Re: XR V2.0 Build thread
April 28, 2012 11:59PM
Made a mount for the rally computer today. With the pushed back co-drivers seat, it needed to be about 12" or so in front of the dash. I have seen some pretty scetch stuff, like 1.5" dom tube pointed directly at the co-drivers chest.... Anyway, I wanted to make an adjustable mount, that attached to the tunnel. After sitting in the car today with the mock up, I just could not get the angles to not have something close to her legs, so I totaly changed the design. This one will be bolted to a tab that is on the A pillar support bar, just below the dash, and come across the dash. Fully adjustable up/down/in out, and the computer is on a ball socket so it can be angled any way she wants. Also, the shaft telescopes....
modernbeat
Jason McDaniel
April 29, 2012 08:57AM
That handbrake looks like it will take out the driver's knee.
Jason McDaniel
April 29, 2012 10:13AM
You know I was sitting on the deck just the other day wishing I had an odo ...smiling bouncing smiley
Looks nice. I'd put a washer or xbar on the cinch bolt for ease of tightening. Great adjustability.
cossunist
Stephane Hanna
what rally car?
May 01, 2012 09:02PM
Do taco gussets not need inpsection holes?
May 01, 2012 11:23PM
Not that I know of. Lots of those holes are just to look cool......
May 02, 2012 12:09AM
cossunist
Technically there is supposed to be a small 'C' shaped cut-out at the bottom but it is essentially worthless as you can't see enough to worry about, so we don't. It would only show the weld on the inside of the joint, which is a very easy weld to complete.
cossunist
Stephane Hanna
what rally car?
May 03, 2012 10:04PM
cossunist
Very well, carry on.
JVL
Each minute you spend in the garage, you get weaker. And every minute Charlie spends on gravel, he gets stronger...
May 03, 2012 11:08PM
Quick thread-jack for Sean....
What sort of mileage do you get on stage with the XR4? Just trying to come up with a baseline number for this weekend's Lemons race.
Thanks!
May 03, 2012 11:55PM
I don't know for sure. 6-8mpg.
May 04, 2012 12:03AM
Thanks. It's something to start with!
May 04, 2012 09:34AM
You are better off calculating in gallons per hour. That makes the math easier to do on the fly. Then you schedule fuel stops and filling up jugs based on time. Figure about 5-7 gal/h depending on the yellow flags for a car making ~150hp at the wheels.
May 04, 2012 03:00PM
....at our level, fuel weight doesn't matter, just fill up the car, you never know what is going to break next.
May 07, 2012 04:23PM
We seemed to use about 7-7.5 gph at Loudon Annoying. It came in on fumes a couple times after long stints.
We still managed 14th overall after a head gasket on Friday, power steering line repair (bzzzzzt with the MIG, yeah the PS will likely be getting deleted) Friday night, and a master cylinder replacement Saturday morning.
Not bad for our first time out...
May 20, 2012 12:15AM
The car has been at the body shop for 3 weeks so it has been tough to get to work on it. Took it over there because they were slow, then the flood gates opened...... I have been going there after work till 11:00 PM or so 3 nights a week, and sometimes a weekend day if they are there. Finished the last couple small pressing fab things, and samded on stuff till my fingers bled. Got some booth time today and shot the interior, engine bay, all the jams, insides of the doors and hatch. If they finish up the body work this week, I can shoot the color next weekend.
May 20, 2012 12:41AM
wow, care to share how any prep tips for the interior?
