Bilstein 46 mm Universal Rally Shocks
Posted by NoCoast
Re: Bilstein 46 mm Universal Rally Shocks
December 04, 2011 11:05PM
Are the threaded sleeves steel?
modernbeat
Jason McDaniel
December 05, 2011 12:14AM
Yes. From memory they said they were a steel alloy and the top 2/3 were going to be zink coated with an olive green color.
December 05, 2011 09:29AM
Ok...so this is cool.
But...who does Bilstien really believe will purchase these?
Joe Rallyist doesn't have the ability to machine that top pin, let alone know the dimensions, etc. He also doesn't know the proper patterns for the "ears".
Is Bilstein planning on just selling these as DIY? type kits? and marketing them to people like JVAB? or other Rally prep shops which have the tools and know how to properly set them up?
Or will Bilstein be putting together "bolt on" kits, for popular applications like Subaru Impreza, Evo, etc? Bilstein could easily take the dimensions from their Subaru stuff that exists and buzz on some ears and machine the top pin.
Kinda looks to me that they just brought in a 50mm insert from Europe, and made a CAD Model, and then made a 1 page hand out.
Still cool....but couldn't they just bring in a pile of those part numbers, and parts so that JVAB could have access to them?
December 05, 2011 04:26PM
Bret Norgaard
Retail is $549 per kit and the spring seat/hat are a separate kit. Customers will need to use a barrel spring (2.5 ID to 4" OD) from a manufacturer of their choice such as Swift or Eibach. More detailed information will be available fairly soon on our website.
December 05, 2011 05:36PM
Bret Norgaard
And what is that you posted?
December 05, 2011 05:47PM
I bet a certain guy out west could build and market a comparable set up with threaded tops and maybe ears for a better price far before bilstein could launch its product. just saying.
December 05, 2011 06:40PM
Bret Norgaard
Was the info sent to me, not the setup I want/can use with ease. But I was curious and fired off a question. That little gem of a quote carries all the info I have, other than a PDF of the above pasted advert.
June 28, 2012 01:46PM
Think these will ever actually be available???
Saw this on another forum posted by AllWheelsDriven:
"We've been steadily increasing our distribution and production of them over the last several seasons. Bilstein refers their custom rally build applications to us directly, regardless of make/model. They are a purpose built, proven, gravel rally strut. Built to suit your application, and go hit the gravel. Knobs, bits and multiple adjusters will just add to the cost of your services, especially if you're not diligent about taking care of them between events. That's if they don't break or fail between events.. it's very common. 20 clicks don't do a thing when the adjuster is broken. If you want adjustable external reservoirs, we can do it.. but the majority of our client base doesn't want to pony up another $1300-1500 for the option.
We're building 40s now, but will have 50s available once the parts are readily available in the US. The price will increase with the 50s, but that's tbd based on what parts will cost. The ears/gussets we use now will adapt to the 50s."
I've also heard that Team O'Neil will be exclusive on east coast and rumors that there would be an exclusive dealer on west coast also.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
June 28, 2012 07:08PM
2 exclusive dealers.. very exclusive... I don't see why more dealers would be a bad thing (as long as they don't put out complete junk)
So would it be possible to take an 8" and limit the travel a tiny bit (to hit 7.5) for the fronts? and take a 9" and limit the travel quite a bit more (down to 210 mm)
maybe with a metal bump stop? or even a bit more rubber bump stop (it only compresses so far right?)
exciting times!
June 28, 2012 07:30PM
A1337STI
Particularly with a limited market, more dealers means that each dealer does less business and the economy of volume may not work.
June 28, 2012 08:21PM
A1337STI
exciting times!
Well of course we can limit travel with say a nylon disc between the rubber bumper and the body but that doesn't change the overall length.. Thing that's worrisome with the decisions being made by marketing is that they probably don't understand how much we want an installed length and travel and insert to overlap.
We want the overlap as wider spaced bushes are more stable for bending than closer spaced, we want travel to whatever is known safe for OEM CV joints and we need to keep the cars low enough to go around corners since we're not making Baw-Jaw trucks..
Somebody who wants to be nameless was saying that "they heard from somebody who had spent hours calling every high end (Reiger, Proflex, RSSPSSPRSS etc) and this guys said" the decision has already been made on the West Coast, and it was alleged its going to someplace with zero previous rally experience and with clientele who spend vastly huger sums of money than 98% of the North American entries, and defiantly in the "way up there' range.
It doesn't bode well for anybody here, especially the announced decision to only supply complete insert/lower tube units and no individual inserts, a very puzzling decsion when I know piles of guys who would like to replace their 4-5 year old, already been straightened a couple of times 50s, including the ones from that other company which "have never had seen manufacturing failure in use ever".
There is obviously rampant politics and smearing going on behind the scenes and I am not the only person baffled as to what the intentions are.
More sales is more sales and there are always ways to get stuff done, the question is as always, at what price...
Anyway I have to go swap out a sheared gear in the band saw, it died just as i was beginning to saw up blanks for those 20 50mm tubes I have had done for years...And I guess i better get started on the 50s for AJs beast of an Audi....
June 28, 2012 08:28PM
A1337STI
That's why the decision to select places who will be doing this kind of work as a sideline in addition to already existing shops/businesses seems odd.
I've done scores and scores of cars, probably a couple of hundred since 03 and its nowhere near enough volume to soley do suspension. Even for me doing 2 or 4 strut tops at one time is a losing proposition when costs of what a CNC lather should be making per hour are considered.
Expect high costs and long delays.
June 28, 2012 10:37PM
A1337STI
John--
You need to write some PRESS RELEASES and IMMEDIATELY RELEASE the EXXXXXXTREME details of the JVAB SOOOPER BITCHIN' line of products and how they're going to TAKE OVER THE WORLD with their MONSTEROUS RED BULL ROCKSTAR ENERGY!!!!! Did your marketing department suffer from Polio in its youth? (nudge, nudge, wink, wink) Get with the PROGRAM, man, get AGGRESSIVE, ULTRA-VIOLENCE!!!!!!!
Or something like that. Basic 40-50mm Bilsteins without eleventy billion adjustments that barely change anything would solve the suspension issues for 90% of the people out there who want to cone squish, track day, or rally. My black XR4 street car can go scary fast on gravel on street tires with the 41mm Ford things and prototype JVAB rears, and they're not even installed right yet.
Being able to get the Bilstein 46/50mm inserts in bulk would be GREAT for everybody who needs more than the Keeps You Bouncin' option (which for cheap money, I can't complain), can't stand the wikkkked hahhhd Konis, and doesn't want to spend $5-8k for the RSSPSPSPSPSPSSSSP for gravel or Moron....errr Moton things for track/really ridiculous cone squishing (I'm still trying to figure out why the hell you need remote reservoirs on a cone squishing car...do the shocks even get warmed up in a 58 second run?).
Enh, I don't know. Seems like Bilstein has the potential to get a great product out there that would bridge the gap between rice garbage and one-percenter suspension, but limiting yourself to two "exclusive" dealers would stifle development and distribution, IMHPBRIO (In My Humble Pabst Blue Ribbon Influenced Opinion).
June 29, 2012 09:09AM
You owe me a keyboard. Now I'm going to go get some coffee that doesn't have spit in it.grinning smiley
Edited 1 time(s). Last edit at 06/29/2012 09:10AM by aj_johnson.
July 23, 2012 09:20AM
spoke with Tim Oneil back at NEFR, it appears the wait is almost over:
Hello Brian,
We will have a date on price and availability on the struts soon, we will be doing training next week and product will follow, thank you. Tim
