Just fun ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
HiTempguy Banned Mod Moderator Location: Red Deer, Alberta Join Date: 09/13/2011 Posts: 717 Rally Car: 2002 Subaru WRX STi |
You're a crazy man haha. I'm thinking about "starting" the process of building a new shell over the next 2-3 years and that is daunting enough as it is. I can't wait to see this thing out on stage though! ![]() |
Last week, a few hours of progress.
Rear bumper and tow hook ![]() New OEM fender liners ![]() Skid plate, Grill, and front end work ![]() Worked on fitting the seats ![]() Rekeyed all the locks ![]() ![]() Tidying up brake lines and such ![]() ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf Edited 1 time(s). Last edit at 09/03/2014 10:16AM by Josh Wimpey. |
Hmmm, they didn't look like that when I posted. will resize ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
user440 Mike Davis Elite Moderator Location: St Louis Join Date: 06/09/2014 Posts: 12 Rally Car: Porsche 944 S2 |
Looks like it's going to be a hoot, and I can't help but love the wacky rally cars.
Mike Davis St. Louis | KD0WTN | Co-Driver #951 Porsche 944 S2 Rally Badger Racing Team | http://instagram.com/rallybadger |
Gravity Fed Alex Staidle Infallible Moderator Location: Δx = ħ/2Δp Join Date: 08/21/2009 Age: Settling Down Posts: 1,719 Rally Car: Various Heaps |
i need to find some leads on VNTs for mercedes OM602 diesel engines....
Skid plate finished. It has welded aluminum channel braces inside running front to back in addition to the frame up front.
![]() ![]() Wiring harness nearly tamed (I think). De-pinned a bunch of unneeded stuff from the fuse box and reduced the harness a bit more. Still no smoke coming out of the wires so that is a good start!! ![]() Still have to deal with the clutch and brake pedal switches. I am running a pressure switch for the brake lights so the pedal switch needs only fool the ECU into never seeing brakes applied so that brake and throttle can be applied simultaneously without fuel cut. Not sure what to do with the clutch pedal switches. Am I correct that they are only used to cancel cruise control? ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
aj_johnson A.J. Johnson Godlike Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
A1337STI Alex Rademacher Junior Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
Posted the following over on the TDI-Club forums with no responses
I am at the point in my project where I am wrapping everything up but still have these switches to deal with and could use some guidance. I have found the threads on defeating the left-foot-braking throttle cut and such but they don't answer all of my questions and I find wiring diagrams quite intimidating so hoping for some practical knowledge. It seems that my wiring harness has 3 pedal-activated switches: 1) Brake pedal switch--activates brake lights, feeds ECU information that results in throttle cut when braking, feeds cruise control defeat signal. I have wired a pressure-activated switch to control the brake lights on this car (rally car) so this switch does not need to function for that purpose but I do need to keep the ECU from thinking the brakes are applied and cutting throttle. I understand this can be completed through tuning. If this is the case, can I simply un-plug the switch and tie it up out of the way after getting a tune? 2) A Neutral safety switch on the clutch (the black switch???) to prevent starting car in-gear and lurching forward/backward into cars/people. I currently have this switch simply dangling under the dash. Have not checked to see how the switch operates --- is it closed or open when depressed?---- but since it is not mounted, the car can be started with or without the clutch depressed. I am fine with this and it seems I could just un-plug the switch and jumper the terminals and tie the harness up out of the way 3) A second clutch pedal switch (Blue) for cruise control defeat ??? Not sure what to do here as I don't know what the switch does. If it is only used to defeat cruise control then no problem. If is is also used for something else, I may have to deal with it somehow. Any thoughts are greatly appreciated as always. Thanks, Josh ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
Sending him an email now. Thanks ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
