PAddy Patrick McVeigh Junior Moderator Location: Toronto, ON Join Date: 12/21/2005 Age: Midlife Crisis Posts: 358 Rally Car: Student Loans |
Patrick, I bought a military jumpsuit I wear when working that helps to keep me from tanning much, but that friggin undercoating is still our nemesis!
I have never seen a car that has it applied as thick as the Merkur! I end up blowing and spitting that crap up for 2-3 days after! Friggin stuff... I can't wait until we finish the bottom and then we'll be done with it. It's all over the shop, and I mean ALL over. Cheers! John http://www.lastditchracing.com http://www.triplecaution.us |
John Cassidy Wrote:
------------------------------------------------------- > Patrick, I bought a military jumpsuit I wear when > working that helps to keep me from tanning much, > but that friggin undercoating is still our > nemesis! > > I have never seen a car that has it applied as > thick as the Merkur! I end up blowing and > spitting that crap up for 2-3 days after! Friggin > stuff... > > I can't wait until we finish the bottom and then > we'll be done with it. It's all over the shop, > and I mean ALL over. > > Cheers! John And just why do you think I yakk so much about the joys of liquid nitrogen?? Spray sparay, chip chip, oh what a relief it is!!! No muss, no fuss, no messy pads to change. Looking good John. Hey I'm about to send you some rear shocks soon as I have the spring seats machined up. Time for another teleconfrence. > > > John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John Cassidy Wrote:
------------------------------------------------------- > Too early in the AM. Gotta post one more. > > > > > > > Edited 1 times. Last edit at Jan 7, 2007 by John > Cassidy. I see you're getting with the program John. That nice green spray bottle is a good start, now paint that block the same and you're on your way to being In with the In crowd. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Toyed with the idea of liquid nitrogen, but we weren't sure that we'd have the rotisserie done.
There's lots of logistical issues to be dealt with on the underside of the car, both fron and rear. In the front, I need to put the frame rail engine mounts in. Of course, I can't do that until I have whatever tranny I'm going to put in this thing. I also can't do the radiator support until I source a radiator. In the rear, I need to source Supra diff, and apparently mod the STA for the coil-overs. I also want to put in one of the sexy square rear diff carriers, or at least get plans to make our own. Then, I need brakes and rally rims etc. Man, it's all going to be spending from here on out! Cheers! John http://www.lastditchracing.com http://www.triplecaution.us |
John nI can easily find you a good unsaltified Saab 900 rad and the twin fans, I have anb extra rad mount, I have Cosworth intercoolers, and the critical 110degree hose, and I have the Cosworth turbine housing you want to stick on the exsisting center section of your turbo and I have the flange and can supply the downpipe to get you into the tunnel.
I can also supply a diff with 4.3 The parts that were hung up for 6 months at the lazer cutter for some unknow reason are now cut so now its back to jigging up the first 5-6 square beams. I may also have some Compomotive THs. I might just be making a trip out that way to trailer a nice rust free non sunroof street car for pPaddy to drive whiloe he's finishing his degree so some of the stuff could be thrown in the van for that trip. Might be fun and it'd give me a chance to see my friend Mike Ryan in Wiscasset who's gotten married and who's a new Dad like me. You're supposed to find a Camaro V8 T5 cause they all have the ratios we want AND the gearstick is in the right place or call Hanlon Engineering in PA and splain you want the 2.95 gearset and the shifter like the Camaro. You can choose what 5th ya want, like a .72 or .68 to use it as a "transit only cruise at less revs even with a 4.3 than a normal street car" or get a .82 and actually use it sometimes on those fast stages. And I am another run of struts and there you can now choose between 40s like everybody else or go 50mm. Time to dust off the checkbook it seems. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Checkbook indeed. Problem is, it never sits long enough to gather any dust! ;-)
We'll talk in the next couple of weeks. I'm in no huge rush to get this done, although I do want it done, if that makes any sense. The cage will take us a bit, as will building the hydraulic bender. Cheers! John http://www.lastditchracing.com http://www.triplecaution.us |
> I might just be making a trip out that way to > trailer a nice rust free non sunroof street car > for pPaddy to drive whiloe he's finishing his > degree so some of the stuff could be thrown in the > van for that trip. Oooooh, and trailer back the green 96? ![]() --Andrew Andrew Steere Lyndeborough, NH KB1PJY |
fiasco Wrote:
------------------------------------------------------- > > I may also have some Compomotive THs. > > I might just be making a trip out that way > to > > trailer a nice rust free non sunroof street > car > > for pPaddy to drive whiloe he's finishing > his > > degree so some of the stuff could be thrown > in the > > van for that trip. > > Oooooh, and trailer back the green 96? > > --Andrew > > Andrew Steere, 1973 > Lyndeborough, NH > eventual XR4Ti rally car... That's the idea. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Rallyho Mike White Professional Moderator Location: Camden, Maine Join Date: 02/20/2006 Age: Possibly Wise Posts: 187 Rally Car: Saab 900 - aka-The Swedish Rally Tractor |
John, make sure you let me know your schedule if you're headed back east. I'm in Camden Maine, basically on the way up to John C's.
She's screamn' fer eet! Rallyho Mike White http://www.facebook.com/rallyhomotorsports |
Here's the tubular manifold I have. Well, mine is actually welded closed for an internal wastegate. Even though I have a few Audi external wastegates laying around. I like this one because it leaves the turbo in stock location, which I wanted since I already have a stock location 5 blot flange 3" downpipe as well.
http://cgi.ebay.com/ebaymotors/2-3-FORD-ATR-TUBULAR-HEADER-SVO-MERKUR-XR4TI_W0QQcmdZViewItemQQcategoryZ33631QQihZ015QQitemZ250069337077QQrdZ1 And here is the radiator I bought. http://cgi.ebay.com/ebaymotors/RS500-RADIATOR-COSWORTH-3DR-or-Sapphire-Ford-XR4Ti_W0QQcmdZViewItemQQcategoryZ33632QQihZ005QQitemZ150076746679QQrdZ1 I have a Saab one that I got from John somewhere, I think it's in the spare shell up on the man ranch though. I'm sure John will tell you why all of that is a waste of money though. Of course, my ex-girlfriend can tell you why all of this rally shit is a waste of money. And my current one can tell you why none of it is a waste of money. As will my smile in a few months when I'm behind the wheel. The linked radiator does have the in and out on the wrong ends. But there's some easy and not so easy solutions for that that can be found on Merkur Sport or Merkur Club. I don't remember which. Grant Hughes Edited 1 time(s). Last edit at 01/08/2007 12:24PM by NoCoast. |
------------------------------------------------------- > Here's the tubular manifold I have. Well, mine is > actually welded closed for an internal wastegate. > Even though I have a few Audi external wastegates > laying around. I like this one because it leaves > the turbo in stock location, which I wanted since > I already have a stock location 5 blot flange 3" > downpipe as well. Oooooooooh so you're being smart again..... Dude what the fawkk? You're going nuts and missing some important shit man. > > > > And here is the radiator I bought. > > > I have a Saab one that I got from John somewhere, > I think it's in the spare shell up on the man > ranch though. > I'm sure John will tell you why all of that is a > waste of money though. Man it seems you like to spend money!!! Whatever! But I don't so that's why I was hoping that 4.3 diff I got for $10 would be useful. It's been since Nov 12 when I won it Grant, so if you don't want to get it just say so and I'll find some Volvo perv that can. Of course, my > ex-girlfriend can tell you why all of this rally > shit is a waste of money. And my current one can > tell you why none of it is a waste of money. As > will my smile in a few months when I'm behind the > wheel. > > The linked radiator does have the in and out on > the wrong ends. But there's some easy and not so > easy solutions for that that can be found on > Merkur Sport or Merkur Club. I don't remember > which. At least the SAAB raditaor the stock hose just slip right on, > > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO > > > > Edited 1 times. Last edit at Jan 8, 2007 by > NoCoast. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Just ordered the JD2 tubing bender and we're going to convert it to hydraulic operation. Should have it operational in about a week or so and will be able to start building the cage.
Looking at the date of the last post, I think my time estimate was optimistic...as usual! ;-)
We are nearly done with all the seam welding on the bottom of the car. We're planning on running 1" tube down the sills to make it bombproof. Might have some more pics by the end of the day tomorrow. Air distribution system in the barn busted in the cold. Water in the sytem froze and expanded. Nice science demo, but one we could have lived without. Repaired and have a leak in the repair. Damn cold! I'll get more parts tonight in case the extra layer of adhesive doesn't seal it up. JD2 tubing bender arrived late last week. Will be starting on the assembly/fab tomorrow as well. Hopefully get it to a point where all we need is to measure and buy the hydraulic lines. We'll have the cage designed in bendtech pro software, so if anyone wants to see some pics of how that works, I'll post those too. Cheers! John http://www.lastditchracing.com http://www.triplecaution.us |
