mhooper Michael Hooper Ultra Moderator Location: Georgia Join Date: 09/08/2006 Age: Midlife Crisis Posts: 65 Rally Car: ae86/gone |
Interesting... I too bend trailing arms on my e30 with no big incidents to speak of... Analyzing them it is very difficult to determine exactly how they are bending... I also considered hydraulic bumpstop in factory spring location... Hmmm. I've bent them with cool overs and with convertible springs so not sure the coil over is the culprit... |
Expand on this. That's an "assertion". How was this thought thru? Show homework. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Just think of it from solid state with bump stop fully compressed.
Now think 100 lbs of force into tire levers off the bump stop and pulls, pushes, twists on the sta to beam mounts. As the.bump stop is moved closer.to the wheel the force gets greater on the mounts. Grant Hughes |
Nate.Vincent Nate Vincent Mega Moderator Location: Pomfret, Ct Join Date: 07/29/2014 Age: Midlife Crisis Posts: 29 Rally Car: BMW 318ti |
I was planning on copying what Prodrive did on their e30s. Coilover mount in double shear too.
This weekend I helped a friend and crewed for the FCPeuro e30 at the AER race in Palmer Mass. One of our drivers got pinched and we had contact on both rear wheel. chewed up one of the tires on one side and on the other it contacted the wheel (and some other stuff). It knocked the trailing arm out and we finished the last three hours of the race with toe out in the rear. It seems these arms are certainly the weak spot. |
![]() It may be fun but it seems to cloud reasoning... The arms are weak..In normal trailing use they do not need to be strong as all impacts just bat the arm away (up).. No so when force comes from side. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
http://www.eeuroparts.com/blog/5665/rcr-sets-the-bimmer-up-for-rally-americas-snodrift-this-weekend/
If you scroll down in that article I have a pic of the trailing arm... I can send u a bunch more if u email me at hooprally at g mail.. Little hard to tell in that pic but there is a 1.25 tube between the trailing arms then 16 ga sheet stitched in top and bottom... The support to the shock mnt is more to help with lateral loads.... I have yet to see a dual shear modification I like... (Soneone please post something nice to show me how!). The issue I have with what I've seen (flat bar coming off t arm to catch outside of shock) is it looks like a big lever to oil can the trailing arm on a big hit... I will prob go that route of dual sheer eventually but want to really think it through first. |
Hey guys,
Life has changed and another opportunity has come my way. Now I need to get rid of this project. -I have a 95% complete caged shell (needs rear braces and rear tower tied together) -Bilstein 50mm front suspension (8" travel) with 10" travel rear Bilsteins and extended rear towers -4 Mounted Michelin ZEL80s on BMW basketweaves -3 spare Michelin ZEL80s -BMW M52 with m50 intake and aluminum flywheel and proper clutch -Many other spares and bits I'm open to offers on the whole thing or I can separate the parts. Thanks |
