Project Mini-me
Posted by MattP
Towona
Tony P
MK2 Golf
Re: Project Mini-me
May 27, 2015 12:21PM
Sweeeeet
Runamuck Rally
tdrrally
edward mucklow
Re: Project Mini-me
May 27, 2015 01:42PM
FREAK EN SWEEET!
ALS FTW
Don K. Oates
looking
Re: Project Mini-me
May 31, 2015 04:02PM
Would there be any sense or value in doing a 4 link suspension for the rear?
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
May 31, 2015 05:49PM
I've looked at the benefits against the cost and fab work, If I were to be doing a lot of high speed desert style races or raid events then yes it would be of use, however I would have to modify the cage to comply with FIA regs and where it meets the rear most suspension mounting points. As the majority of the stuff I will be doing aren't, then there isn't a compelling reason to do so. Also if anything were to break on event, its a quick call to Lordco, Napa, or any other local autostore and hey presto, for cheap parts and minimal time I can continue. Remember the whole reason I built this was for fun and cheap(ish) motorsport. I've seen very simple plans being over engineered to the point of being impractical and costly.
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
Re: Project Mini-me
June 01, 2015 09:06AM
Did you get rally ready weight?
Re: Project Mini-me
June 01, 2015 02:22PM
MattP
if it works, don't mess with it.
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
June 01, 2015 07:18PM
Grant, no I haven't had time to weigh the beast yet but I'm guessing 3400 give or take.
Exactly Al, I'm going with the KISS principle on this build, well for the time being at least!!
Yes, it's a Ranger.
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
June 05, 2015 10:45PM
Grant, I just weighed the beast, with a 2/3 tank of fuel, a 200lb driver it comes in at an alarming 1800kgs 3970 ish, I'm thinking I may have to trim the weight by a fair bit. However I just looked at the original weigh-in and if I'm taken out of the truck it weighs exactly the same as when I started. So adding 140' of DOM, 6 gawdam heavy wheels and tires and all the safety stuff was not the diet I was thinking of, more like Ricky Lake than Jenny Craig! I just replaced all the suspension with Bilstien 5100 and Deaver rear springs as the I found out after Radium that not only was one leaf pack broken but I had no shock on the drivers front and all the others were definitely past their prime. Took it out for a little run up a gravel road, so much easier to coax the rear end to steer now and wayyyy more predictive. Now to find an event to go play with it!
Yes, it's a Ranger.
open | download - New Shocks.jpg (24.8 KB)
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
June 13, 2015 11:43PM
Just got this from a spectator at Radium last month!
Yes, it's a Ranger.
Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
Re: Project Mini-me
June 14, 2015 12:22AM
nice save matty!
All bridges burnt, island life is beauty
Towona
Tony P
MK2 Golf
Re: Project Mini-me
June 16, 2015 02:13PM
Why they let spectators sit there is beyond me. Seems way too dangerous a spot.
Runamuck Rally
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
June 16, 2015 10:38PM
Thanks to the vid, it's now going to be addressed for the next rally RMR
Yes, it's a Ranger.
ElectroTech
Steve Wheeler
1992 Golf
Re: Project Mini-me
June 16, 2015 11:24PM
Looks like a blast!
tdrrally
edward mucklow
Re: Project Mini-me
July 01, 2015 10:03AM
any updates?
MattP
Matt Pullen
2002 Ford StRanger
Re: Project Mini-me
July 29, 2015 09:15PM
Not so much, this is the lul in the western Canadian season. And what with our loonie tanking againgst your buck it makes it a tad expensive to come and play south of the border at the moment. But there is a test day up here on the 23rd Aug I'm going to be running the Ranger at, a nice 5km stage will be good for trying new things and improve the driver skills.
Yes, it's a Ranger.
