Re: Stupid Mustang Question...
November 10, 2013 03:50PM
tdrrally
bigger tyres work wonders in the desert for sure
but on the gravel, yikes!
V8s work good in the desert for sure, too.
but on gravel? Hmmmmmmmmmmmm.
tdrrally
edward mucklow
November 10, 2013 05:01PM
utecht proved how well they can do
November 10, 2013 06:56PM
tdrrally
But he did not prove that a V8 was needed.
Or that he would have done better with something else....like a simple 4 cylinder engine combined with gearing.
but whatever.
tdrrally
edward mucklow
November 10, 2013 08:57PM
he did prove the lowly fox chassis could win
the v8 is just cheap torque
i have had my share of 4 cylinders cars vw toyota mitsubishi ect
i got bored with ring the guts of then
and tired of force feeding them.
just want simple fun with good brakes and great suspension
well that's the plan
November 10, 2013 09:14PM
tdrrally
Maybe he simply showed how mediocre others are? Maybe?
tdrrally
edward mucklow
November 10, 2013 09:22PM
maybe
or its about the driver then the car?
i'm looking for low dollar fun!
and i miss my starion esi-r and can't afford to rally
but a v8 fox is doable
November 10, 2013 10:27PM
tdrrally
OK I am not arguiung with you. I'm tired of Gene and a few others screaming at me about whatever bullshit they scream about. I am asking NOT FOR YOU, you have decided to do this despite all the reports of ineffective V8s are. Now we get a second piece of the puzzle highlighted above..
Again I am not arguing, I am asking for the others, those who are building 4 cylinder cars....so please think back to "your share" of VW Toyotas Misterbitchy etc and tell me what final drive rations you started with and what you did with final drives in all those cars..
And of course what KIND of cars those were.
November 11, 2013 08:04AM
Hey Ed, the 205's might be eaten alive with the torque of the V8....'specially on a dry, hard surface.
John, Ed is a pretty smart guy with cars and cost tradeoffs.....and knows what he likes....so don't let the laid back attitude fool you. And he can drive a rally car quite well; I rode with him in STPR once up on a time in the Starion esi-r, and he knew how to use every bit of that power. You can believe him when he says he would 'ring the guts out of them'; his driving was beyond the power/torque capability of a standard NA 4 banger when he first stepped into a rally car.
Regards, Mark B.
tdrrally
edward mucklow
November 11, 2013 08:43AM
the celica had a 4.30 gear from toy van with lsd from a supra
the vw had the n/a diesel gear box
the mitsu ran a 3.90 gear
the other mitsu cars ran what ever a dsm or mirage runs
the big issue i have with fwd cars is the cost of r&p
don't get me wrong i lovum all the first real racing car i ever drove has a bre spec 510
then a mix of e30 cars the m3 was my favorite
and i can't for get my fiat 131 abarth parts a plenty on that one
thank you mark for the kind words and thank you for your service
November 11, 2013 07:27PM
tdrrally
So the Celica and the VW barely had gears short enough to compensate more than 10% more than the typical tire geared them up...
More typical for n.a cars with "warm" motors on 14" tires is like 4.88, and on around 2.0 liter and 15" the old school rwd norm was about 5,1:1
Little hot 1.6 motors are happy with 5.3
My Saab was born with 4.88---and tall tires maybe 64cm tall so it got initially 5.83 when it was a little motor on a twin 40 Weber DF1, and when it got more powerz via 2 x 45 DCOEs, it got the great 5.45
And you're on the money about the big drawback with FWD cars being the cost---and the bother---of useful alternate final drive..
Dana 30 and Toyota rwd ring and pinion sets are between $130 to $235 new..
And added to all the other woes of FWD is the fact that to get short enough ratios for reasonable fun with that fixed distance between the shafts it was necessary to make very small pinion gears usually cut right into the shaft and below maybe 9 teeth, I'm told tooth profile is compromised--and there went reliability.
So most went to around 4,27 final drive with bigger pinions, and then made the gears make more reduction...ie 4th like 1.35 and top 1.16
Do the math 4.27 x 1.16 and overall in top= 4.95, right around the old 5.0 to 5.1
How do you suppose the Toyota and the VW would have felt with 20% more torque everywhere from idle up to redline?
That's why a V8 isn't needed. Right parts are.
tdrrally
edward mucklow
November 12, 2013 06:51AM
i always ran the best parts the budget would allow
i would rather spend my cash on suspension, brakes and lower the weight of the car
the 300lbs of torque at 3200 rpms the v8 makes will work fine. and be turbo lag free
toyota 4.30 gear from a parts yard, at the time was $35 installed
the 4.30 wth 22re engine and 24" tires was almost to short sometimes. it works great at an autocross.
fwd r&p are not cheap, i used the diesel boxin the vw (free), lowest gear set with 13" tires it was ok
i would rather rally on a budget than not rally at all
if that means stock bits that get replaced as needed then so be it
if i don't like the mustang and or the v8 i can change the engine or sell the car to road racer or go road racing
i would love to build a celica tct or 240rs replica in the future and maybe i will but for now its american iron
celica tct
240rs
your input is always welcome, i do agree the 4 cylinder cars need more gear
but they all need better suspenders !
November 12, 2013 10:47AM
tdrrally
celica tct
240rs
OK. you know that this is more discussion for those guys who don't know this shit rather than arguing wif youse, OK?
The lurker to poster ratio is pretty high and many guys have never experienced like VW 4.2 or proper 4.88 or 5.1....
And yes the cost of the right stuff is higher and that's one reason I push Dana 30 for smaller stuff cause the price for new gear set is so low---$135-175 is today cheap for the 20% more torque gained at every rpm. ($35 is better--I got my whole Supra diff assembly with LSD and 4.3 for $32.75---and since Toyota 8" is so popular with the truck guys I got a 4.1 set for $10 and a 4.3 for $15 off Flea-bay)
The one thing that short ratios requires however is a motor that can happily rev to about 7000 or we lose top speed...my little Saab revs to 7k and has a top speed of right at 105mph w/ 62 cm tires..
Maybe those things you had wouldn't happily do 7000..
That's the beauty of motors that make plenty of torque: you don't have to gear 'em so short, and 4.3 works perfectly and the box still has a useable 1st..
tdrrally
edward mucklow
November 12, 2013 12:38PM
i agree for someone just getting into rallying or racing in general
START WITH A SMALL DISPLACEMENT CAR AND LEARN HOW TO DRIVE!!!
TRIPLE CAUTION OVER CREST!!!
after you have balled a couple of good cars up then go from there
my celica gts had a 7.5 supra irs with a stock lsd and the van gear and a near stock 22re engine, great fun good torque ok power
the starion was more better by a bit
November 12, 2013 01:48PM
tdrrally
Yeah I could see that. Those Mitsu things I've buuilt a few good ones and made 'em short stroke so they woul be happier revving but the Starion motor/cam/box/final drive did work arf-fully good. Big strong diff in back too, fawking heavy! (hell the crank makes a volvo crank look noodly, and the old Volvo cranks are bigger everything than small block Chevy)
Similar heads betwwen the MrBitchy and Toiletta, difference is it is hard to make a det resistant n.a. HIGH COMP version of either, but wif turboz, who cares! Low comp ,turn up ze booost..
Have you ever sat down and cranked out numbers like
"Motor A--2300 SOHC Turbo--
-240 ft/lbs x (first gear ratio) x final drive = xxxx ft/lbs
-240 ft/lbs x (second gear ratio) x final drive= xxxx ft/lbs
-240 ft/lbs x (third gear ratio) x final drive= xxxx ft/lbs
etc
Then "Motor B----xxxx-xxxxx"
etc
Very interestink, Schmart.......ask Siegfried would say...
tdrrally
edward mucklow
November 12, 2013 03:52PM
thought about a 2.3t, but the 5.0 with an auto and rear gear tba (3.27 or 3.55) and 26-27" tyre
no plan on big power 225 hp and the torque will do for awhile
real focus is on suspension, brakes and a diet for the car and i
its not a beast but it growls like one
more than once thought about an elsinger 2.3t in an xratty or foxtang, run like a cossie and cost like a pinto
