I'm sure you're right Gene - I even suggested we were probably talking fractions of percent in performance and this is more of an exercise in theory than it is anything else. But, given a situation where the tooth sizes and gear strength are similar - understanding this can help in deciding on the driveline bits.
Good point about parasitic loss to the oil... So this ALL points to a taller box and shorter final drive, assuming everything is available in a strong enough package. |
Yeah, always been baffled that so many buy the widest HEAVIEST tires like 17/65 Michelines and those Pirellis that weight 50 lbs each for their 165 bhp Sub-a-rats. They hain't Loeb or Gronholm, they don't drive anywhere like Loeb or Gronholm, they don't need tires like KLoeb or gronholm... And if they bought sensible tires all us lowly 2wd turbo guys could buy their tale-offs and then spank 'em with their own used tires. Note the typical propshaft is 2.5" with 0.088 wall tube....not very difficult to rev up.. I'm more concerned about reciprocating weight in all the old school motors most are using: rods and especially pistons. They completely stop and then start again twice every single revolution of the crank....rottating things have some small relative speed change (its already spiing 6000, and it drops to whatever but not much on a gearchange and you just have to change its speed maybe 30%, not slow it down (energy used) then speed it up, then slow it to a stop, the speed it up 100 times a second @6000 rpm. All I can say is OI!) I think this is a case of: <object width="420" height="315"><param name="movie" value=" ?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always">< John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Not really John. It is about looking to optimize a tiny teeny bit of performance, or at least understanding how the choices come together. But if you can optimize each component a little it turns into a larger gain when you bring them together. Specificlly, this is about what's between the transmission input and axles. Engine or wheel/tire gains are great and almost certainly more effective (hell, wheel scrapers are a huge advantage on wettish events.) But that's outside the scope of what I'm batting around here. (Admittedly - even when I first brought it up - a purely 'bench racing' discussion) |
Optimizing is always good as long as the benefit is realisticaly weighed against cost and gain. Obviously if 2 different diffs are available and one is trash ....but we don't want people to focus on micro-tech stuff if it costs a bazillion dollars and gives back $20 worth of return. Common sense needs to prevail, always in short supply with racers tho.
Just thought I'd bump this for all the guys building their nice RWD cars now... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Clayto Clayton McCrary Mega Moderator Location: Olympia,WA Join Date: 07/04/2013 Age: Possibly Wise Posts: 161 Rally Car: XRatty purchased. Now build it!! |
Got an extra Xratty sitting right over <------ that ways about 25 feet. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yes, I have gleaned the car from a pic somewhere deep in the website. I'm a noob to competitive Rally but not a noob to rear wheel fun! My first rear wheel car was a 84 supra with a great torque band. Sadly I will have to wait on the Xratty But I will keep that baby in mind |
Reamer Jeff Reamer Super Moderator Location: Marlette, Michigan Join Date: 08/14/2010 Age: Midlife Crisis Posts: 489 Rally Car: Subaru |
If or when I build a rwd car i would run a used Nascar trans and a quick change rear end. Any gear set you want from 218 to 915 final drive for $49.00 and an aluminum tube magnesium housing rear end for around $400 used or spend the big bucks and buy new for under $1500. Put a used black gold diff for another $300.00 and you would have a damn near bullet proof with any ratio for any conditions to at least 850hp. They may take more then 850hp but thats all I can say for sure because thats the most power Ive put down with one on tarmac.
As for OL verses PGT who cares theres no PGT cars to race with and the rules suck! OL to me would be the better choice of the 2. If it were fwd or rwd I would go rear because of how cheap and easy the build would,could be. Thats my 2 cents any who. First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
