Re: audi 80 back at it!
May 15, 2012 01:47PM
grant, I had to go look at the rules, thank you for pointing that out. Somehow or another I don't remember ever seeing those dimensions. That really helps, but can I put a bend in it?
May 15, 2012 02:50PM
Yeah, though I'd suggest following the a-pillar support recommendations (8.3.2.1.4). Keep it around 20 degrees and keep it straight from the side view. I usually just try to get it as far away from helmet and close to contour of body shell. On the 4 door, I made it so that the maximum linear inches of the bar is right against the b-pills to allow it to be stitched to it. The bend is just into the rear door opening and the bar meets the main hoop just at the top of the lower bend in hoop, or basically where yours is in that pic.
May 15, 2012 06:16PM
You guys have been busy beavers
May 15, 2012 06:39PM
I'm going to suggest following Grant's thoughts. I don't care for that bar the way it is. Keep it straight from the side, make it a bit smaller. Remember that a HANS may hang up on it as it is AND someday an E_Crew guy may need to get in there to help someone.
May 15, 2012 09:59PM
Lets hope not!
I think I can make that happen, thanks for the help guys.
shiza
Dan Norkus
94 Integra
May 16, 2012 01:43AM
Are you working this Saturday? I'm planning on doing the rallyx but I can come by after.
May 16, 2012 08:32AM
Depends on casey's schedule. I'm pretty much ready for welds. If i'm not out there on sat, I'll probably be out buying paint and supplies.
May 16, 2012 01:33PM
So the A pillar support bar isn't shown...remember you can bring it down the front leg from the header bar 4" to give additional steering wheel clearance. Also you can put a 20* bend in the bar to bow in out away from the steering wheel. Bar must appear straight from the side tho. Bend has to be east to west, not north to south so to speak.
May 17, 2012 08:44AM
Like so?
Took this pic, just cause it was cool to see a seat in there
I actually finished up just about everything as far as cage bars, but my phone died so I didn't get pics with the A pillar supports or my cardboard dash mockup in place. Final welding Starts on FRIDAY!
May 17, 2012 09:49AM
Thats good! Great progress.
June 14, 2012 01:42AM
Tonight I coerced Casey to come over to weld more of the cage together. Here are a couple crappy cell phone shots of that
One more good welding party scheduled for friday and I can start prepping the interior for paint. open to suggestions, as I'm just not creative when it comes to colorschemes. If no one has a good answer the car may just end up being painted white. Although since mr Norkus mentioned it red is growing on me.
June 14, 2012 01:52PM
red is expensive but more showy. White hides body work errors and is much cheaper and easier to touch up and match later on.
June 14, 2012 05:13PM
PLus, it is so much nicer working in/on a brightly lit car at night. A white interior will light up like daytime with one work light shining on the roof or floor.
June 14, 2012 05:37PM
And any oil, water, leaks of any kind show up easier on white cars and thus are easier to trace/diagnose.
shiza
Dan Norkus
94 Integra
June 14, 2012 06:04PM
The white impreza with the red cage at the Idaho Rally looked sharp. I would consider that for sure. I like red a lot though. You could always do white inside and in the engine bay then red outside.
