frumby
Jason Hynd
XR4TI a slow build!
Re: 1985 Merkur XR4Ti (aka Rally Car v3.0)
December 12, 2012 09:43AM
Well, in order to be around my family and not get divorced I gave up jets that go upside down in favor of this deal. The flying is boring. The travel can be exhausting, but I've actually gotten to see parts of the world I wouldn't have otherwise. Key is to get away from the American Military wherever you go. Some of my favorite memories have been making friends with Italian bike riders and covering hundreds of miles by bicycle all over Sicily!
I'm in agreement that the GV is a waste of $$. Our entire job is to carry the Commander Pacific Fleet around. I think that Admirals are little more than spoiled politicians.
Anyway.. Good to see so many involved with aviation here! Thread creep
December 12, 2012 09:51AM
so John, lets talk bushings. I have that severe shutter under braking going on. Whats the best, rally approved way to deal with that?
December 12, 2012 10:19AM
I have to go to post office, I'll send you a set of the "Heavy Duty" Outer TCA bushes. Cheep! Cheep! cheep
December 12, 2012 10:33AM
whast your price, also ive since moved so any address you have for me is out of date
Edited 1 time(s). Last edit at 12/12/2012 10:34AM by Gravity Fed.
December 12, 2012 02:00PM
Cheap. For you this week only $30. Send the address.
March 09, 2013 06:57PM
March 09, 2013 07:33PM
Edited 3 time(s). Last edit at 03/09/2013 08:36PM by Gravity Fed.
March 09, 2013 07:35PM
well the clutch is toast after today...
Time for some T5 action...
also, what intercooler are people running for these things? Any pics of the saab 900 radiator with the intercooler installed? for inspiration?
March 09, 2013 09:17PM
2wd Cossie plus Saab 900 plus simple channel bracket (1.1 lbs) pop riveted together, line with mouse pad
90o rotated upper manifold
Nice motor mounts, too
March 09, 2013 09:25PM
well i start tracking down the radiator. what is that funny nipple on the intercooler?
need to get the transmission stuff in line too. clutch is basically non existent after today.. so might as well swap the T5 and diff if am having to pull and replace...
March 09, 2013 10:08PM
Goes to the not needed recirculation valve...Same POS as found on Saab 900s and some Portches...
The often warp and don't seal so the poor turbo has to work its heart out to try and make boost but with a portion pissing away, it can't.
also the diaphragm rips.. And they suck.
Remember the 900 rad is any year from 1979 to 1992. Look at the number of rows and the number of fins per inch...some have more than others. If you look enough you find all metal ones
Turbos have 2 flat fans, non-turbo 1 flat,, one not flat... so for 2 flat fans get turbo or n.a and swap them before carrying the junk to the counter..
Peel back the cover for the electrical leads and snip off the connecter 3-5" up the loom and you'll have two nice connectors ..
I re-wrire the fan circuits to use the nice thero-switch in the rad...and use a normal relay..
I have posted the Saab wiring many times, the fans are fed hot juice and the thermo-switch grounds the circuit, that means one skinny wire carry no juice up to an on/off switch lets you turn the fans on...
March 09, 2013 10:13PM
how much are those cossie interfoolers from ya? might need to package that into some diff swap kit stuff.
March 09, 2013 11:59PM
also, can i remove the weenie sway bar from the rear? whats the thoughts on that? figure it would apply the usual thoughts of "more travel" without it.
Edited 1 time(s). Last edit at 03/10/2013 12:00AM by Gravity Fed.
March 10, 2013 01:39AM
Yeah its junk and a joke..
March 10, 2013 12:20PM
I used Volvo 240 radiator and IC. Simple bottom bracket, IC's available at the Pick n Pull. Slightly modified stock radiator fan, new radiators for $98. 75-93 240 uses the same rad, pretty sure they comtinued to use it on the 740.
I did sun the Cossie IC and Saab combo in my street XR and it was good also.
