webkris Kristopher Marciniak Infallible Moderator Location: Long Beach Join Date: 10/20/2006 Age: Midlife Crisis Posts: 124 Rally Car: 2003 Dodge Neon |
New bulletin out today discusses the serious nature of helmet cams.
http://rally-america.com/RuleBulletin/Rule_Bulletin_2012_011.pdf "Cameras may not be mounted to competitors’ helmets." Guys - it's time to hang up some of these questionable designs: For example: Steven did his first RallyMoto event with this one: Some great in-car from 100AW was recorded with the following: Electronic stabilization is years away - and we thought the foam was safe enough... Remember when a block of wood and two screws was GOOD enough? When Travis jumps motocross he uses this: It's too bad we'll never get anymore Travis Pastrana in-car from his face rig... Wireless video is never going to happen - but we have to stop using our metal coat-hanger viewfinders... Tireless hours of helmet cam research LOST! While we may not agree, we can understand this decision... If only we could get our hands on this future space age prototype... - Kris |
A1337STI Alex Rademacher Junior Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
tipo158 Alan Perry Mod Moderator Location: Bainbridge Island, WA Join Date: 02/20/2008 Age: Ancient Posts: 430 |
This is the particular camera that we were thinking about - http://gopro.com/cameras/hd-helmet-hero-camera/
alan Edited 2 time(s). Last edit at 04/16/2012 06:07PM by tipo158. |
Dear Rally-America.
Thank you greatly from a viewer of onboard videos. Helmet cam in a rally car is simply retarded and is a novelty and more likely to nauseate a viewer then inspire envy or envoke a desire to get involved with rallying from any perspective. Furthermore I believe internal operations manuals and press agreements should stipulate that any video being produced under RA media guidelines are required to utilize either interior shots with audio or exterior shots only with an additional microphone for audio inside the cabin. Rationale: I am continuously amazed at how the 1995 WRC review has epically better onboard video than what is in use in productions today. After much review it was determined that there were two primary differences between these videos. 1995 had a fairly standard camera angle with fairly low resolution but decent audio captured both from in the cabin (lots of engine, gearbox, and gravel spray sounds) and a mixed but not overwhelmingly loud (ie. no clipping) of the WRC intercom system. The videos of recent times, specifically those filmed on Go Pro and other 'wearable' cameras, result in high quality high resolution video and an audio stream that is best described as piss poor garbage. This level of footage does not belong in a professional production. Successful videos such as Ken Block's Gymkhana series may have utilized these small high resolution cameras for video capture, but audio capture and professional mastering was done seperately. Out of car video with just wind sounds is possibly the worst. See Lestage onboard from Rally in the 100AW 2012 at 4:20 for example. Grant Hughes |
It just seems rather silly when compared to issues like car prep, cage design, sill bars, and the like. One should consider the even hand of a rule-set. Filling up a rule book with warnings similar to the ones on the side of a hair dryer is not conducive to getting competitors to take serious rules - seriously... My 2 cents for the year. - Kris |
I don't understand. Do you think that no one has been thinking about running helmet cams in a rally car? RA already has rules on car prep, cage design and the like (sill bars are not part of Art. 253 cages)? The helmet cam is "silly" compared to those rules, but it only adds one sentence and makes things safer. alan |
Gravel Spray ------------------------------------------------- Senior Moderator Location: ------------------------------------------------ Join Date: 07/25/2008 Posts: 157 Rally Car: ------------------------- |
Out of curiosity - what precipitated this?
I guess I just don't see a 4oz hero cam double-sided sticky-taped to a helmet as being any sort of problem. How about: "Helmet cams should not interfere with seats, vision or other safety devices." edit #1 (Oh and they can't be more then "a reasonable weight" to prevent the debauchery seen above...) edit #2 (AND they are only going to get smaller in the future!) - Kris Edited 3 time(s). Last edit at 04/16/2012 06:57PM by webkris. |
Helmet worn cams in rally cars are stupid and annoying to watch. Jon Burke's done it. I've watched it. Hated the perspective.
Wanna have that first person view? Mount it a post strapped to your Hans device or similar. Less movement and no longer mounted to helmet albeit probably less safe. Or to the wing of your cool OMP seat from Safe Drives. Grant Hughes |
KTurner Kevin Turner Mega Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
See Grant's post: "Helmet cam in a rally car is simply retarded and is a novelty and more likely to nauseate a viewer then inspire envy or envoke a desire to get involved with rallying from any perspective. " There are enough poor quality in-car videos out there, the helmet cam just lowers the bar. -KTurner Stomp down on the exhilarator and hold on to the wheel. |
MConte05 Matthew Conte Mod Moderator Location: St. Louis, MO Join Date: 06/27/2011 Age: Settling Down Posts: 257 Rally Car: 1991 Subaru Legacy Turbozzzzzz |
I don't know what precipitated it, but after the issue was raised, we watched some in-car video from some offs and we saw potential for injury under the circumstances described in the rationale. There was enough movement of the competitors that if either competitor had been using a helmet-mounted camera, the camera (or its mount if the camera broke off) could dig into the seat wings or something else and cause the head to turn in a plane where the H&NR does not limit movement or it could dig into the other occupant of the car. My particular concern was the camera mount should the camera break off. It would pointy and firmly affixed to the helmet and protruding from it. We understand that cameras will get smaller in the future. As technology advances, the rules change. All cameras used to require to have two points of attachment, but now cameras under 8oz don't. alan Edited 1 time(s). Last edit at 04/16/2012 10:08PM by tipo158. |
No it was "oh no fuckin Nigel" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Anders Green Anders Green Junior Moderator Location: Raleigh, NC Join Date: 03/30/2006 Age: Possibly Wise Posts: 1,478 Rally Car: Parked |
