RX-3
Posted by hoche
Re: RX-3
June 07, 2014 04:07AM
Well, you don't really have the transmissions lined up right. The T-5 is actually a bit shorter than the Mazda transmission and the shifter is going to be a bit more forward. Start with the input shafts lined up and work back from there. That's the one thing you can't really change. Input shaft has to fit in the clutch/pilot bearing, everything else (bellhousing, driveshaft, shifter) can be modified from there.
Re: RX-3
June 07, 2014 11:15AM
The funny thing is, that trans is from a later RX-7 so the floor was probably hacked to make it work.
The '79-80 RX-7 did not have the remote shifter tower, and the shifter in the same spot as the RX-3. And, I'll bet that the T5 has the shifter come out in roughly the same spot as that.
Re: RX-3
June 07, 2014 11:50AM
Well the snout can easily be shortened and the nose where it pokes into the bearing can be reduced....The GM box pilot is 15mm---be good to know the bearing ID in the Maz-dog..
So Hoche, line the things up next to eachother with the tips of the input shafts on the same line and post piccies
Re: RX-3
June 07, 2014 01:01PM
The GM pilot is near-as-dammit identical to Mazda. GM is a thou or three off, and in violation of Murphy's Law, it's smaller than Mazda not larger.
Which is probably why a GM gearset is used.
Edited 1 time(s). Last edit at 06/07/2014 01:02PM by Pete.
Re: RX-3
June 07, 2014 03:55PM
Yeah, I looked at the Mazda case again this morning and what I thought was a really long bellhousing is actually the bellhousing plus the front half of the tranny.
So Hoche, line the things up next to each other with the tips of the input shafts on the same line and post piccies
Here ya go:
Yeah, the floor is hacked:
Here's about where the T5 shifter will sit:
Re: RX-3
June 07, 2014 04:16PM
I used this shifter in Merkur to move shift knob back a bit. 2-3" or so.
http://www.mgwltd.com/mustang_shifter.shtml
Mines an older design like the attached picture though.
open | download - mgwshifter.jpg (7.1 KB)
Re: RX-3
June 07, 2014 04:33PM
Oh do I have a super simple design to move shifters back AND make as short a shifter as you dare...
Race spec, too---
Re: RX-3
June 07, 2014 08:25PM
stage 5 shifter dislocation
Re: RX-3
June 10, 2014 05:10PM
Is there a difference between an S4 Turbo-II and an S5 Turbo bellhousing?
Can't find just the bellhousing but I found two whole trannies.
Re: RX-3
June 10, 2014 05:31PM
S5 is also Turbo II.
I don't *think* there is a difference in the transmission. Nothing usefully different, anyway.
Re: RX-3
June 10, 2014 05:45PM
Isn't the bellhousing integral to the gearbox case?
Re: RX-3
June 10, 2014 06:01PM
Not on those specific ones. They went back to a separate bellhousing. Or so says my four days of extensive internet research, and you know how reliable THAT is.
Re: RX-3
June 10, 2014 06:32PM
tell me about it.
So separate mmmm that makes modding one a viable option....
Naturally sombody has a CAD file of the rotary block, right?
Where's that Alex Staidle when you need 'im
If we get that then its easy.....
Hurry up and find a loose bellhousing!
Re: RX-3
June 10, 2014 07:12PM
Turbo II has the "R" type transmission with a separate bellhousing, like the RX-3/4/5 transmission but beefier. Bellhousing bolts in from the inside because Japanese companies do things funny sometimes. Not funny ha-ha, more funny WTF.
Re: RX-3
June 10, 2014 11:55PM
Here's a picture of one, snagged from Craigslist:
