aj_johnson A.J. Johnson Junior Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
Congrats to you both, if you think cleaning diapers sucks... it only gets harder to keep them clean!
SeanP Sean Lane Infallible Moderator Location: Sacramento, CA Join Date: 07/29/2011 Age: Possibly Wise Posts: 334 Rally Car: 2000 Dodge Neon G2, bruised |
DG_Rally Dave Grenwis Professional Moderator Location: Minneapolis, MN Join Date: 08/16/2012 Age: Midlife Crisis Posts: 125 Rally Car: '92 VW Golf |
Congrats guys. My daughter's got a little over two weeks on her as well. How long until we can start with go karts? Dave Grenwis - DG Rally - www.dgrally.com |
coryg57 Cory Grunwald Ultra Moderator Location: Puyallup, WA Join Date: 11/17/2011 Age: Settling Down Posts: 53 |
BobOfTheFuture Rob Professional Moderator Location: LI, NY Join Date: 09/25/2010 Age: Midlife Crisis Posts: 629 Rally Car: None, anymore. |
Playing an exaggerated game of telephone operator on a flying switchboard. Or do you mean at home? At home I sleep, and sometimes troll RallyAnarchy... Edit- that's pretty small. Here's a slight closeup ![]() Enablers, All of you. Edited 1 time(s). Last edit at 08/16/2013 11:49AM by BobOfTheFuture. |
It can't be too bad..Redblocks are non interferance, slap a new belt on and go. As for the other one, meh, its a road car. Insurance should fix that right up so what's the problem, just a little bang.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I'm actually going to pull the head and double check everything. When I tried to turn it over there is something stopping it from rotating.
The daily driver has been written off by insurance. Now its negotiating for the value of the car and shopping for something else. |
Could be wadded up former cam belt all jammed up. Pull the plastic front cover first... Above all find out what it is first, don't just pull the head BUT Lissen, if you pull it you may as well clean it up some and PROBABLY oughtter chop around 1.5 to 1.6mm off to up the compression (unless its a turbo motor, then just light skim).. Nice color car....reminds me of another nice 240 I had the honor of co-driving in a couple of times.. (sigh) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I already took your advice when I refreshed John. The head is shaved and it has the VX cam. I didn't think about the belt just being jammed up. Hopefully I'll find some time to get out to the car in the next week or two and get that front cover apart.
I actually had a question on the non-interference head. All the timing belts list for interference engines, but research online says non-interference. And is it still non-interference when its shaved down? |
The chamber is stock about 13mm deep. Fully open the valve is maybe 12.7mm off the seat...max valve lift is however nowhere near TDC when the piston is up. It is somewhere around 90-100 degrees ATDC. In other words, pretty hard to bash the valves into the pistons when the piston is way down the bore... With a broken belt, the valve snap shut as soon as the belt is broken...and with INLINE valves--in line with bore----even if they do kiss, if you're luck is just normal, the piston just gently closes the valve. I've seen traces of contact in the carbon in my mighty Saab V4 many times but valve were never bent. Don't worry, be happy. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Sure, make it easy on yourself. traffic from Pue-you'll -erp can be a bitch so whenever its easy even after traffic calms down in the evening. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
bknblk2 Tony Wood Mega Moderator Location: Wichita Join Date: 02/02/2009 Age: Possibly Wise Posts: 181 Rally Car: 83 Citation "Oskar" |
HiTempguy Banned Elite Moderator Location: Red Deer, Alberta Join Date: 09/13/2011 Posts: 717 Rally Car: 2002 Subaru WRX STi |
I like to punish myself, so this is the new daily driver. Whole bunch of little things to fix (clutch line just randomly popped, stainless steel one inbound). Interesting car though, way too heavy (3800lb's). Don't know if I regret it yet over getting a 1998-2001 A4 or something else, but we'll see. The price was right at $4k and it is pretty mint. Dump a grand worth of parts into it and enjoy it. |
