ae86 build.....
Posted by urr
urr
Andrew Sutherland
Subaru, EVO, Honda, Husky
urr
Re: ae86 build.....
February 27, 2008 02:01PM
> urr Wrote:
> > yeah...the engine is pretty text book. Goal
> is
> > 200hp. 7A built bottom end (1800cc), proper
> head
> > w/ cams, header, itb's (stock) and a
> stand-alone
> > ems.
> > Long term project....
> Andrew, why not the nice 3GSE motor, make the 200
> bhp goal easier and get some of those torque
> things too.
> I just can't see the value of any 5 valve head
> when we are in classes that allow modification of
> 4 valve heads, and between the 4AGE and the 5
> valve, it really is the ITB setr up which allows
> the extra air in, not necessarily the extra little
> valve.
> Torque is good.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
Torgue is very good!! I happened to pick up the 20v thingy for $325...so it seemed like a cheap decent option. I haven't looked into the 3GSE yet...but I will!
urr
Andrew Sutherland
urr
Re: ae86 build.....
February 27, 2008 02:06PM
Dazed_Driver Wrote:
> Ok, so you've got the engine then, what are you
> doing for the heater lines? also, are you
> rebuilding it? When did you pick up the engine?
yup...already bought the motor. I can sell it for the same price I bought it if better options are out there for similar dollars.
> BTW, john said something vaguely about some SAAB
> people getting like 1 second a mile faster with
> power steering and nothing else.
I don't doubt it....just curious if anyone was running manual.
> PS, have you ever worked on the corollas before?
No...this is my first corolla. I am familiar with Ford Kent x-flow motors though and building those to make power.
> Feisty Peacock?
Re: ae86 build.....
February 27, 2008 02:19PM
urr Wrote:
> john vanlandingham Wrote:
> Goal
> > is
> proper
> > head
> > stand-alone
> > > ems.
> 200
> > things too.
> head
> modification of
> 5
> allows
> little
> > valve.
> > Torque is good.
> > John Vanlandingham
> > Sleezattle, WA, USA
> > www.jvab.f4.ca
> yet...but I will!
The 3SGE in a RWD car is way cool except for a couple little sticky points. If you plan to use an older engine you need a bellhousing that only came on diesel trucks in Australia. Toysport usually has them or can get them. http://www.toysport.com/catalog/PET%203S-GTE%20Conversion.htm
The stock intake manifolds that come on them are generally for FWD applications and need to be modified or replaced with something custom. Basically you get up into the range where you could just buy a complete BEAMS engine transmission combo from an importer more easily. Then you can buy all sorts of cool shit like this off the shelf.
http://trdparts.jp/english/parts_engine-3s-ge.html
urr
Andrew Sutherland
urr
Re: ae86 build.....
February 27, 2008 02:22PM
yeah..a quick search on ebay got me this:
http://cgi.ebay.com/ebaymotors/JDM-3SGE-Beams-5ZIGEN-Altezza-Lexus-IS300-Engine-Swap_W0QQitemZ370025406969QQcmdZViewItem?hash=item370025406969
very cool...and a 6speed! I wonder what tranny it is and what ratio's it's hinding?
I wonder how easy it is to go ITB on the 3SGE head? If someone makes a manifold I'm sure i can pick up some TWM stuff...just $$$$
Re: ae86 build.....
February 27, 2008 02:32PM
http://trdparts.jp/english/list_race-mis_sxe.html
BEAMS engines have ITB's inside that plenum already. Or call these guys they have spare Formula Atlantic engines just laying around for $25K.
http://www.hasselgren.com/products.html
Or this:
http://www.hasselgren.com/drift.htm
Can you tell I've been thinking about building an is300...
Re: ae86 build.....
February 27, 2008 03:11PM
Could be:
I.....3.79
II....2.28
III...1.52
IV....1.12
V.....1.0
VI....0.79
So skip 1st, use 2nd thru 5th go 5.3 final drive IN A VOLVO axle and you'll have a HOT car.
Or fab using the stubs of the stock manifold.
Saabfarm
Luke Sørensen
SAAB 99
Re: ae86 build.....
February 27, 2008 05:17PM
Here is the article that John was probably telling you about:
Heres a rough translation of the power steering part:
The other news about Saab is that Stig Blomqvist will soon get power-steering both in rally and rallycross.Roger Johansson has tried out power-steering last year in rallycross and got it all working.The Premier for Stigs part will be in the Swedish Rally. We have long discussed if its time to test power-steering,said Börje Jarl,responsible for the technical development of Saabs competition department. But until now we have been limited to power-steering which is not of sufficiently quick reaction.The problem is now gone.The new servo to 900 model is unbelievably quick and has great high precision.
Power-steering for Saab does not involve just the cars becoming more easy steering,now it is stable enough to also commence developing the chassis.One can use important wider tires.
I have so far done the whole trial part with servo,says Stig Blomqvist.The results are amazing.Just through putting on wider tires I can drive more than one second quicker per kilometer,which in Rac-rally would mean more than 10 minutes shorter drivetime on the stages.In addition to being of better precision than earlier, I do not get tired on long stages.
Mainly during this year,Saab will be developing the road-handling.The motor and gearbox are considered to be (tested) enough today,the turbo-motor now gives 270 horsepower and the torque is at 37 kpm.
-Luke
www.saabrally.com
Re: ae86 build.....
February 27, 2008 05:37PM
Luke, I had read something somewhere in a book, then when I got to know Ola Stromberg I aked him about it.
The book and Ola didn't mention the wider tire bit. Ola emphsised the ability to wind in 4 degrees of CASTOR for more self centering effect and I have always liked to shoot for that 4 degrees. The car goes straight till I turn the wheel, and have good "on center" feel on gravel.
AaronJMcConnell
AaronJMcConnell
Subaru Impreza
Re: ae86 build.....
March 18, 2008 07:02AM
JDM 3SGE from Altezza, bellhousing adapter to Ford type 9 with tran X gearset, choose a suspension, choose brakes, early supra IRS suspension bolts in with the MA70 8" LSD diff-get a 5.71 and a 1.5 way KAAZ-if you want to stay with solid axle, do an 8" pickup axle, not an ae86.
Re: ae86 build.....
March 18, 2008 11:05AM
AaronJMcConnell Wrote:
- MA70 8" LSD diff-get a 5.71 and a 1.5 way
Boys, the OEM Toiletta ring gear is like 6.3" or so, you don't think that stepping up to say 7.2" in a Dana 30 or 7.5" would be enough for a limp wristed 1.6?????
My lurv of Toiletta 8" is really for guys with TURBO 2.3s like Xratties and Volvos, you know manly man cars.
I like a margin of safety more than most guys, but dontcha stink.....????.
Re: ae86 build.....
March 18, 2008 01:08PM
Its only a 6.3 in the sr5. 6.8 in the GTS, haha. Dont make them sound so small. Volvo's have problems too. Like being really ugly. hahaha
urr
Andrew Sutherland
urr
Re: ae86 build.....
March 18, 2008 05:04PM
3sGE Beams - Got it
Ford type 9 - Is there an off the shelf bellhousing adapter? Seems like machining one would get pricey quick. Why not the lexus 6-speed that's bolted to the motor from the factory?
Suspension - JVL bouncers?
Brakes - JVL stoppers?
Rear End - Depends on which rear axle I use. I was thinking Volvo w/ Dana 30, Watts set-up. Never seen the early Supra IRS bolted in...I'll look around.
Re: ae86 build.....
March 19, 2008 12:02AM
JVL currently doesnt have any brake kits- yet.
I dont know how hard to bolt a supra IRS in is, I should have looked into that... But, as that is set up for straight axle, it may be goofy. Yes there is an off the shelf adaptor for the type 9, its from Fensport. Theres another one from the UK too, but its just as pricey. Since you want to run a 3sge, just run the RWD one and use the RWD tranny. It might fit... kinda?
Re: ae86 build.....
March 19, 2008 12:12AM
Yet. It looks pretty damn simple. I've gotten Saab 900 discs under 14" before and that was 20 years ago, I've learned a wee bit since then.
Not so much goofy as no need.
If Ford Escorts can still hang with in the hardest rallies where they're allowed against virtually anything and all they had was a solid axle and LOOOOOOOOOONG links, then YOU CAN TOO with a solid axle.
It's one of those "potential incremental tiny % improvement" things for unknown but certain pains in the asses of time and money.
Yes
Making tunnels bigger is easy. It can fit.
> Feisty Peacock?
Re: ae86 build.....
March 19, 2008 01:53AM
Well, I think its an issue of length. Where the gear stick ends up. I *think* the issue Dan is having with his "kit" is it ends up way the fuck behind you. Or at least way the fuck where it shouldnt be. But im not sure.
