.5K miles of use, $450
Used 16V short block-Strongest 16V bottom end I have ever run, made 158WHP with this bottom end, some pitting in the pistons $200
Used 16V short block-80K mile bottom end crosshatching still in the cylinders , $250
2ea 6A Mallory Ignition boxes $100ea
Techtonics Tuning 16V Race header-damaged flex joint-basically brand new with one event on it-$275 ($450 new)
020 VWMS Differential-clutch type 020 diff, $750
020 starter, good used $25
2ea 020 mkIII high torque mini starters $75ea
Used 020 16V sprung hub 6 puck clutchnet disc $50
1 new double strapped and bolted 020 pressure plate $100
1 Used 020 Lightweight flywheel $50
Audi 7A 20V 5cyl motor and transmission out of a coupe $250
mkIII power steering pump $20
mk2 brake upgrade 1 complete twin piston 11" brake setup with calipers, carriers, rotors newer mintex pads and lines $300
2ea 10.1" used front brakes for mkII (calipers, carriers, and rotors) $70-no pads
10.1" RACING front brake pads
-3 sets of used Ferrodo DS3000 pads $50/set
-1 set of used Porterfield R4 pads $70
8.9" rear Racing brake pads
-1 set used Ferrodo DS3000 $50
16 14" Ronal R8 wheels, used for Rally $100/set of 4
14" Rally Tires-all are currently mounted on Ronal R8's, wheels are $25/ea
1 Good Used Hard Michelin $70
1 New Hard Michelin $100
1 Used up med Hankook $30
4 good used hard Hankooks $60ea
2 OK med Hankooks $50ea
VW Motorsport 16V Synchro Gearbox--Yes, THE REAL DEAL:
0 Mileage rebuild(BRAND NEW), AGB (16V case)
KAAZ differential, new clutch plates
VWMS 16V 4.20 ring and pinion (BIG ASS TEETH, no BS)
VWMS main shaft (24mm large mk2/mk3 input shaft spline)
VWMS 1-3 gears
stock 4k 4-5th gears
1st 2.72 (long, awesome for gravel starts, dropping into first for lower speed corners is easy, 1st gear to 40MPH!)
2nd 2.06
3rd 1.68
4th 1.13 (not too bad of a drop, but the 1.43 VWMS pice would be dope)
5th 0.91
FD 4.20
VWMS 5th 1.26 and machined fifth gear housing included in sale, basically pickup a VWMS 4th setup and it is on like Donkey Kong for the best 020 you can own for the money. I can point you in the right direction to pickup the VWMS 4th stuff if you are after it.
Make An Offer, I have it up for sale for $2750 but will let it go for less, this is a $4500 Gearset alone, when it was obtanium, it is now officially unobtainium
IM with questions
Bill Beers
Bill Beers
'77 G2 Rabbit
Re: VW Golf Parts 16v 020 Sale
November 24, 2009 04:21PM
Sent you an email Tom.
Breadbox
Chris Sample
84 rabbit GTI
November 25, 2009 01:11AM
Hey, can you send me some pics of the Ronal wheels, and what kind of tread is left on the tires?
dirtygti@gmail.com
Thanks, Chris
Fly GTI...
