dirty_d Brandon B Mod Moderator Location: NE Ohio Join Date: 09/14/2010 Age: Possibly Wise Posts: 83 Rally Car: wabbit season |
So I sent out a check yesterday for that Datsun 210 that was on special stage.
http://www.specialstage.com/forums/showthread.php?61321-1979-Datsun-210-Rally-Car Needs sill bars but other than that and rewebbed harnesses it's "ready to rally" hahaha. The good It runs pretty good. It's a datsun. ka24de. msd ignition. mikuni carbs. The cage looks well built for a grandfathered cage. dana30 rear end from some volvo, tri-linked, 4.88 gearing. it's a datsun. tidy pile of spares. many wheels. did i mention it's a datsun? i like datsuns. did i mention that mikunis don't scare me? they don't. The bad: needs a gearbox rebuild. 2nd gear synchro not so good. comes with a spare gearbox with the same problem. helical lsd - does anyone make a clutchy limited slip for these things? Front suspension was converted to 240sx stuff - steering rack made manual, 240sx hubs & adjustable control arms, customized tie rod ends to fit. kludgy fitting of tension control arms. geometry was not well planned. 240sx is wider track than the 210 by an undetermined amount. bumpsteer weirdness is assumed. Tell me i'm dumb for not flying out and driving it. also tell me of reliable auto transport companies you admire. uship is not giving me warm fuzzies at the moment. Edited 1 time(s). Last edit at 02/21/2014 05:04PM by dirty_d. |
Aaron Luptak Aaron Luptak Godlike Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
While I'd want to add them for my own sake, I'm still not 100% convinced that they "have" to be added - it wouldn't be the first time I've heard of a scrutineer (even Mike Hurst) contradicting themselves and/or the rules.
You're not dumb. I said 'no' to towing it up to run 00 at Idaho 2 years ago with it because I wasn't 100% confident in it. KF7RWG http://www.utahrallygroup.com |
ROADTRIP! DO IT! There are excellent all steel LSD for Dana 30, that's the good news.. Bad news is nearly $2000. Powah steering mitigates a lot of mistakes. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Sent the email with pics to mike hurst to be sure before i did the deal. He says sill bars. I say yes sir. I think i would like X bars in the doors actually. Would like to have at least a bar in the roof but no easy way to do that without having a bad time with a hole saw or removing the roof skin.
i will take the power steering under advisement. I do not possess gorilla arms. easy enough to dig up a pump and a rack for that. the existing rack is supposedly a power rack anyway but there was mention of "welding" in conjunction with blocking off the places where the PS juice goes in and out. I can't realistically do the road trip. thats quite a haul from my neck of the woods. 26 hours one way and somewhere north of 1k in fuel for ye olde family truckster. maybe more if i take the enclosed trailer. Edited 3 time(s). Last edit at 02/21/2014 09:37PM by dirty_d. |
Fly out, drive back! Adventure! I drove in a serious blizzard from Amsterdam to Stockholm in a Mercedes 220s I got for the cost of the train ticket one way for one..And there was 2 of us and we had to stop for a 36 hour thing, temps in the teen, to pick up our kitty Manyard G Krebs who was flying in the Copenhagen---and had been delayed by the storm.. Live a little! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Gravity Fed Alex Staidle Super Moderator Location: Δx = ħ/2Δp Join Date: 08/21/2009 Age: Settling Down Posts: 1,719 Rally Car: Various Heaps |
mellow65 Oliver Klozoff Professional Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
Well it's here.
got a couple things to fix right quick. wheel studs front right seem like they were tacked into the hubs lightly and broke loose. wheel loosened up and threads are all trashed. i didn't check it before doing a loop round the lot. dumb. dumb. dumb. Have a spare stud, but it's loose when i put it in the hole so i'm probably not going to find the same size stud to press fit back in. Is it kosher to tack weld studs to the hub? makes replacing future fuckedup studs a little more difficult if i tack em' lightly.no guarantee they're not gonna spin in the future when i try to rotate the tires in a short service window. edit: can't press in 14mm. I have to use the goofy datsun lugnuts that center the wheels. they're for 12 x 1.25. No reverse gear either, so i've got that going for me, which is nice. I have a spare gearbox but it has a bad 2nd. I also have another unknown condition gearbox but it's from a sr20 so i need to swap the bellhousing with the one mated to the KA in the car. That is today's progress. finding problems. fixing problems. Edited 1 time(s). Last edit at 04/19/2014 02:02PM by dirty_d. |
Creech Scott Creech Ultra Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
http://www.dormanproducts.com/catalog/2006_hardware.htm
"Section 10 - Wheel Studs and Nuts" IIRC, there are diagrams and dimensions of the parts. Catalog home page is here: http://www.dormanproducts.com/dispstatichtml.aspx?PageName=HD_catalogs.html Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. Edited 1 time(s). Last edit at 04/19/2014 02:27PM by Creech. |
Summit has a great search function, and you can filter studs by knurled size and thread pitch.
Are you running the 4spd or the dog leg 5? I just gave away a dog leg and a 240Z 5spd. If you need one I can try and see if they're available. Shipping is probably $150 for freight. |
Rallymech Robert Gobright Super Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Possibly Wise Posts: 1,292 Rally Car: 91 VW GTI 8V |
Ordered some studs on ebay. Summit wanted like 24 bucks a pop for the specific ones i wanted. I love summit as their main location in the east is 1/2 hour away from me so i can actually GO there and get stuff, or go there and check stuff out to make sure it will work.
I typed another post that got spamflagged or something, but basically i found a suitable dorman lugbolt that has a 14.xx mm knurl which is oddball but what i need. they're like 46mm long which is shorter than i wanted, but should be workable. i tried to find something long and rally-friendly but it doesn't exist with that knurl. not from arp or anyone anywhere. I'm stuck with 12 x 1.25 because i have to use these stupid nissan specific centering lugnuts for all the wheels I have. The car has a FS5W71 5 speed gearbox they used in about every 240sx in the world among other cars, and it's mated to a KA24de 2.4 liter twin cam motor that's the same deal. These gearboxes are all beat on by every wannabe dor-ifto dork in the universe so finding a good junkyard version is a bit of a crapshoot. thus the bellhousing swap with a gearbox i have on the shelf. (also a crapshoot, but i don't have to buy anything) OSgiken makes a nice close ratio gear$et for these. you can replace gears 1 through 3 for about 2k. Would be nice to find a cheaper alternative if i have to rebuild a gearbox anyway, but thats about 3x what i would consider reasonable for (MAD TITE JDM GEARZ YO) Nissan stuff. |
