Racinkid13 Max Mod Moderator Location: Durham, NC Join Date: 02/04/2009 Age: Midlife Crisis Posts: 611 Rally Car: 1983 MKI GTI |
I found out why my computer wasnt working. It had the universal speedo probe and i had bypassed that when i installed the new speedo cable. Not knowing what it was for exactly. The old pseedo had twisted off and left a small piece jammed in the probe. I was going to put the computer in my truck.
1. can I use a wheel probe in place of the speedo? 2. which wheel should i be placing the probe on or should i use a probe on the driveshaft? reason im asking is i see on the pinout plug-ins for 2 probes and a speedo. Edited 1 time(s). Last edit at 12/23/2013 02:41PM by Racinkid13. |
Wheel probe proximity sender has been the smart choice since they became available back in the early 80s...only hard thing is fabbing some bracket to hold it and at least 4 stud heads to look at within 1/4" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
johnhuebbe John Huebbe Junior Moderator Location: St. Peters, MO Join Date: 08/31/2012 Age: Midlife Crisis Posts: 283 Rally Car: 1970 VW Beetle & 1991 Subaru Legacy |
What rally computer do you have? It is best to put a probe on an un-driven wheel. It lessens any wheel spin you will have. Although nowadays with notes, an accurate odo on stage is becoming less and less necessary (unless you get lost in the notes) |
its a terratrip. 202 i think? John, its going into the Dodge. The wabbit is going to a new home. |
What Doodge? Pick up? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Creech Scott Creech Senior Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
Boyz gwan to Norf Caroliner, hain't no halibuts in dem hills. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I know someone posted this somewhere, due to me asking this somewhere. But im losing my mind and cant find it anywhere.
I thought someone told me I could use the signal wire from the ODO and tap into the signal wire the truck uses for its ODO. Is this true? With helping our in Sandblast, Id like to be more helpful. Step one is getting this Terratrip in there. Then the HAM. |
tdrrally edward mucklow Mega Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
if I remember right, most rally odos need some sort of divider/amp/??? adapter when being driven from a Vehicle Speed Sensor (vss) like you're asking.
My Monit came (from ebay) with one that I wired into a VSS line on my 4Runner for sweep/volunteer usage, works great. looks like maybe you need a terratrip "Dual Sensor Interface"? http://www.rallysport.ca/rally_equip/files/Terratrip_Dual_Sensor_Interface.PDF KF7RWG
http://www.utahrallygroup.com |
Not Trolling Keith Morison Godlike Moderator Location: Calgary, AB Join Date: 09/15/2015 Age: Ancient Posts: 340 |
Yes, you need the 'prescaler' box to use VSS signal with a terrortrip (or brantz)
Wheel sensor on an un-driven wheel is best if you can do it. I'm now using a GPS based sensor on my Coralba which makes it a bit more portable and easy to install. Sweep trucks with working odos are a nice thing to have. First Rally attended (2000), First Rally competed in (2001) Cars Built (1), Engines Built (0) Cages Built (0) Driver (8), Co-Driver (47), Drivers (19) Clerk (29), Steward (1), Official (17), Volunteer (5) WRC Spectator (1), WRC Photographer (6), WRC Observer (4) Rallies attended (120) Countries attended rallies in (11) Last Updated, May30, 2022 |
