240 build for stage rally
Posted by DeathCanRacing
BobOfTheFuture
Rob
None, anymore.
Re: 240 build for stage rally
September 03, 2013 05:48AM
DeathCanRacing
Found a toyota 4runner axle at the junkyard. It came with 4.56 gear and open diff. I will use the 4.56 gears but not sure if i should weld the spider gears or try to find a good clutch type diff.
Cut slots in the floor pan for the 4-link setup. I'm thinking about using 1/2 inch heim joints 3/4 inch .120 wall tube for the 4-link and 3/4 inch heim joints 1 inch .120 wall tube for the panhard rod. Does that sound sufficient?
Sometimes I look at the pics of what some of the guys are doing with the rear of their Volvo's, and I wonder If I'm wasting my time.
Justin, Its pretty cool that your able to just hop into it like this. Way to go!
Enablers, All of you.
DeathCanRacing
Justin Mason
Volvo 240
September 10, 2013 07:39PM
Justin, Its pretty cool that your able to just hop into it like this. Way to go![/quote]
Thanks Bob. I have wanted to do this for a long time, but didn't have enough time. I still don't have enough time but i'm trying to make it work.
DeathCanRacing
Justin Mason
Volvo 240
September 10, 2013 08:03PM
Making progress on the rear.
open | download - IMG_0320_1.jpg (113.9 KB)
open | download - IMG_0325_1.jpg (99.1 KB)
September 10, 2013 09:28PM
Hey there,
thats a lot of progress there!
Look out for where your seats are going to mount vs. those 4-link boxes,from the pics they seem like they are going to be close. In my car the seats are about 8 inches in front of the step-up.
DeathCanRacing
Justin Mason
Volvo 240
September 15, 2013 02:16PM
The rear is finally coming together. It will be nice not having to move it in and out of the shop with the forklift anymore. I am going to wait on mounting the panhard until i get the rear coilovers. i'm thinking about integrating the panhard mount in with the shock mount so the panhard will be as long as possible.
open | download - IMG_0329_1.jpg (135.1 KB)
open | download - IMG_0333_1.jpg (115.5 KB)
September 15, 2013 03:07PM
Now you going to double skin and then armour up and make a stout skid for the front lower pick up?
mke723
Mike Lindenfelser
1995 Impreza L
September 15, 2013 08:29PM
looks like your going to have a lot of travel, are you going to cut a channel for the drive shaft too?
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to.
September 16, 2013 03:15PM
Backside, gotta make it so the stud heads clear
Zing zang!
Ta daH!!!
Toyota 4 runner, now a Volvo.. Nice strong 8" unit, bigger halfshafts than many Ford 9" units..
FOR A FRACTION OF THE PRICE
Now just gotta drill a few holes lessee x is 2.125 y is zero, then x is .886 x Hmmmmm
DeathCanRacing
Justin Mason
Volvo 240
September 17, 2013 08:01PM
Thanks for the input, John. I will add that to the to-do list.
DeathCanRacing
Justin Mason
Volvo 240
September 17, 2013 08:06PM
Zing zang!
Ta daH!!!
Looking good. I can't wait until i get them. Should i go with a one piece drive shaft over the stock two piece?
September 17, 2013 08:28PM
DeathCanRacing
Zing zang!
Ta daH!!!
A one piece swinging up and down will work, been done, just a clearance question, so yeah maybe. Got to get the diameter right...sumpin about "critical speed times length".
tdrrally
edward mucklow
September 29, 2013 08:12PM
looks like the 240 needs as much tweaking as a fox body mustang.
its looking good keep up the good work
September 29, 2013 11:29PM
tdrrally
It's not a NEED per se..
But in both cases and Corollas and RX7 and Bowel Movement Wonder old school its really easy..what i call "grunty work" and it simplifies things so much its worth making the little effort it is, especially if a guy listens cause i ain't sheetmetal guy so I came up with ways that other guys that are less sheeetmtal guys than me can do it and have it come out good and not some hatchet job.
Its a sorta Why wouldn't you since its just Sawz-all and weld.?
October 02, 2013 09:14PM
Ready to pack and ship:
Front hubs with Bugpack 2.2 in 14 x 1.5 studs with that nice lead or 'speed nose"
And the Toyota 8" now Volvo with same nice fat 14mm studs.
Those stud are the hot sheeet when you have a wheel where the studs are down a counterbored hole and you need to start the nut.
With those you poke the nut into the socket and cram it in and spin.
Fast...and way way stronger than crappy little 12mm intended to go get groceries..
Hell we beef up everything else, its negligence that more people who know better don't push this one detail..
Creech
Scott Creech
Audi 90 Quattro (WIP)
October 03, 2013 03:30PM
So, on something like the 14mm studs - do you just use a tapered reamer to open-up the stud holes in the wheels?
(that is, with the ASS-ump-shun there is enough "meat" in the wheel, and you don't need to enlarge the counterbore to fit the larger nut and socket)
'Nother thing - the rear axles I notice are flat across the wheel mating surface, but the fronts have a small "step" in them - is this (or CAN this be) a weak spot where the nut is clamping the wheel across a "bridge" rather than face-to-face?
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
