3000 gt vr4
Posted by Drew
Re: 3000 gt vr4
July 15, 2014 05:09PM
Josh Wimpey
I'll be $6k in the hole when I'm done putting the Quantum together. I don't want to find out that I could have just bought an Evo.
No problemo, if your Quantum is nice, I will buy it from you :-)
Not after all the heartache smiling smiley
We're up to 82.5mm bore MC block, 7:1 compression, ported NG head with the GOOD valves that won't fall apart with exhaust temp, cut-down NG intake manifold, and I'm about this close to throwing a 55mm Precision turbo on the thing because I will have some headroom with the 52lb injectors and detonation should be no issue with the lack of compression.
Not a competition car of any type in the least, although I may take it to the dragstrip every now and then to make people wonder what the hell is with the funny-sounding "Volvo". If I had a goal, it would be a nice 80s style laggy turbo car that could put down 370hp at the wheels, because that's higher than any other ten-valve engine I've heard of in the US.
Edited 2 time(s). Last edit at 07/15/2014 05:26PM by Pete.
Re: 3000 gt vr4
July 15, 2014 05:32PM
Which valves are those?
Re: 3000 gt vr4
July 15, 2014 07:17PM
A small chunk of my cash outlay went to 034 Motorsport smiling smiley The valves and... other stuff.
Re: 3000 gt vr4
July 15, 2014 07:24PM
I need to see some pictures of this thing!
Re: 3000 gt vr4
July 15, 2014 07:36PM
Are you serious?
That's sad. TONS of 350-380 hp 8v Volvos out there...
Re: 3000 gt vr4
July 15, 2014 08:29PM
Are you serious?
That's sad. TONS of 350-380 hp V8 Volvos out there...
Fixed.tongue sticking out smiley
Robert Culbertson
Out of this dumpster fire
Re: 3000 gt vr4
July 15, 2014 10:32PM
Are you serious?
Ha! As the recent owner of a 302 powered Volvo, I can say that the handling is barely changed from stock. Can you tell there's a bit more weight up front? Yes. Does it really effect the cars handling? Not really.
Re: 3000 gt vr4
July 15, 2014 11:51PM
Are you serious?
He's talking pretty specifically about 10v audis. Not many people bother getting the 10vt motors up past 300. The 20v is available enough that its almost a wash to put together 350hp 10v vs 20v. Plus if you buy an s4 and part it out people actually want the parts. If you buy a 5k donor you practically have to pay to get rid of the shell.
Re: 3000 gt vr4
July 15, 2014 11:54PM
plus volvo was nice enough to put the exhaust on the other side of the head.
Re: 3000 gt vr4
July 16, 2014 01:22AM
Volvo was NOT nice enough to pair the engine with a stout all wheel drive drivetrain.
And yeah, it IS sad that people make more power with the four cylinder 8-valve VW engines than the five cylinder engine that is more or less the same engine with another cylinder stuck on the end, with a bottom end that is just about indestructible, but the realities are that once you get much past just turning up the boost a little, it's cheaper per horsepower to get a 20-valve engine since you'll be doing a lot of the same things regarding fueling and ignition and such but the 20 valve allows so much more breathing room tuning-wise and real estate-wise, so nobody in this country bothers.
I've heard of 700+hp 10-valve motors, but not here.
Edited 1 time(s). Last edit at 07/16/2014 01:27AM by Pete.
Drew
Drew comer
1967 Cortina GT
Re: 3000 gt vr4
July 17, 2014 11:45AM
I look at 3000 gt vr4 as what the ford/mazda probe gt should of been
Ask, listen-read, research, learn, weigh, execute, then let er rip
