gt86/frs/brz
Posted by Dazed_Driver
Re: gt86/frs/brz
June 24, 2014 01:36PM
well there was one at Idaho this year.
Re: gt86/frs/brz
June 24, 2014 01:38PM
there was one at Idaho this weekend
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
Re: gt86/frs/brz
June 24, 2014 01:42PM
Hard not to want the above car...pic looks nice!
Not that i could afford it anyway..but then I picture my 6'5" 300 lbs ass sitting in there..
I doubt I'd fit!
How cramped are these cars...particularly with a cage?
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
John Reed
John Reed
Toyota AE86
Re: gt86/frs/brz
June 24, 2014 01:49PM
It has WAY more room inside than my Corolla - the look and the room are the main reasons I want one over what I currently have. Otherwise I suspect the simplicity of what I have now is better (suspension and stuff).
As far as the electronics goes, like any modern car they are fairly complex so the best advice is keep the thing as stock as possible. The more you remove, the more pissed it will get and you will waste time and money dealing with that. ABS and stuff has to stay in there to some extent to keep other parts of the car functioning properly. Me, I would rip it all out and start over with my own stuff, but that is not the path most guys want to go down....
Suspension, it sounds like the one at Idaho was fairly simple (maybe just changing dampers/arms/etc) or you can talk to the Nameless guys and purchase their setup (take out all the stock stuff and run their subframe/arms/dampers/etc). Likely not cheap, but proven to work in rally and I believe mostly bolts in (save for maybe the towers)!
Or just rip it all out and do a solid axle and 4 link setup in the back.
John Reed
John Reed Racing
www.johnreedracing.com
johnreedracing@gmail.com
Edited 1 time(s). Last edit at 06/24/2014 01:50PM by John Reed.
Re: gt86/frs/brz
June 24, 2014 02:16PM
The one at Idaho was servicing right next to the team I was servicing for. I didn't talk to them much, but I did find out that it was pretty stock, albeit with Ohlins dampers. They were mostly out there as a learning experience, not pushing hard at all.
Re: gt86/frs/brz
June 24, 2014 02:18PM
still a little too much push
open | download - 10371380_10152507263389375_2104987113042378369_n.jpg (106.9 KB)
czwalga
steve czwalga
95 awd celica
Re: gt86/frs/brz
June 24, 2014 02:24PM
I'm restoring a flood damaged CAN-bus car; and by flood damaged i mean salt water over the roof damaged. I've learned a lot, but there's a lot of draw backs, such as everything is married to the VIN blah...so dealers can make more money and you're almost forced to use their shops. If you can program the ECU (which to my knowledge is still possible in most cars with aftermarket support) you can eliminate CAN-bus from your car completely. All your actuators, motors lights etc etc, are still 'dumb'. They are just controlled by smart things.
For a race car thats stripped out, hard wiring the bare essentials shouldnt be a big deal. When it comes down to it most of the parts you need to work will still work with old school controls and oem switches. You just need to wire them properly to eliminate the brain.
You can also eliminate a bunch of other modules on the BUS system that you dont need, airbags,abs,coms... you just have to make sure that your terminate resistors are still in place, and that the high speed lan wires are looped through if you eliminate something. Or just eliminate the BUS system completely.
Really all im trying to say is for a race car, thats never going to back to factory specs; if you can get the engine to run independently of the car; the CAN-bus shouldn't scare you.
Edited 1 time(s). Last edit at 06/24/2014 02:26PM by czwalga.
Re: gt86/frs/brz
June 24, 2014 03:29PM
The was a BRZ at Idaho.
kainam00
Dmitriy Martynov
2.5RS, Crashed and neutered
Re: gt86/frs/brz
June 24, 2014 04:26PM
I probably wouldn't really even want to change subframes/control arms, just the dampers. I've looked under one of these a while ago, and it's honest, simple stamped steel under there. Nice, cheap, reliable, easy to reinforce, and easy to bend back into shape. As long as the travel is decent, I don't see a reason to change it for a basic G2 car.
I have an RSSP setup from my current "GC" chassis RS, which should probably fit the front with a little work...
I guess I'll investigate further.
Edited 1 time(s). Last edit at 06/24/2014 04:30PM by kainam00.
webkris
Kristopher Marciniak
2003 Dodge Neon
Re: gt86/frs/brz
June 24, 2014 05:40PM
Idaho Rally Scion FR-S
- Kris
Re: gt86/frs/brz
June 24, 2014 07:03PM
hey, did you guys hear there was a fr-s at idaho? tongue sticking out smiley
webkris
2003 Dodge Neon
Re: gt86/frs/brz
June 24, 2014 07:30PM
OMG RIGHT?! grinning smiley winking smiley
Robert Culbertson
Out of this dumpster fire
Re: gt86/frs/brz
June 24, 2014 09:33PM
Well he sure stuffed it into those bushes. Nice job Jason!
Not like the old Saab eh?!
Edited 1 time(s). Last edit at 06/24/2014 09:35PM by Robert Culbertson.
Re: gt86/frs/brz
June 25, 2014 07:21AM
Is that an FRS? I thought it was a BRZ? Why do people keep saying GT86? Last I checked Toyota isn't selling a GT86 anywhere in the world! And by world I mean USA of course. winking smiley
Though it looks like Toyota is starting to get what we've been saying all along. BMW > Subaru. smiling smiley
http://www.gtspirit.com/2014/06/24/toyota-could-ditch-subaru-partnership-to-focus-on-bmw-collaboration/
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: gt86/frs/brz
June 25, 2014 07:43AM
Well we know Toyota is not serious about rally since they did not partner with Volvo.
