Richard Donovan
Richard Donovan
Re: do you have a welded front/rear diff, did you pre-heat?
September 03, 2012 09:36PM
no worries Sean, I'd rather do it like this than like you said "broken in one month".
September 04, 2012 02:50AM
Richard Donovan
That's odd, there was a gasket there when I removed it.
So I put back what I found.
What I'm saying is you can leave the gasket out and just use silicone.
September 04, 2012 05:46PM
b00sted
For future reference: Brake Cleaner + Welding = no-no. http://weldingweb.com/showthread.php?t=32501
Isn't that only with certain types of brake clean?
September 04, 2012 06:03PM
b00sted
I think we just figured out what's wrong with Grant!
I thought that was why the have regular brake cleaner and the non-chlorinated kind.
September 05, 2012 09:35AM
There's a picture somewhere from the old Galapago house garage where Steve, Mark, and I are using the diesel jet heater thing and a can of brake clean to make big fire balls. In the winter. In a closed 2 car garage.
That's why we ONLY have the non-chlorinated kind. smiling smiley
b00sted
David Barrett
September 06, 2012 12:30AM
b00sted
That seems logical. Phosgene is Cobalt(II) Chloride. So if there's no Chlorine, there's no way to produce Phosgene.
September 06, 2012 11:40PM
b00sted
b00sted
Now I'm a pretty mellow guy, but the one thing I'm a stickler for is chemistry. Phosgene is dichloromethanone, an aldehyde (double bonded oxygen and carbon) with two chlorines. Carry on.
b00sted
David Barrett
September 07, 2012 01:33AM
I read it wrong. It's COCl2, not CoCl2. But either way, you can't form it without the Chlorine.
Richard Donovan
Richard Donovan
October 29, 2012 06:55PM
Well, it's all back together finally......... and ..... I love it!!!!!
Modulating the throttle during a slalom run on wet grass is amazing, there is actually a difference between throttle on and throttle off. Great traction on loose gravel too. The car is more predicable now.
The cornering is good, I do have to modify my line, but I needed to do that anyway. I have enough traction now to pull off that line under moderate throttle.
I do feel that the rear sway bar needs to be increased to help it rotate a bit easier now.
Thank you for all the help and suggestions everyone!
