OjNK Gordon Sleigh Mega Moderator Location: Halifax, Nova Scotia Join Date: 12/09/2012 Age: Midlife Crisis Posts: 56 Rally Car: 2000 Subaru Impreza 2.5RS P4WD |
So on a lark I'm taking our rally car out to an AutoSlalom next weekend. I haven't done any slaloming in ages, and then mostly in Civics and Miatas. We're pretty much just going out for shits and giggles and to spread the word/awareness of our building stage rally series, so I'm really not expecting to do much, especially since the only non-gravel tires I have are some truly awful Federal brand All Seasons that came from the dealer on my Wife's Impreza.
Anyway, its a 2000 Impreza RS Production 4WD car, so the only mods of consequence are the cage and the Hotbits DT1s. Any recommendations for settings and tire pressures for a fairly tight course? On the Civic with adjustables I'd stiffen the front full hard and the rears almost full soft. On the Miata I didn't have adjustables but I ran a big front sway and no rear sway which worked well. Adjusting the suspension, tire pressures and maybe disconnecting a bar is about as far as I'm willing to go on this little adventure. Any suggestions? I'm expecting more hilarity than anything else. Atlantic Canadian Region Rallysport: http://www.rallyeast.ca - Ledwidge Lookoff Rally http://www.lookoffrally.com 2000 Impreza 2.5RS CARS P4WD (Sponsored by Rally-Tech, Great North Performance) |
Considered it, but don't want to chew up any of the sets we have. Trust me, these Federals will provide a decidedly rally-like lack of traction.
Creech Scott Creech Senior Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
"Soften" the end that pushes the worst. (shock settings, tire pressures, etc.)
They're crapasstic tires, who gives a fawk if you roll 'em over onto the sidewalls, right? "If you can live with body-roll, softer suspension gives more grip" (paraphrase) True with Asphlat as it is with teh Gravellys..... If it pushes hard-enough (think "F-Stock Mustang" ), do all your braking, THEN turn-in. Of course, you don't have 300-400hp to power back out again, I'm guessing. Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. Edited 2 time(s). Last edit at 09/08/2013 10:18PM by Creech. |
si John Farnsworth Elite Moderator Location: Chicago, IL / St. Louis, MO Join Date: 03/01/2013 Age: Midlife Crisis Posts: 54 |
Well, I can't speak to your local group/club/region of AutoX, but I can say that in the local SCCA events here, if you demonstrate any rally-like lack of traction and continue, the safety steward will likely ask you to take a seat outside of your car. Generally it's not considered acceptably safe to drift a corner intentionally.
From my experiences with an 01 2.5RS, I'd say start at about 42F 38R cold, and then as you get comfortable with the grip and the tires and surface warm up, take it either down to 40F 37-38R from wherever it lands, or up to 42F 40R. Depends heavily on the surface and how it feels. I wouldn't disconnect a bar. The Impreza normally isn't tail happy, and you'll want the rear bar to get any decent rotation on the tight parts. If you aren't getting the rotation, I'd take the tire pressures up a bit in rear until you do. Don't expect to ever be able to use those tires again if it's asphalt. Tight corners on warm asphalt with high pressures on AS tend to look like you took a tire groover and went crazy all over the outer 1/8th or so of the tread. |
(groan) (attempt at explaining why--since we know the what already) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Meanwhile, I did that and got thumbs-up from corner workers and event officials, with just the light admonishment that they didn't care what I did since i wasn't hitting cones. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
12xalt "oh! you're the one!" Super Moderator Location: Hazel Dell, WA Join Date: 02/22/2008 Age: Possibly Wise Posts: 1,390 Rally Car: 1974 Dodge Colt, under construction |
as for the drifting, etc, the small club I occasionally do an autox with once in a while just rolls their eyes and tells the worrywarts "rally driver" when one of us shows up
as long as we aren't using the course for drift practice and don't to it intentionally on every single turn, they typically don't get upset though I have been talked to for getting too sideways too close to the timing gear |
As a long-time Solo Safety Steward, as well as an Instructor - I have to say you are talking out of your arse, John. The ONLY job of the SSS is to ensure the safety of the course (i.e. it meets guidelines for runoff and collision hazards), and the Safety of Spectators and Participants. Somebody Hooning a bit too-much on-course? NOT the SSS' job to call him/her on it. Someone's Hooning gets "out of hand", and they get a bit too close to the crowd (or Courseworkers) or grid/paddock and parked vehicles? Shut'erdown-Time, son. TEH EDITZ: SSS is a Volunteer position - it carries no "power", has a crapload of responsibility (when shyte goes all upside-down: sometimes Literally), and is essentially Thankless. But then, you probably already know everything there is to know about all of that, as you participate regularly and are likely an SSS in your local club yourself; Right? I mean, how else would you have your finger on the pulse of exactly what goes on at every fucking single fucking grassroots fucking event, all-over the goddam fucking world, right John? Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. Edited 3 time(s). Last edit at 09/09/2013 03:15PM by Creech. |
Generally Same-Same at all the places I play. A couple of years-ago at KC at the driver training center, at one event I didn't have anyone in my class to "square off against", so I just tried new things. Got mad-props for goin' El Dorifto on my runs around this huge, 240-degree increasing-radius curve they had set up. I am NOT the fastest or bestest driver out on the course - but more than one person HAS told me that I am always entertaining to watch. I'm there to have fun, that's all I know about it. Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. |
Me? I neither intended to condone or disparage the practice. I'm only speaking from experience in the 2 regions I have done events with (St. Louis and Chicago). What you say is fair - the lots have hard obstacles (light posts, barriers, fences, timing equipment) and are always limited on space. I don't believe I've ever seen anyone drift a corner completely (without attempting to stop the drift and regain traction) and not get at least a talking to after the finish. I have only seen 2 people asked to not return, and both were self-proclaimed drifters who were being very obviously reckless and on more than one corner caused the course workers to flee. Edited 1 time(s). Last edit at 09/09/2013 02:00PM by si. |
KTurner Kevin Turner Mod Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
that's what I usually get at the autoX. "You know this isn't dirt? right?" have autosnoozed the rally car a bunch since there used to be an event 0.5 mi from the house. I would set your tires to about 40psi to start and don't change anything else (not worth the effort). if you want a tire marker on the sidewalls will give a quick indication if you need to go up or down in pressure. the drifting issue usually depends on if you appear out of control or not. -KTurner Stomp down on the exhilarator and hold on to the wheel. |
Not you - Mr. Vanlandingdammitalltohellman's "interjections". Sorry, it looks like it was addressing you because of the teeny tiny script he used figuring it would be overlooked, except by maybe Morison or one of the other people he wars with constantly. (no offense to you here either, Keith) Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. Edited 1 time(s). Last edit at 09/09/2013 02:31PM by Creech. |
my brother is usually the entertaining one at autox because he'll show up in and run anything (including his wife's tahoe) Last time I ran (in my stock protege5 with all seasons on it) I was told I had the best launch of the day. I'll take it! |
Awwww. OK maybe there really aren't really perverts who pull wings off flies, but the whiny "you can't do THAT, it looks dangerous" BS is what the whole thing strikes me as--but its only based on 30 years of fleeting contact with "those sorts" so I'm probably wrong. I mean if I wanted to spend a whole day listening to people whine about why "the other guys "have to be" cheating cause he beat me" I could just find a gang of Microsoftie nerds sipping their lattes and listen to them John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
