VW Golf rally porn
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: VW Golf rally porn
March 27, 2013 01:44AM
No problem Danny, As I said, use the Passat arms and MK3 CVs (I have never seen mk3 90mm CVs in the US) and go --- sorry for including confusing pics of two different arms, the first was from a quick google image search. No one runs the front ARB for rally anyway but it will bolt right up to the Passat arms while the mk3 arms as you noted have a different attachment point.
One. Class -- 2WD
www.quantumrallysport.com
March 27, 2013 12:43PM
Oi here's what all you Golf pervs need to see. From that contry where they're all upside down:
<object width="560" height="315"><param name="movie" value="
?hl=en_US&amp;version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param>
There's even some Honda rally car content at 31.43.
Toyally, like, awesome.
Kristof
Kristof Kiraly
1986 VW GTI
May 05, 2013 10:03AM
So, overall...there is an advantage to use VR6 widetrack setup over stock '86 GTI setup. Correct?
- balljoint position
- wider control arms
- larger wheel bearings
- heavier duty axles and cv joints
Questions concerning the swap:
1.) Mk2 or Mk3 steering rack? What tie rods to use?
2.) The wider track will cause more camber, correct? Will the top pin, thats threaded, fit into the strut mount ok? During suspension travel, will it cause extra stress on the bearing/strut mount?
Max
1983 MKI GTI
May 13, 2013 05:46PM
i just watched this whole thing. i think i found my new paint scheme for the rally car.
mke723
Mike Lindenfelser
1995 Impreza L
May 13, 2013 09:20PM
MCM (might car mods) is MAAAAAAD! Moog is funny! lots of laughs watching it...I assume its all a joke...
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to.
May 14, 2013 01:27AM
mke723
Sure it's a joke, even if it's all true.thumbs up
