Re: Rx-7 Rally Car v3.0!
December 18, 2014 11:51PM
Eric Ewert
You sir are very good at building rally cars. How does that toyota axle fit in the rx7 width wise? Also how did it compare in the weight department?
There is no way i would have been able to do this without the help of Al Kun, JVL, and Martin.
this specific toyota axle from the 4runner is the same width as the FC front suspension. Its a ton heavier because its considerably stronger.
December 19, 2014 12:51PM
That's why my goal is this bad boy: http://www.1speedway.com/Floater_Rear_Ends.htm#msfloat
with an aluminum case. Should still be a crapton stronger than the Mazda bits while still close-ish to the 140lb weight.
Eric Ewert
Eric Ewert
volvo 240
December 19, 2014 06:12PM
So one must ask what happened to the IRS rear?
140lb huh I recall the toyota with all mounts on it weighing in at 185. Lots to add but could be worse I suppose.
December 19, 2014 06:38PM
I was wrong, a GSL-SE rearend (big bearing/big axle, 4.5" bolt pattern) weighs 160 with rotors and calipers.
Eric Ewert
Eric Ewert
volvo 240
December 19, 2014 06:51PM
the toyota was weighed without brakes for the record. Also not sure how accurate it would be… I weighed it with a bathroom scale.
December 19, 2014 07:29PM
Eric Ewert
All bathroom scales seem to read about 20% high or more....smoking smiley
Eric Ewert
Eric Ewert
volvo 240
December 19, 2014 10:13PM
ummm... yes of course, I heard that from a reputable source as well... it must be true...drinking smiley
Eric Ewert
Eric Ewert
volvo 240
December 27, 2014 03:09AM
Hey Alex what are you doing for caliper mounts on the toyota axle? I've got a few ideas based on what the off road guys do with 4 runners (bolt on bracket) but figured I would ask what you got on the table.
December 27, 2014 11:33AM
A bolt on bracket drinking smiley
zack13277
Zack Rondeau
83 Mazda RX7
May 05, 2015 08:23PM
Hey Alex, I talked with John V today, about my 1g RX7 build. I'm putting in a Toyota rear end with 4 link and panhard bar, John's coilovers and I was going to make the rear towers taller for the rear coilovers. I was wondering how high you made your towers.
Thanks
-Zack
May 10, 2015 05:42PM
basically as high as i could go. the tops (above which the eyelet sits) are about level with the 1/4 window bottom
zack13277
Zack Rondeau
83 Mazda RX7
May 10, 2015 06:30PM
Ok, thanks. Also did you put a 2nd gen steering column or subframe in? It looks like the column might be like 2 inches short.
-Zack
May 19, 2015 11:52AM
yea i used the entire FC front drop out and the column. Now, the FC column does come up short. If the junkyard Gods smile upon you however, a power steering FB column is longer and will work quite well.
Until i find another one, im staying with the FC column and just dealing with whatever.
May 19, 2015 10:43PM
Is it running yet?
May 20, 2015 09:01PM
Ha!
